Results 1 to 8 of 8
Thread: BCM Coding all Zeros
    Verified VCDS-User
    Mar 2019
    malaysia
    any of you face this issue ? i am using Hex-net pro
    coding is not supported by this control module variant
    replacement control module must be parameterized by using
    the factory tools and software version manager
    https://imgur.com/2nKiEJE
    A full AUto-Scan will help to put the error in context...
    Verified VCDS-User
    Mar 2019
    malaysia
    Tuesday,12,March,2019,21:20:43:63906
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
    VIN: WAUZZZ8V6H1018992   License Plate:
    Mileage: 47024km-29219mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V6H1018992   Mileage: 47024km-29219miles
    Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 AB    HW: 04C 907 309 AE
       Component: R3 1.0l TFS   H25 3494
       Revision: W1H25---
       Coding: 02250032232401083000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
       ROD: EV_ECM10TFS_VW37.rod
       VCID: 618AADCE70B00842B2-8034
       CAN Converter 01:
       Part No SW: 0CW 300 049 M    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0902
       Revision: 00005026    Serial number: CU501608145951
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 47DE5356FE5456725C-8012
       Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
       Component: ESC           H62 0642
       Revision: 00000000    Serial number: 62206000000379
       Coding: 13F18AA22421127489800E0980C525C8512448917001A472022100040208420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
       VCID: 014A8D4E90F0A842D2-8054
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0414425164
       Coding: 030C0C
       VCID: 3B363FA6B29C0292C8-806E
       Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
       Component: AC Automat    H03 0110
       Revision: 20001000    Serial number: 00000001020885
       Coding: 03100003110000001000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
       VCID: 3C343CBAB79205AAC1-8068
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: A7A8044800PAG0MUFU03
    590082 - Control Circuit for A/C Compressor
              B10A9 15 [008] - Open or Short to Plus
                        Reset counter: 16
                        Compressor shut-off requirement: Engine running time too short: engine start not detected by CAN
                        Compressor current: specified value: 0.000 A
                        Voltage terminal 30: 12.1 V
                        Outside air temperature: 40 °C
                        Engine speed: Measured value not available
       Serial number: 02001623201269
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EB0F6B2E10ED7BAAF-802A
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS371 160717  043 0585
       Serial number:         160727145509
       Coding: 0A47F7
       Serial number: 62174594
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Serial number: 25 05 2016  00001162
       Part No SW: 5QA 919 283     HW: 5QA 919 283
       Component: PDC 4 KanalH07 0031
       Serial number: 000308419616217
       Coding: 0700040011
       ASAM Dataset: EV_EPHVA14AU3700000 009027
       ROD: EV_EPHVA14AU3700000.rod
       VCID: 075E9356BED496729C-8052
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR23ELZI
       Coding: 98CCC000000000005C54000000C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 106CB80ACB9AD1CA4D-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 001 908 16
       Serial number: 357000000000EAB08D1T
       Subsystem 2 - Part No SW: -----------    HW: 480 001 908 16
       Serial number: 35800000000D7031CD1N
       Subsystem 3 - Part No SW: -----------    HW: 480 402 208 16
       Serial number: 35100019B20F2B25F354
       Subsystem 4 - Part No SW: -----------    HW: 480 402 208 16
       Serial number: 35200019B20F2B2422C/
       Subsystem 5 - Part No SW: -----------    HW: 480 400 408 16
       Serial number: 3550002B521FBE81D05F
       Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 20081604400272
       Coding: A018
       VCID: 0D52A17EDCA8FC22A6-8058
       Part No SW: 8V0 920 872 N    HW: 8V0 920 872 N
       Component: KOMBI         H04 8316
       Coding: 27A41A182A8000080100A8001001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 48DC506AF34A590A55-801C
       Revision: --------    Serial number: 20081610801387
       Coding: 030100043F0857005B000248100B00000001010000000000000000000000
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 7CB4FCBAF712C5AA81-8028
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0003
