Results 1 to 7 of 7
Thread: Throttle valve adaptation issue
    Nov 2018
    I've done throttle valve adaptation before and did so again right after cleaning my throttle bodies. No issues.
    I went to do it today, just to record it for a how to video and decided to try and record the screen through the Microsoft function. It slowed the computer down tremendously and I had to stop it. Well the adaptation stopped too.
    As a result, I have a DTC that will not clear.
    On top of that, I ran the throttle valve adaptation again and could not hear the usual clicking of the throttle butterflies as they're activated. I tried to clear the DTC's and then cycle the ignition. No luck.
    Next I disconnected the negative to the battery. Connected everything up again and this time, running the adaptation, I heard the clicking. But it literally sat there for minutes on end and never finished up. Tried repeatedly with no luck and the codes will not clear.
    This is on a 2013 Audi RS5
    2761 - Throttle Actuator (J338)
    P1579 00 [039] - Adaptation Not Started
    as well as...
    10253 - Throttle Throttle Controller 2 (J544)
    P3037 00 [039] - Adaptation no Started (it really says no instead of not)
    Any idea? Car starts fine. And thanks in advance.
    Please post an Auto-Scan for context.
    If the engine was completely cold, try warming it up a bit. Check battery voltage as well.
    Nov 2018
    Engine was warm, within the acceptable range. I believe the coolant was about 80 degrees Celsius. Battery voltage was 12.3.
    It's just strange that it will not clean the DTC for the throttle bodies. If I do it repeatedly, it'll clear but it's not really cleared and comes back if I check it again. There's been a lot of "buggery" since updating to the latest version, especially with logging.
    Nov 2018
    Here's my entire auto scan.
    Monday,11,March,2019,15:35:30:27520
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WUAC6AFR6DA902467   License Plate:
    Mileage: 89100km-55364mi   Repair Order:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
              52 53 56 5F 6C
    VIN: WUAC6AFR6DA902467   Mileage: 89100km-55364miles
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560 F    HW: 8T1 907 560
       Component: 4.2l JHM.9X/  H04 0005
       Revision: NAH04---
       Coding: 1A25003225C6080D3000
       ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
       ROD: EV_ECM42FSI0118T2907560F.rod
       VCID: 3FDBBD3337FB04FFA77-806A
    10253 - Throttle Controller 2 (J544)
                        Mileage: 89105 km
                        Date: 2019.03.11
                        Time: 14:15:22
                        Coolant temperature: 89 ∞C
                        Intake air temperature: 64 ∞C
                        Voltage terminal 30: 11.968 V
                        AFS dm: 0.0 kg/h
                        Median injection timing: 0.000 ms
                        Mileage: 89105 km
                        Date: 2019.03.11
                        Time: 14:15:22
                        AFS dm: 0.0 kg/h
       Part No SW: 8T0 927 156 F    HW: 0B5 927 156 J
       Component: 0B5 42 FSINAR H01 0008
       Revision: --H01---
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001012
       ROD: EV_TCMDL501021.rod
       VCID: 40D9BECF4A057B07DED-8014
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Component: ESP8 quattro  H09 0100
       Coding: 302D1A
       VCID: 45D7AFDB55A75E2FEDB-8010
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Coding: 0D804000000000000000
       VCID: 045172DF1E1DA727BA5-8050
       Serial number: 2313000016339008
    Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000051213831
       Coding: 00037025002C00000000
       Shop #: WSC 06342 000 00000
       Revision: C1000000    Serial number: 01200220130492
       Coding: 4802200000
       VCID: 392FD32B295F2ACF993-806C
                        Fault Status: 00100011
                        Fault Frequency: 29
                        Reset counter: 247
                        Mileage: 88168 km
                        Date: 2019.02.17
                        Time: 10:37:31
                        Voltage: 14.30 V
                        Temperature: 26.0∞C
                        Temperature: 20.0∞C
                        Count: 11062
                        Count: 10974
                        Bin. Bits: 01000000
                        Bin. Bits: 10001011
                        Time: 255.00 s
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000554864301
       Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
       Shop #: WSC 92630 444 123950
       VCID: 7AAD0C276CD9E1D7D09-802E
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150213  H15 0080
       Serial number: SWF13020150148
       Coding: 00FD11
       Serial number: 21004112
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000502130647
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R4SYJ02
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 7C48C296000000000001
       Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
       Component: ACC3          H11 0100
       Coding: 00333E
       VCID: 323DE407F429D997589-8066
       Serial number: 003KJD91EW3S
       Coding: 303343334830303030304A55304C38543053
       VCID: 4ACD9CE77C39B157009-801E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R130000CJ7S
       Serial number: 6334MSME780331656
       Serial number: 6344MSME78406157C
       Serial number: 6352QSME62282B44G
       Serial number: 6362QSME5F2C5372T
       Serial number: 63732SME712B0F585
