Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Adv. Measuring values logging issue
    Nov 2018
    Currently using VCDS v18.9.1 and I use a program called MegaLog Viewer HD (unfortunate name I know) to view and graph the logged data. I've noticed since switching to the latest VCDS version that when I group them together I'm getting multiple time stamps in the file, one for each parameter I've chosen to log. Prior to the update, there'd be one time stamp followed by the eight parameters I was logging (turbo mode).
    In addition, when I log the pre-cat wideband 02 (lambda), I'm getting lambda as well as voltage now, separated by a backslash (/). I can no longer graph that parameter through the MegaLog Viewer since there are two measuring values where there should be one.
    I would, prior to the update, be able to select all eight parameters I recorded to the .csv file through the viewer to graph but now only first four appear. The viewer has a pull-down menu for up to four parameters in one graph. You can stack multiple graphs so you have four parameters in one, four in the second one directly below. Now I get four parameters period and no option to view the other four that are in the file. Not sure if it has something to do with the time stamp appearing eight times.
    Anyone know if changes were made to the logging function or am I perhaps seeing an issue created by the log viewer?
    I'm using a Hex V2 cable.
    Thanks in advance!
    Nov 2018
    I went back and looked at one of my older logs through Excel and the multiple time stamps are there but the lambda value features the lambda value only, not the voltage reading. I'm able to see the data for all eight recorded parameters. In the later version, I'm unable to see more than four through the log viewer program even though there are eight in the file, viewable in Excel.
    Please post some sample logs illustrating the difference.
    Nov 2018
    My apologies for the super late reply, working on a number of little projects and forgot to post two logs up. I can't attach actual logs so I did a screen grab of them both in excel.
    Here's one from September that MegaLog Viewer can read no problem. I'm looking at blocks G096 and G100. Both show the current of the oxygen sensor but NOT lambda. I captured the VCDS build number at the top but here it is again: Monday 17 September 2018 13:18:00:27520-VCID:3B23C92323E318DF646-806E VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.2
    In the second, more recent log, the voltage and lambda are displayed. The blocks are now G100 and G103. I forgot to capture the build so it's copied and pasted here: Saturday 23 February 2019 15:01:07:27520-VCID:3FDBBD3337FB04FFA77-806A VCDS Version: Release 18.9.1 (x64) Data version: 20190114 DS296.0
    Not sure if this is an actual change or if I've perhaps inadvertently clicked something causing the changes listed above.
    Quote Originally Posted by Ape Factory View Post
    You can certainly copy and paste the CSV data into a post (preferably between [code] and [/code] tags.
    However, since these two files are not from of the exact same measuring values, you're asking to compare apples and oranges here. I would recommend loging the exact same data as in a file that MegaLog Viewer HD previously had no problems with.
  6. #6
    Nov 2018
    That's just it...I'm selecting the same thing to monitor. Specifically, the current of the wideband oxygen sensor pre-cat. The only difference is now it's showing lambda/voltage instead of just voltage with the update. I'm assuming, when you select a parameter to monitor, the VCDS is choosing to name that parameter. If you look at both, I have G100 in each log yet the data is different in that one includes the lambda and one does not. And 096 is the same as 103 in the newer version.
    Anyway, the log viewer I use can't parse the data when it's presented as lambda/voltage. That's my main issue. I can't even select it since it doesn't read the data from the log at all.
  7. #7
    OK, I see it now.
    Do you have a scans from this car so we can see what the ASAM IDs are, and what ROD files VCDS is using?
  8. #8
    Nov 2018
    I can do that. Want me to take a complete snapshot and post it? It'd be great to have just lambda separately from voltage as I can convert that to air/fuel and graph it easily.
  9. #9
    Maybe, but if what VCDS is showing/logging here for those measuring values matches what the factory software shows, then we're not going to change it.
    In the meanwhile, we need the ECU ID data to investigate.
  10. #10
    Nov 2018
    Here's a full scan. I'll do another post with the ECU ID.
