Results 11 to 20 of 27
Thread: Adv. Measuring values logging issue
    Nov 2018
    Just happened to have scanned the ECU ID on Friday...
    Friday,15,March,2019,20:32:32:27520
    VCDS Version: Release 18.9.1 (x64)
    Address 01: Engine
    Control Module Part Number: 8T2 907 560 F
    Component and/or Version: 4.2l JHM.9X/ H04 0005
    Software Coding: 1A25003225C6080D3000
    Work Shop Code: WSC 00000
    VCID: 3FDBBD3337FB04FFA77-806A
    Advanced Identification/FAZIT
    Identification: BPG-810
    Revision: NAH04---
    Date: 14.02.13
    Manufacturer number: 1328
    Test stand number: 0017
    Flash Status
    Programming Attempts(application): 0/0/0/0/0
    Successful Attempts(application): 0/0/0/0/0
    Flash Date: 00.00.00
    Misc.
    Hardware number: 8T1 907 560
    Workshop System Name: -----
    ASAM Dataset: EV_ECM42FSI0118T2907560F
    ASAM Dataset Revision: 001004
    Car Info
    Chassis Number: WUAC6AFR6DA902467
    Engine code: CFSA
    VCDS Info:
    Labels: 079-907-560-CFS.clb
    Readiness: No script available
    ROD: EV_ECM42FSI0118T2907560F.rod
  2. #12
    So the data type for IDE00565 in EV_ECM42FSI0118T2907560F is "OBD", and it corresponds to PID PID 52/0x34, which calls for the display of "Fuel–Air Equivalence Ratio (lambda) and Oxygen Sensor Current".
    See chart here:
    https://en.wikipedia.org/wiki/OBD-II_PIDs#Service_01
    I'm not sure why older versions didn't show the current. I've checked previous versions back to to DS251 and the data type has not changed. Eric has also looked at the VCDS source and hasn't found any relevant changes. So the only thing we can think of is that your ECU's ASAM ID may have changed between the 0002 software version you had in the first log that you posted and the 0005 version in the second log that you posted. Do you have any scans that show your ECU's ASAM ID with the 0002 software in it?
    If you'd like to split the two values into separate columns, I'd suggest a find & replace in that column, to replace the slash with a comma.
  3. Likes Eric, Dana liked this post
  4. #13
    Nov 2018
    I'll look as I have more than a few scans saved. And thanks for the tip. Can't stand excel but I'm sure I can figure how to do a find and replace.
  5. #14
    Nov 2018
    Here's an old one.
    Thursday,11,January,2018,21:43:56:27520
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
    VIN: WUAC6AFR6DA902467   License Plate:
    Mileage: 63530km-39475mi   Repair Order:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
              52 53 56 5F 6C
    VIN: WUAC6AFR6DA902467   Mileage: 63530km-39475miles
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560 B    HW: 8T1 907 560
       Component: 4.2l V8HDZ /  H04 0004
       Revision: NAH04---
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM42FSI0118T2907560B 001005
       ROD: EV_ECM42FSI0118T2907560B.rod
       VCID: 3B23C92323E318DF4F3-806E
       Part No SW: 8T0 927 156 F    HW: 0B5 927 156 J
       Component: 0B5 42 FSINAR H01 0008
       Revision: --H01---
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001012
       ROD: EV_TCMDL501021.rod
       VCID: 40D9BECF4A057B071A1-8014
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Component: ESP8 quattro  H09 0100
       Coding: 302D1A
       VCID: 45D7AFDB55A75E2F297-8010
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Coding: 0D804000000000000000
       VCID: 045172DF1E1DA7277E9-8050
       Serial number: 2313000016339008
    Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000051213831
       Coding: 00037025002C00000000
       Shop #: WSC 06342 000 00000
       Revision: C1000000    Serial number: 01200220130492
       Coding: 4802200000
       VCID: 392FD32B295F2ACF5DF-806C
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000554864301
       Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
       Shop #: WSC 92630 444 123950
       VCID: 7AAD0C276CD9E1D7145-802E
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150213  H15 0080
       Serial number: SWF13020150148
       Coding: 00FD11
       Serial number: 21004112
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000502130647
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R4SYJ02
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 7C48C296000000000001
       Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