       Serial number: 20160824074456 20155
       Serial number: 75410803001608174846
    8531970 - Quiescent Current
              U1406 00 [008] - Too High
              [Ruhestrom oberer Grenzwert überschritten]
                        Fault Frequency: 173
                        Reset counter: 15
                        Mileage: 29847 km
                        Date: 2018.06.22
                        Time: 01:09:46
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
       Revision: 00000000    Serial number: 16000140221002
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424149A9FC2CDEA09-8060
       Serial number: 080816EH709593
       Coding: 001C1B205C01040000001002
       VCID: 43C64746CA6C7A5280-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45C2595EC4584462AE-8010
       Serial number: 050816EH514021
       Coding: 001C13205E01040000001002
       VCID: 42C84242D576735A8B-8016
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0ECE00102B200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E3036B2A18E17BAEF-806A
       Part No SW: 81A 035 824     HW: 81A 035 824
       Component: MU-S--ER      710 0740
       Coding: 01730100FF00000011110001000A00002F0024060170010002
       ASAM Dataset: EV_MUStd6C3DELP 001013
       ROD: EV_MUStd6C3DELP_AU37.rod
       VCID: 608CA8CA7BBA014ABD-8034
       Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY20722V
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 BB    HW: 8V0 919 614 BB
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL106051600020209
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 210716EGK0758A
       Coding: 000C13204001040000001002
       Serial number: 210716EGK07587
    End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.0V)-----------
    Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27A41A182A8000080100A8001001000000000000,to,27AC1A182A8000080100AA001001000000000000,(06385/790/00016),
    Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A182A8000080100AA001001000000000000,to,27AC1A182A8000080101AA001001000000000000,(06385/790/00016),
    Address 09,5Q0 937 084 CF,channel IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,adapted from,not active ,to,active ,
    Address 09,5Q0 937 084 CF,channel IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,adapted from,active ,to,not active ,
    Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A182A8000080101AA001001000000000000,to,27AC1A982A8000080101AA001001000000000000,(06385/790/00016),
    Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A982A8000080101AA001001000000000000,to,27AC1A182A8000080101AA001001000000000000,(06385/790/00016),
    Address 09,5Q0 937 084 CF,channel ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,adapted from,not active ,to,active ,
    Address 09,5Q0 937 084 CF,channel IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,adapted from,not active ,to,active ,
    Address 09,5Q0 937 084 CF,channel IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,adapted from,not active ,to,active ,
    Address 09,,channel IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,adapted from,not active ,to,active ,
    Address 17,8V0 920 872 N,recoded (Long Coding-exp),from,27AC1A182A8000080101AA001001000000000000,to,27AD1A182A8000080101AA001001000000000000,(06385/790/00016),
    Address 09,5Q0 937 084 CF,channel ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,adapted from,not active ,to,active ,
    Verified VCDS-User
    Mar 2019
    malaysia
    even after clear error log , i also cant managed to get into , it is an Audi A3 8v 1.0 FL
    That's a newer style MQB BCM, where everything that used to be in Coding has moved to Adaptation channels.
    PS: Thread subject changed because there is no "Error" here.
  6. Likes TBAx, PetrolDave liked this post
    Dec 2016
    DE
    Everything what was in coding in earlier version MQB BCM has moved to adaptions now.
    If you have issues finding the specific bit, please let us know, what you want to change.
  8. Likes Uwe liked this post
    Verified VCDS-User
    Mar 2019
    malaysia
    Omg last MQB is much more easier just 1 tick, now will need to go thru adaptation channels
  10. #8
    Verified VCDS-User
    Mar 2019
    malaysia
    I think I managed to find after a long way today
    1] needle sweep
    2] drl option to on off
    3] wiper mode
    4] rs3 startup instrument cluster
    5] oil temperature
    6]lock n unlock with horn sound
    7] seat belt chime off
    8]laptimer
    Unable to find signal indication change to 4 or 5 sec, mmi screen rs3 logo
    Enable tmps