       Serial number: 63832SME542B2F444
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20130219001040
       Coding: 00003E
       VCID: 51FF8B8B91EF828F413-8004
       Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
       Revision: 00300000    Serial number: UVA266K2E
       Coding: 83BF0100AF03D705020000
       VCID: 3D27C73B3D7716EFB5B-8068
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z13204008E
       Coding: 80E3031600
       VCID: 4CC19AFF76CDAF67325-8018
       Serial number: 1367620003
       Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
       Component: DYNAMIKLENK.  H06 0690
       Coding: 030000
       VCID: 3635D8171841C5B7741-8062
       Component: 4 Wheel Drive H14 0100
       Serial number: 001302130001758
       VCID: 2F3BED73E79BF47F377-807A
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000051211560
       Coding: 001B7B25002C00000000
       Shop #: WSC 11251 001 1048576
    03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                        Fault Status: 01100101
                        Reset counter: 168
                        Mileage: 88098 km
                        Date: 2019.02.17
                        Time: 09:31:51
       Component: SWA Master    H04 0060
       Serial number: 0192285845
       Coding: 010211
       Shop #: WSC 06324 000 00000
       Component: SWA Slave  H04 0060
       Serial number: 0192294703
       Coding: 000102
       Component: TSG FA        H09 0304
       Coding: 011C13224E00120102
       VCID: 56F57897B801E5B7941-8002
       Revision: 00001000    Serial number: 0012646993
       Coding: 010000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3431E21F0EBDD7A74A5-8060
       Revision: 00002001    Serial number: 0301332569
       Coding: 0106069A00FAC10581B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000634856
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0028
       Serial number: WA104645000002650945
       Revision: 00005001    Serial number: 94813011143102
       VCID: 2D07F77BED17866F05B-8078
       Component: TSG BF        H09 0304
       VCID: 55F77F9BA507EEAF9DB-8000
       Revision: --------    Serial number: 20000000227161
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3829D62F12D533C766D-806C
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156B50D7693479
       Coding: 020007010000000001
       VCID: 25170F5BB5E7BE2FCDB-8070
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 1040
       Revision: --------    Serial number: 204BT0D7561283
       Coding: 150200020306A9EF75028B4E00000403140000000000000000
       VCID: 3FDBBD33377B04FFA77-806A
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H42 0104
       Serial number: A130BX0D2659970
       Serial number: 00000001419689
       Component: CD-Database  4949
    No Faults Found
       Revision: --H07---    Serial number: 525PA8-J2Z91FG
       Coding: 1021008
       VCID: 3829D62F1E5533C766D-806C
    End----(Elapsed Time: 02:13, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
    Monday,11,March,2019,17:10:05:27520
              52 53 56 5F 6C
       Revision: NAH04---
                        Mileage: 89104 km
                        Date: 2019.03.11
                        Time: 15:59:40
                        Coolant temperature: 66 ∞C
                        Intake air temperature: 61 ∞C
                        Voltage terminal 30: 11.826 V
                        AFS dm: 0.0 kg/h
                        Mileage: 89104 km
                        Date: 2019.03.11
                        Time: 15:59:40
                        AFS dm: 0.0 kg/h
    Readiness: 1110 1101
       Revision: --H01---
       Coding: 302D1A
       Coding: 4802200000
                        Reset counter: 207
                        Mileage: 89104 km
                        Date: 2019.03.11
                        Time: 16:00:11
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 207
                        Mileage: 89104 km
                        Date: 2019.03.11
                        Time: 16:04:56
                        Voltage: 11.70 V
                        Temperature: 28.0∞C
                        Temperature: 26.0∞C
                        Count: 1850
                        Count: 953
                        Bin. Bits: 00000000
                        Bin. Bits: 10001011
                        Time: 2.55 s
       Coding: 00FD11
       Coding: 02005D
    H01 0031
    H01 0031
       Coding: 00333E
       Coding: 00003E
       Coding: 80E3031600
       Coding: 030000
                        Reset counter: 207
                        Mileage: 89104 km
                        Date: 2019.03.11
                        Time: 14:59:28
       Coding: 010211
       Coding: 000102
                000 -  -
                        Reset counter: 207
                        Mileage: 89104 km
                        Date: 2019.03.11
                        Time: 14:59:32
                        Text: DUA130,Front,M,0,0,6
       Coding: 1021008
    End----(Elapsed Time: 02:02, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
    Both faults show battery voltage in the freeze-frame data under 12V.
    Personally, the first thing I would try is doing it with a battery charger connected.
  6. Likes Dana liked this post
    Nov 2018
    I'll try that. I have a voltage meter in the cig lighter and it said 12.3. Guess it's not calibrated.
    Nov 2018
    Yep, despite reading 11.9 volts, which is supposed to be fine, hooking it up to a battery tender solved the issue.
  9. Likes NZDubNurd, Uwe, Andy, Dana liked this post