    Wednesday,20,March,2019,13:29:09:27520
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WUAC6AFR6DA902467   License Plate:
    Mileage: 89540km-55637mi   Repair Order:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
              52 53 56 5F 6C
    VIN: WUAC6AFR6DA902467   Mileage: 89540km-55637miles
    1B-Active Steering -- Status: Malfunction 0010
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560 F    HW: 8T1 907 560
       Component: 4.2l JHM.B /  H04 0005
       Revision: NAH04---
       Coding: 1A25003225C6080D3000
       ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
       ROD: EV_ECM42FSI0118T2907560F.rod
       VCID: 3FDBBD3337FB04FFA77-806A
    4327 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:16:01
                        Coolant temperature: 51 ∞C
                        Intake air temperature: 46 ∞C
                        Voltage terminal 30: 12.415 V
                        AFS dm: 0.0 kg/h
                        Median injection timing: 0.000 ms
    Readiness: 1110 0101
       Part No SW: 8T0 927 156 F    HW: 0B5 927 156 J
       Component: 0B5 42 FSINAR H01 0008
       Revision: --H01---
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001012
       ROD: EV_TCMDL501021.rod
       VCID: 40D9BECF4A057B07DED-8014
    18147 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [032] - -
                        Reset counter: 40
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
                        Engine speed: 0 /min
                        Transmission input speed: 0 /min
                        Engine torque: -64 Nm
                        Transmission fluid temperature: 55 ∞C
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
                        Voltage terminal 30: 12.500 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.901 V
    8008 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [032] - -
                        Reset counter: 40
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
                        Voltage terminal 30: 12.600 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.899 V
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Component: ESP8 quattro  H09 0100
       Coding: 302D1A
       VCID: 45D7AFDB55A75E2FEDB-8010
                        Reset counter: 4
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x000E
                        Hex Value: 0x809B
                        Hex Value: 0x0000
                        Fault Status: 00101101
                        Reset counter: 6
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x001C
                        Hex Value: 0x029B
                        Hex Value: 0x0000
    01324 - Control Module for All Wheel Drive (J492)
                        Reset counter: 6
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x000F
                        Hex Value: 0x509B
                        Hex Value: 0x0000
                        Reset counter: 6
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x000B
                        Hex Value: 0x939B
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Coding: 0D804000000000000000
       VCID: 045172DF1E1DA727BA5-8050
       Serial number: 2313000016339008
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 220
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:18:44
                        Reset counter: 6
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
    Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000051213831
       Coding: 00037025002C00000000
       Shop #: WSC 06342 000 00000
       Revision: C1000000    Serial number: 01200220130492
       Coding: 4802200000
       VCID: 392FD32B295F2ACF993-806C
                        Fault Status: 01100101
                        Reset counter: 215
                        Mileage: 89309 km
                        Date: 2019.03.15
                        Time: 18:18:02
                        Fault Status: 00100011
                        Fault Frequency: 19
                        Reset counter: 7
                        Mileage: 89309 km
                        Date: 2019.03.15
                        Time: 19:05:04
                        Voltage: 12.30 V
                        Temperature: 19.0∞C
                        Temperature: 21.0∞C
                        Count: 25000
                        Count: 10941
                        Bin. Bits: 01000000
                        Bin. Bits: 10001011
                        Time: 2.55 s
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000554864301
       Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
       Shop #: WSC 92630 444 123950
       VCID: 7AAD0C276CD9E1D7D09-802E
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150213  H15 0080
       Serial number: SWF13020150148
       Coding: 00FD11
       Serial number: 21004112
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000502130647
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R4SYJ02
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 7C48C296000000000001
                        Reset counter: 5
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
       Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
       Component: ACC3          H11 0100
       Coding: 00333E
       VCID: 323DE407F429D997589-8066
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Temperature: 23.0∞C
                        Voltage: 12.42 V
                        Hex Value: 0x0077
                        Lateral Accel.: 0.00 m/s^2
                        Reset counter: 7
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
                        Temperature: 27.0∞C
                        Voltage: 12.54 V
                        Hex Value: 0x00BF
    01316 - ABS Control Module
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Temperature: 23.0∞C
                        Voltage: 12.42 V
                        Hex Value: 0x00C0
       Serial number: 003KJD91EW3S
       Coding: 303343334830303030304A55304C38543053
       VCID: 4ACD9CE77C39B157009-801E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R130000CJ7S
       Serial number: 6334MSME780331656
       Serial number: 6344MSME78406157C
       Serial number: 6352QSME62282B44G
       Serial number: 6362QSME5F2C5372T
       Serial number: 63732SME712B0F585
       Serial number: 63832SME542B2F444
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20130219001040
       Coding: 00003E
       VCID: 51FF8B8B91EF828F413-8004
       Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
       Revision: 00300000    Serial number: UVA266K2E
       Coding: 83BF0100AF03D705020000
       VCID: 3D27C73B3D7716EFB5B-8068
                        Reset counter: 6
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z13204008E
       Coding: 80E3031600
       VCID: 4CC19AFF76CDAF67325-8018
       Serial number: 1367620003
                        Reset counter: 5
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
                        Bin. Bits:    10111
                        Voltage: 12.60 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
                        Bin. Bits:    10111
