Saturday,09,March,2019,09:16:03:52357
VCDS Version: 18.9.1.0
VIN: WAUZZZ4MXGD005091 License Plate: 2AG-0208
Mileage: 44096km-27399mi Repair Order:
Chassis Type 4M-AU73 (4M1)
Scan: 01 02 03 06 08 09 15 16 17 19 28 36 42 44 46 47 50 52 5F 6C
6D 81 A5 AC BB BC CA
VIN: WAUZZZ4MXGD005091 Mileage: 44096km-27399miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
50-Seat Adj. 3rd row -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRTC) Labels: Redir Fail!
Part No SW: 4M0 907 401 HW: 059 907 309 B
Component: 3.0TDI EDC17 H45 0004
Revision: 91H45---
Coding: 2A2A40320326050334180000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114M0907401 001008
ROD: EV_ECM30TDI0114M0907401.rod
VCID: 66C38BED99AB487A47-8032
5132 - Valve for Fuel Metering (N290)
P0090 00 [175] - Open Circuit
Date: 2047.15.31
Time: 31:63:63
Coolant temperature: 30 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.360 V
Engine status: COENG_READY
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4M0 927 158 J HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H03 1007
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002009
ROD: EV_TCMALX52011.rod
VCID: 3B750A99B2A92592C8-806E
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 K HW: 4M0 907 379 K
Component: ESP9 Premium H08 0521
Coding: 249830B230A20A9B969E589A007E5292E6A6D2240C0C50691A004A4967654B
Shop #: WSC 12480 002 1048576
ASAM Dataset: EV_ESP9BOSCHAU736 011006
ROD: EV_ESP9BOSCHAU736_AU73.rod
VCID: 3F8D7E89A6B139B2E4-806A
261632 - Brake Boost Vacuum too Low
P050F 00 [040] - -
Mileage: 44087 km
Date: 2019.02.20
Time: 10:45:36
98 40 00 00 CA 24 00 00 00 00
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M0 959 760 E HW: 4M0 959 760 E
Component: MEM-BFS 008 0014
Serial number: 00000149535907
Coding: 000010000000B0410000210101010000110000313100000000000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 3A7B0F9DBD931C9AD3-806E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 K HW: 4M0 820 043 K
Component: Klima Zone 4 H52 0060
Coding: 6618083C5544401102220180800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 2D5134C17CDDBB2246-8078
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000332306
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: 6B28C9A7000000000001
328050 - Motor for Right Side Vent Flap
B10CA 21 [008] - Signal Amplitude Too Low
Reset counter: 49
Mileage: 44091 km
Date: 2019.03.01
Time: 08:17:41
Right side vent flap motor: spec. value: 9699
Right side vent flap motor: actual value: 11789
System run time-Engine running time: 62 s
System run time-Terminal 15 on: 64 s
Right side vent flap motor: diagnostic-Last operating state: No routine started
Right side vent flap motor: diagnostic-Operating condition: Verification drive 2
Voltage terminal 30: 14.13 V
Outside air temperature: 28.00 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 G HW: 8W0 907 063 G
Component: BCM1 MLBevo H12 0215
Coding: 07501943E16900CD010D5719582F0CF913033101900000000000000060001A810A4501A222B60A
ASAM Dataset: EV_BCM1BOSCHAU736 014003
ROD: EV_BCM1BOSCHAU736_014.rod
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 150324 042 0792
Serial number: 150415210836
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 20298114
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
Component: E1 - LDS H05 0007
Serial number: 19 05 2015 00024107
Subsystem 4 - Part No SW: 4M0 857 511 A HW: 4M0 857 511 A
Component: Y7_Innenspieg H08 0002
Serial number: GX1CE127041511520013
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 AB HW: 4M0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00012441
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 4M0 907 705 HW: 4M0 907 705
Component: J866-EVLS-SG H03 0040
Serial number: WA120676000013215516
Coding: 020100
Subsystem 7 - Part No SW: 4M0 925 301 B HW: 4M0 925 301 B
Component: SL-Q7NF/AU736 H09 0006
Serial number: 00000000000000004675
196898 - Databus
Fault Frequency: 19
Reset counter: 9
Mileage: 44091 km
Date: 2019.03.01
Time: 08:16:40
average_Voltage_terminals: 11.60 V
Outside air temperature sensor-Resistance: 232.96 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 27.50 °C
interior_temperature: 19918.00 °C
Vehicle speed: 0.00 km/h
Address 15: Airbags (J234) Labels:* None
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H50 0084
Serial number: 003L100066ZT
Coding: AACCF0D80C80000058F650F3C00C00000000
Shop #: WSC 12461 002 1048576
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 78FFD595C31FCE8AE5-802C
Subsystem 1 - Part No SW: ----------- HW: 442 062 305 15
Serial number: 3577Y009F193B854C29F
Subsystem 2 - Part No SW: ----------- HW: 442 062 305 15
Serial number: 3587Y009F193B8553333
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 405 15
Component: SideSensor_Dr 1C7 0148
Serial number: 35177000229352E98696
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 405 15
