Octavia III facelift virtual cockpit 5E0920790A needle sweep
adejme
Slovakia
C?ID=356622
Hello , i have octavia III facelift retrofitted virtual cockpit 5E0920790A needle sweep is possible or no ? thanks
icardiag
Europe
C?ID=113031
No it's not possible.
Spacewalker
Poland
C?ID=159607
did you try via coding ?
not available in coding ?
Needle sweep is useful on a cluster with physical needles because it shows that the motors and needles are not mechanically jammed up somehow.
But I don't think there is any point at all to it on a virtual cluster, so I'm not sure why anyone would bother implementing it in the cluster's software.
golfi_vend
Tartu, Estonia
C?ID=195131
It's just visual "thing".
AID-Entry usually doesn't support this. Like Leon VC and same on Skoda. Arteon, B8 and similar clusters support this.
DV52
C?ID=194404
golfi_vend: No offense intended, but galvanized into action by the comments here I tried changing the software switch on the instrument control module on my A3 8V (it's Byte 1, Bit 0 and it's called "staging" in the yellow long coding helper screen). After setting the Bit to "yes" - it does actually work on the virtual display. Details of the module as follows:
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
   Component: FBenRDW       H16 0066
   Coding: 248409506F8800080180EA001000000000000000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3A38F780BD1E31942A-806E
Of course, Uwe's pertinent question about why-bother is a far more interesting issue -a discussion for Uwe's Bar, I suspect
