Jpnankervis
New Member
Hi
Im breaking my brain over the amount of codes my Skoda Octavia VRS 2.0 TFSI has, specially regarding voltage.
Below are the codes. I just replaced the battery, with a new and more powerfull if you could call it. So I think the issue might have to do with wiring at this point. But I have no idea where to start. Any ideas will help. Codes below are just a couple but the ones Im more interested in fixing. They are all related to electric issues (interminent communication) in the inmobilizer, radio, etc.
Thursday,14,March,2019,18:27:34:06158
VCDS Version: Release 18.9.1 (x64) Running on Windows 10 x64
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1Z0 907 115 D HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0203000318070060
Work Shop Code: WSC 73430 790 00000
VCID: 364DC10C415F73FA37-8062
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached
Fault Status: 01100010
Mileage: 70825 km
Time: 12:46:55
RPM: 6175 /min
Load: 58.8 %
Speed: 87.0 km/h
Temperature: 90.0°C
Temperature: 32.0°C
Absolute Pres.: 750.0 mbar
Voltage: 13.970 V
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Mileage: 70890 km
Time: 18:25:25
RPM: 5850 /min
Load: 61.9 %
Speed: 157.0 km/h
Temperature: 89.0°C
Temperature: 35.0°C
Voltage: 13.716 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
Mileage: 71186 km
Time: 13:28:41
RPM: 1349 /min
Load: 25.5 %
Speed: 12.0 km/h
Temperature: 90.0°C
Temperature: 39.0°C
Voltage: 13.970 V
Readiness: 0000 0001
Thursday,14,March,2019,18:29:26:06158
Control Module Part Number: 1K0 909 605 T HW: 1K0 909 605 T
Component and/or Version: Q1 AIRBAG VW8 020 2300
Software Coding: 0020785
VCID: 3D5FDE206469A0A2F6-8068
00532 - Supply Voltage B+