Serial number: 35277000429352E6960+
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 405 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B51B50DF0E1ET
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 405 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B51B50DF0628H
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 405 15
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B71B9D75461CI
Subsystem 8 - Part No SW: ----------- HW: 442 420 805 15
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00B5193B851623E
Subsystem 9 - Part No SW: ----------- HW: 442 420 805 15
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00B5193B85202AH
Central Sensor XY:
Subsystem 10 - Part No SW: ----------- HW: 410 201 505 15
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800A91656925018X
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HD HW: 4M0 907 129 HD
Component: Lenks.Modul H11 0008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 79F9D091F815D7829A-802C
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 790 HW: 4M0 920 790
Component: FBenRDW H12 0280
Coding: 042401C0289000080323E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001020
VCID: 6CD7F9C58747722A11-8038
Part No SW: 4M1 907 468 A HW: 4M1 907 468 A
Component: Gateway H13 4079
Revision: 3B010050 Serial number: 5043B010B15508
Coding: 0301000100000F407F07000000590032C8120007008000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002_AU73.rod
VCID: 35611CA1948DF3E23E-8060
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20150515203003 RD103
Subsystem 2 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9041
Serial number: 4945706503
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4M0 919 158 C HW: 4M0 919 158 C
Component: Klima Zone 2 H52 0060
Coding: 000000000000000100820080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 008 0014
Serial number: 00000149536845
Coding: 00181B000000B0410000210101010000110000313100000000000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 593 G HW: 4M0 959 593 C
Component: TSG FS 005 0052
Serial number: 0000151362417
Coding: 005D9B005E00000000013080
VCID: 408F7D75DB4F464A9D-8014
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0005
Serial number: 0000482458
Coding: 90110001000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 346721A59FF7EAEA09-8060
Address 46: Central Conv.
Interface not compatible.
Address 47: Sound System (J525) Labels:* None
Part No SW: 4M0 035 223 A HW: 4M0 035 223
Component: MIB2_amp_PD H02 0420
Serial number: 00000000003695
Coding: 0135060A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 2149D8F130056F42F2-8074
Address 50: Seat Adj. 3rd row
Part No SW: 4M0 959 592 D HW: 4M0 959 592 C
Component: TSG BFS 005 0036
Serial number: 0000150331163
Coding: 005D9B005E00040000013080
VCID: 3C770985B7A722AAC1-8068
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 036 B HW: 4M0 035 036
Component: MU-P-LN-EU 041 0358
Serial number: A288E0FB001785
Coding: 013706010000000013110002000A00102F001BE501700100DE
VCID: 2447D1E52F177A6A99-8070
Subsystem 1 - Part No SW: V03 959 802 CA HW: -----------
Component: ECE 2015 --- 0118
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9FJ4006KX
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 D HW: 4M0 919 615 D
Component: ControlUnit_P H14 0165
Serial number: 21051500000000000108
Component: Gracenote2 --- 1010
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 HW: 4M0 907 428
Component: Areaview 2 H11 0282
Serial number: C854606JG000338
Coding: 02370601AE0FA10000404044
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 003013
ROD: EV_CamSysRVAV2CE2MLBEv_003.rod
VCID: 6FEDEEC9B651893234-803A
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 HW: 4M0 959 107
Component: HDSG-Modul H12 0143
Revision: -------- Serial number: 30018632900000
Coding: 0070
ASAM Dataset: EV_DeckLidCONTIAU736 001010
VCID: 70EFEDB5AB6F96CA2D-8024
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 D HW: 4M1 713 041 D
Component: GSM-LL H07 0066
Revision: 0L0D5012 Serial number: 20150518000064
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU73.rod
VCID: 2643CBED592B887A87-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 B
Component: BVS H11 0042
Coding: 0407030600000401022023A0C50000B400F0C020C020
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: 2F6D2EC976D1C93274-807A
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0006
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736.rod
VCID: 326B27BD65E3E4DA1B-8066
Part No SW: 4M0 959 595 D HW: 4M0 959 595 C
Component: TSG HFS 005 0036
Serial number: 0000148509254
Coding: 004D99000000040000003080
ROD: EV_DCU2RearDriveMAXHCONT.rod
Component: TSG HBFS 005 0036
Serial number: 0000150349833
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof
End-------------------------(Elapsed Time: 06:16)--------------------------
