Our Touareg has been giving a parking brake fault when applying it or starting the car after it has been applied. The car beeps, the light on the switch flashes, and the instrument cluster shows "error: auto hold". The car does not have auto hold, and scan shows two errors, left parking brake motor maximum travel limit exceeded, and parking brake motor- signal implausible. I cannot find any information about this error. The parking brake holds the car, and the air gaps are within tolerance, 2.273 left and 2.285mm right, and the the system is calibrated and has coding. Any insight on this issue would be much appreciated! Thank you.
Friday,15,March,2019,16:06:22:09325
VIN: WVGDF9BP4ED002232   License Plate:
Mileage: 186301km-115762mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          6C 6D 72
VIN: WVGDF9BP4ED002232   Mileage: 186301km-115762miles
Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 CD    HW: 03H 907 309 E
   Component: 3.6 FSI ULEV  H16 5844
   Revision: M7H16---
   Coding: 002A0012432600000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM36FSI01103H906023CD 001004
   ROD: EV_ECM36FSI01103H906023CD.rod
   VCID: 6695B79308E58BE7041-8032
Readiness: 1110 0101
   Part No SW: 0C8 927 750 CG    HW: 0C8 927 750 CG
   Component: AL1000 AISIN  002 2466
   Coding: 001368
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 73B3DEC74B376E4F93F-8026
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 416230010EC815
   Coding: 5B7613C349242555DAF6C89692D4A4407300
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD63237C3D4F87009-801E
   Part No SW: 4H0 907 064 DK    HW: 4H0 907 064 DK
   Component: BCM2 2.0      H34 0503
   Coding: 0D860016000000000000
   VCID: 75B7E0DF45C3707FBDB-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2313000092413005
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: 4606200A80
   VCID: 0557901F15A360FFADB-8050
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001452201
   Coding: 26001012973C5D010020180300005D0C431C460882010261000000020000
   VCID: 6C81C5BB1689B1B7525-8038
   Component: WWS    130602  031 0021
   Serial number: 90243400130610142420
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20131010
   Coding: 025223
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001306130092
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R5Z1W02
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag02F H06 0026
   Revision: --------    Serial number: 003L5001DH8P
   Coding: 000000000000000000000000000000003246
   VCID: 42DD4B03440D97C7C89-8016
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R131110BD85
   Serial number: 3575LRB401450GEME8FA
   Serial number: 3585LRB401050GEOBOT-
   Serial number: 3515RRB400I50JHIKPVL
   Serial number: 3525RRB400I50JHIL1CN
   Serial number: 3555NRB400250J2AH9O%
   Serial number: 3565NRB400A50J2AMP27
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815MFJ0002J
   Coding: 000015
   VCID: 363527D318453B67741-8062
   Serial number: 0264614
   Part No SW: 7P6 920 982 K    HW: 7P6 920 982 K
   Component: Kombi         H13 0419
   Revision: 13240080    Serial number: 658180613592003
   Coding: 8B7732022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 46D557136825ABE7E41-8012
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H12 6032
   Revision: --------    Serial number: 00000000969310
   Coding: 0021035600
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FDB42F737FFFA2FA77-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 30161D29045701570243
   Revision: AA000000    Serial number: 00000064289995
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 34311DDB0E3929774A5-8060
   Part No SW: 4H0 959 793 AA    HW: 4H0 959 793 P
   Component: TSG FA        H02 0305
   Revision: --------    Serial number: 0000065044061
   Coding: 011D17205E00453005080000
   VCID: 78A9E9EB52D10D17A6D-802C
   Revision: 00002001    Serial number: 0309534229
   Coding: 0106123A68B9509580B00620010000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 126135392
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO22169857
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO22439396
   Coding: 191100
   Part No SW: 4H0 959 792 Q    HW: 4H0 959 792 M
   Component: TSG BF        H02 0305
   Revision: --------    Serial number: 0000065139341
   VCID: 46D5571368A5ABE7E41-8012
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1361300230
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 363527D318C53B67741-8062
   Slave 3:
0040 - Motor for Electronic Parking Brake
          C10E3 29 [008] - Signal Implausible
                    Reset counter: 219
                    Mileage: 185982 km
                    Date: 2019.03.13
                    Time: 20:33:17
                    Voltage: 12.4 V
0055 - Left Parking Brake Motor
          C10BC F1 [009] - Maximum Travel Limit Exceeded
          [Steuergerät EPB - Aktuatorweg erschöpft - Rechs]
                    Reset counter: 219
                    Mileage: 185982 km
                    Date: 2019.03.13
                    Time: 20:33:17
                    Voltage: 12.4 V
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   VCID: 7CA1F5FB66692137C25-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156F 0D7815190
   Coding: 020007020100000001
   VCID: 2411ED9BBED9B9F7DA5-8070
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0706
   Revision: --------    Serial number: 273F.0D7500549
   Coding: 010200050040E1EE41020B0C00000003F00001030000000000
   VCID: 392F2CEF295BD41F993-806C
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7900LC7
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  5298
   Part No SW: 4H0 959 795 M    HW: 4H0 959 795 J
   Component: TSG HL        H03 0303
   Revision: --------    Serial number: 0000064916725
   Coding: 011817200000253005080000
   VCID: 45D7501F55A3A0FFEDB-8010
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000098946
   ROD: EV_RDKBERU25_VW52.rod
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H07000    Serial number: 525 PA8J360647
   Coding: 0100001
   VCID: 372B2AD7134FC26F6F7-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 148301485
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0303
   Revision: --------    Serial number: 0000064585907
End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.2V)-----------