                        Voltage: 12.60 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
       Component: DYNAMIKLENK.  H06 0690
       Coding: 030000
       VCID: 3635D8171841C5B7741-8062
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Count: 52
                        Count: 1
                        Hex Value: 0x0A35
                        Hex Value: 0x7B02
                        Hex Value: 0x0000
                        Hex Value: 0xF03F
       Component: 4 Wheel Drive H14 0100
       Serial number: 001302130001758
       VCID: 2F3BED73E79BF47F377-807A
    0212 - No Communication with Transmission Control Module
              U0101 00 [008] - -
              [Getriebe - Steuerger‰t keine Kommunikation DTC_CAN_GETRIEBE_NO_COM]
                        Reset counter: 5
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
    0221 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
              [Motorsteuerger‰t keine Kommunikation DTC_CAN_MOTOR_01_NO_COM]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
    0297 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
              [Motorsteuerger‰t keine Kommunikation DTC_CAN_MOTOR_03_NO_COM]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [008] - -
              [ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000051211560
       Coding: 001B7B25002C00000000
       Shop #: WSC 11251 001 1048576
    03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                        Reset counter: 215
                        Mileage: 89309 km
                        Date: 2019.03.15
                        Time: 18:18:01
       Component: SWA Master    H04 0060
       Serial number: 0192285845
       Coding: 010211
       Shop #: WSC 06324 000 00000
       Component: SWA Slave  H04 0060
       Serial number: 0192294703
       Coding: 000102
       Component: TSG FA        H09 0304
       Coding: 011C13224E00120102
       VCID: 56F57897B801E5B7941-8002
       Revision: 00001000    Serial number: 0012646993
       Coding: 010000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3431E21F0EBDD7A74A5-8060
    3158274 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Botschaftsausfall des Motor-Steuerger‰ts]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Write only channel
       Revision: 00002001    Serial number: 0301332569
       Coding: 0106069A00FAC10581B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000634856
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0028
       Serial number: WA104645000002650945
                        Reset counter: 4
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:13
                        Reset counter: 6
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:17
    00230 - Transmission Park Selector Switch (F305)
                        Fault Status: 01101000
                        Reset counter: 222
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:11:18
       Revision: 00005001    Serial number: 94813011143102
       VCID: 2D07F77BED17866F05B-8078
       Component: TSG BF        H09 0304
       VCID: 55F77F9BA507EEAF9DB-8000
       Revision: --------    Serial number: 20000000227161
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3829D62F12D533C766D-806C
    334080 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_02_MESSAGE_TIMEOUT]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Voltage terminal 30: 12.7 V
                        Internal Fault ID: 51
                        Network management state: normal
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
    329728 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_GETRIEBE_03_MESSAGE_TIMEOUT]
                        Reset counter: 5
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:12
                        Voltage terminal 30: 12.6 V
                        Internal Fault ID: 94
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    329984 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_GETRIEBE_04_MESSAGE_TIMEOUT]
                        Reset counter: 5
                        Mileage: 89499 km
                        Date: 2019.03.18
                        Time: 23:21:12
                        Internal Fault ID: 95
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331264 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_01_MESSAGE_TIMEOUT]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Internal Fault ID: 99
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331520 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_03_MESSAGE_TIMEOUT]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Internal Fault ID: 100
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331776 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:16
                        Internal Fault ID: 101
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156B50D7693479
       Coding: 020007010000000001
       VCID: 25170F5BB5E7BE2FCDB-8070
                000 -  -  - Intermittent
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:21
                        Bin. Bits: 00000000 00001000
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 1040
       Revision: --------    Serial number: 204BT0D7561283
       Coding: 150200020306A9EF75028B4E00000403140000000000000000
       VCID: 3FDBBD33377B04FFA77-806A
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H42 0104
       Serial number: A130BX0D2659970
       Serial number: 00000001419689
       Component: CD-Database  4949
                000 -  -
                        Reset counter: 215
                        Mileage: 89309 km
                        Date: 2019.03.15
                        Time: 18:18:41
                        Text: DUA130,Front,M,0,0,6
                        Reset counter: 7
                        Mileage: 89549 km
                        Date: 2019.03.19
                        Time: 23:10:27
                        Bin. Bits: 00010000 00000000
                        Bin. Bits: 00000000 00010000
       Revision: --H07---    Serial number: 525PA8-J2Z91FG
       Coding: 1021008
       VCID: 3829D62F1E5533C766D-806C
    End----(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Wednesday,20,March,2019,13:33:42:27520
              52 53 56 5F 6C
       Revision: NAH04---
    Readiness: 1110 1101
       Revision: --H01---
       Coding: 302D1A
       Coding: 4802200000
                        Reset counter: 223
                        Mileage: 89549 km
                        Date: 2019.03.20
                        Time: 12:29:17
       Coding: 00FD11
       Coding: 02005D
    H01 0031
    H01 0031
       Coding: 00333E
       Coding: 00003E
       Coding: 80E3031600
       Coding: 030000
                        Reset counter: 223
                        Mileage: 89549 km
                        Date: 2019.03.20
                        Time: 12:29:17
       Coding: 010211
       Coding: 000102
                000 -  -
                        Reset counter: 223
                        Mileage: 89549 km
                        Date: 2019.03.20
                        Time: 12:29:22
       Coding: 1021008
    End----(Elapsed Time: 01:55, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