       Component: ACC3          H11 0100
       Coding: 00333E
       VCID: 323DE407F429D9979C5-8066
       Serial number: 003KJD91EW3S
       Coding: 303343334830303030304A55304C38543053
       VCID: 4ACD9CE77C39B157C45-801E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R130000CJ7S
       Serial number: 6334MSME780331656
       Serial number: 6344MSME78406157C
       Serial number: 6352QSME62282B44G
       Serial number: 6362QSME5F2C5372T
       Serial number: 63732SME712B0F585
       Serial number: 63832SME542B2F444
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20130219001040
       Coding: 00003E
       VCID: 51FF8B8B91EF828F85F-8004
       Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
       Revision: 00300000    Serial number: UVA266K2E
       Coding: 83BF0100AF03D705020000
       VCID: 3D27C73B3D7716EF717-8068
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z13204008E
       Coding: 80E3031600
       VCID: 4CC19AFF76CDAF67F69-8018
       Serial number: 1367620003
       Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
       Component: DYNAMIKLENK.  H06 0690
       Coding: 030000
       VCID: 3635D8171841C5B7B0D-8062
       Component: 4 Wheel Drive H14 0100
       Serial number: 001302130001758
       VCID: 2F3BED73E79BF47FF3B-807A
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000051211560
       Coding: 001B7B25002C00000000
       Shop #: WSC 11251 001 1048576
    03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                        Fault Status: 01100101
                        Reset counter: 34
                        Mileage: 59658 km
                        Date: 2017.10.26
                        Time: 22:55:48
    03321 - Switch for Height Adjustment: Down
                        Fault Status: 00100011
                        Reset counter: 223
                        Mileage: 63390 km
                        Date: 2018.01.08
                        Time: 14:07:49
    03325 - Switch for Backrest Angle Adjustment: Back
                        Reset counter: 223
                        Mileage: 63390 km
                        Date: 2018.01.08
                        Time: 14:07:49
       Component: SWA Master    H04 0060
       Serial number: 0192285845
       Coding: 010211
       Shop #: WSC 06324 000 00000
       VCID: 3FDBBD3337FB04FF63B-806A
       Component: SWA Slave  H04 0060
       Serial number: 0192294703
       Coding: 000102
    733696 - Control Module 2 for Lane-Change Assist
              C1115 F5 [008] - Limited Visibility
                        Mileage: 61628 km
                        Date: 2017.12.07
                        Time: 17:51:39
       Component: TSG FA        H09 0304
       Coding: 011C13224E00120102
       VCID: 56F57897B801E5B750D-8002
       Revision: 00001000    Serial number: 0012646993
       Coding: 010000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3431E21F0EBDD7A78E9-8060
       Revision: 00002001    Serial number: 0301332569
       Coding: 0106069A00FAC10581B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000634856
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0028
       Serial number: WA104645000002650945
       Revision: 00005001    Serial number: 94813011143102
       VCID: 2D07F77BED17866FC17-8078
       Component: TSG BF        H09 0304
       VCID: 55F77F9BA507EEAF597-8000
       Revision: --------    Serial number: 20000000227161
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3829D62F12D533C7A21-806C
       Part No SW: 4G0 035 082 E    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 156B50D7693479
       Coding: 020007010000000001
       VCID: 221D1447A4C949176C5-8076
       Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 0624
       Revision: --------    Serial number: 204BT0D7561283
       Coding: 150200020306A9EF75028B4E00000403140000000000000000
       VCID: 372BD5131F4B3CBFABB-8062
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H42 0104
       Serial number: A130BX0D2659970
       Serial number: 00000001419689
       Component: CD-Database  4949
       Revision: --H07---    Serial number: 525PA8-J2Z91FG
       Coding: 1021008
       VCID: 3829D62F1E5533C7A21-806C
    End----------(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.0V)-----------
  6. #15
    Quote Originally Posted by Ape Factory View Post
    Here's an old one.
    [code]
    Revision: NAH04---
    Well, that's not the 0002 software in your first log, but it solves the mystery anway.
    Your ECU software part number has changed, and so has the ASAM identifier.
    And guess what, that older ECU software had two separate values that could be logged:
    IDE00565-MAS04135 --0 Current of oxygen sensor bank 2 sensor 1 (broadband sensor) - Oxygen sensor value,LINEAR,lambda
    and
    IDE00565-MAS04136 -- Current of oxygen sensor bank 2 sensor 1 (broadband sensor) - Current,LINEAR,mA
    Whereas your new ECU software only has:
    IDE00565-ENG167462 -- Current of oxygen sensor bank 2 sensor 1 (broadband sensor),OBD,
    So the difference is in the software in your ECU, as opposed to something that has changed in VCDS.
  7. Likes Eric, PetrolDave liked this post
  8. #16
    Nov 2018
    Huh, I checked with the calibration engineer just to make sure and he states nothing was changed in the communication with the com lines. I'll double check with him.
    Also, is there any way to have the logging function automatically change the file name each and every time? I did a bunch of logging only to have it all overwritten as the same file name is being chosen by the software. I'm logging completely different parameters but it's the same name each and every time regardless. When working quickly, this would be a huge benefit.
    Another suggestion is when you save a group of logging parameters that it also saves the "turbo" mode option as well as the UDS grouping/time stamp if checked when saving a group of parameters.
    It's extremely tough to work quickly with the VCDS logging feature when you're constantly having to change one character or having to check a bunch of small boxes. Automation is your friend.
  9. #17
    There's nothing to double check. The software part number of your ECU changed, as did its ASAM identifier. It's all there in black and white.
    I'm a bit puzzled why that would happen if you're logging "completely different parameters". Also, I don't think logs ever get overwritten; if the same file name is used, new data should be appended to the existing data in the file.
    That's not a bad idea.
  10. #18
    Nov 2018
    I would literally jump with joy if that could be implemented. The interface aspect and logistics of logging, as it now stands, are tedious and it makes it hard when you're using a small, lightweight laptop like I am. Battery lasts forever and it's cheap, so it makes a good VCDS-only tool. But it's also super hard to see anything when it's in the seat next to you and as mentioned, tedious to get everything right.
    It's so easy to forget to check or uncheck one box, to rename the file, etc... I literally overwrote a ton of really valuable data today due to the fact it doesn't automatically rename a file or at least warn you the data is being overwritten.
    In addition, I'd suggest, from a graphics point of view, to make the "buttons" or boxes bigger. Heck, make the whole logging window larger or even make it expandable to full screen mode. If looking at the computer, in the car, there are times where I can't even see if it says start or stop. Big buttons with larger text would be super helpful from an interface standpoint.
    Appreciate you're receptive to this!
  11. #19
    Again, I do not think logs are ever overwritten; if the file name is the same, new data gets appended to an existing file.
    Have you adjusted the Window Size here?
  12. Likes PetrolDave liked this post
  13. #20
    Nov 2018
    Ah didn't realize you could do that! I'll try that for the window size.
    As for the files being overwritten, I'm closing out each log. So if I'm logging the transmission, I'll do that, stop it, close it out and open the ECU and then log. Same file name but totally different parameters being logged.
    Now if I'm logging the same parameters over again, and I hit resume, yes, it's being appended. But I checked my files and only one log appeared when I had recorded six different logs previously. If the coding saved each file via the date and time, that would prevent files from being overwritten.
