Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Driving Shool Mode (DSM) on 5F modules with "Gen2" channels?
    May 2014
    Driving School Mode (DSM) on 5F modules with "Gen2" channels?
    I've been trying to help a local lad here in the Antipodes with DSM on his MIBII unit. As I also have this style 5F module on my A3 8V (virtual cockpit), I thought that I would simply follow the usual instructions without any problems - but I was wrong!!
    The "usual" instruction for DSM on MQB platform vehicles generally involve the following 3 x channels in the module @ address hex5F (bracketed settings are default) :
    • Vehicle function list CAN-Driving_school >available (not available)
    • Vehicle menu operation-menu_ display_ driving_ school > activated (not activated)
    • Vehicle menu operation-menu _display _driving _school _over _threshold _high >activated (not activated)
    Here is a list of the DSM related channels on MIBII units:
    1. ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school > not activated
    2. ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer > not activated
    3. ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off > not activated
    4. ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high > not activated
    5. ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill > not activated
    6. ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school > Not available
    7. ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus > Not available
    So - aligning the old instructions with the new MIBII channels, I'm guessing that:
    First channel maps onto 6
    Second channel maps onto 1
    Third channel maps onto 4
    And I have also changed 7 above to Databus Infotainment - so that it aligned with the setting on my old mk7 Golf in which DSM worked OK
    But alas no DSM option appears under the CAR option in the MIB.
    Has anyone here had success with this tweak on 5F units with "Gen2" adaptation channels?
  2. Likes Uwe, Dana liked this post
  3. #2
    Dec 2016
    DE
    What unit specifically is build into that car in question?
    To my knowledge only "low-line" MIB HMIs are able to show the driving school mode, such as the Composition Media or Composition Touch.
  4. Likes Dana, DV52 liked this post
  5. #3
    United States
    The scan and maps from this one may add clarity.
    I'm no expert in this area but my retired 2017 SEL had a proper 5F (Discover Media) with those Gen 2 channels and I had it enabled in that car.
    My current low-spec 2018 S has a low-end Composition Color unit but I don't believe I attempted to enable Driving School Mode in this car yet. I can certainly try that for science!
  6. Likes Uwe, DV52 liked this post
  7. #4
    May 2014
    ^^^^ TBAx: of course - my apology (see below)
    Dana:Purely in the pursuit of science - please try
    Thursday,16,August,2018,07:00:59:16808
    VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
    VIN: WAUZZZ8V3JA084907   License Plate:
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 6C A5
              BB BC CF
    VIN: WAUZZZ8V3JA084907   Mileage: 173km-107miles
    Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
       Component: R4 1.4l TFS   H24 3744
       Revision: R6H24---
       Coding: 02250032236401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906027HF 001007
       ROD: EV_ECM14TFS01104E906027HF.rod
       VCID: 6FAE16D4B6DCA43CCD-803A
       CAN Converter 01:
       Part No SW: 0CW 300 041 Q    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1603
       Revision: 00005008    Serial number: CU501712236712
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW27.rod
       VCID: 43C68A64CAD4705C79-8016
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 63357000000216
       Coding: 12F18AA2242822708B800A00A0CA2948512444D1500594731821503482A8420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
       VCID: 79BA288CF898FA8C63-802C
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0465996031
       Coding: 030C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C34F198B72A0FA438-8068
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001446081
       Coding: 03100004110000001000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 40CC8568DBC26B4464-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 01501A0900PAG0MUFU03
       Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H36 0253
       Serial number: 01001800901626
       ROD: EV_BCMCONTI.rod
       VCID: 095A584CA878EA0C73-805C
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 171127  043 0580
       Serial number:         171208172857
       Coding: 0A47F7
       Serial number: 21148915X81A955547A0
       Coding: 00006C
       Component: E1 - LDS MQB  H06 0032
       Serial number: 16 09 2017  00002183
       Part No SW: 5QA 919 294 B    HW: 5QA 919 294
       Serial number: 000308418918003
       Coding: 0470155811
       ROD: EV_EPHVA18AU3700000_009_AU37.rod
       VCID: 4BD6A244E284B81C81-801E
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: 3500E7411DFFC428949C8055000026
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
       VCID: 3B36F284B224089C31-806E
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Component: AirbagVW21    005 0336
       Serial number: 003VWR3SAJL2
       Coding: 98CCC000000000005C54000000C8000000C5
       Subsystem 1 - Part No SW: -----------    HW: 480 001 001 18
       Serial number: 3570000000085DA0AA2U
       Subsystem 2 - Part No SW: -----------    HW: 480 001 001 18
       Serial number: 3580000000016DA0AA2P
       Subsystem 3 - Part No SW: -----------    HW: 480 400 801 18
       Serial number: 3510001BB28DFC73E6A-
       Subsystem 4 - Part No SW: -----------    HW: 480 400 801 18
       Serial number: 35200019F28DFC73E41S
       Subsystem 5 - Part No SW: -----------    HW: 480 401 011 17
       Serial number: 3550002AD25629A3B145
       Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 04011804400355
       Coding: 6C18
       VCID: 085C5D48B37293046C-805C
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
       Component: FBenRDW       H16 0066
       Coding: 248409506F8800080180EA001000000000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001027
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 3A38F780BD1E31942A-806E
       Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007219271
       Coding: 030100043F0857085B000058180B00000001010000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW27.rod
       VCID: 383CED8883122384DC-806C
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20180108180606 21736
       Serial number: 75886000001801070888
       Revision: 00000000    Serial number: 17000401984006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424D9B89F7AC7E4F0-8060
       Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
       Component: MRR1Rear      H21 0610
       Revision: --------
       Coding: 44C002
       Serial number: 161217ELE26178
       Coding: 001C1B205C01040000001003
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1081
       Coding: 11170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73A61AA4DAF480DC29-8026
       Serial number: 171217ELG32984
       Coding: 001C13205E01040000001003
       VCID: 42C88F60D5CE795472-8016
       Part No SW: 8V1 035 041 D    HW: 8V1 035 041
       Component: MU-P-LND-RW   054 1168
       Serial number: A838K0HS006144
       Coding: 01730308FF0A000011511101000A00102F002666017001005E
       VCID: 302CD5A86B62FBC494-8064
       Subsystem 1 - Part No SW: V03 959 801 PT    HW: -----------
       Component: ROW 2017/2018  --- 0065
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y08LE7
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL130101700050258
       Component: Gracenote2  --- 4012
       Coding: 0273100102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
       VCID: 393AE88CB8183A8C23-806C
       Component: MQB_B_MFK     H07 0272
       Serial number: 08011812P20164
       Coding: 040307030000010101022346814EA90088000E100020
       ROD: EV_MFKBoschMQBB_VW36.rod
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 121217ELC09635
       Coding: 000C13204001040000001002
       Serial number: 121217ELC09492
       Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
    End----(Elapsed Time: 01:50, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  8. Likes Dana liked this post
  9. #5
    Nov 2018
    What does this feature do when activated?
    2016 Audi A6 TDI
    So Cal, USA
  10. #6
    Quote Originally Posted by wuplur View Post
    Shows this screen on the infotainment
  11. Likes Uwe liked this post
  12. #7
    Apr 2018
    ITALY
    I also always wondered how is that screen useful...
  13. #8
    Unless you're a driving instructor maybe not really useful; but it does give a summary of fuel consumption, speed and range which otherwise would need several screens.
    Plus it's available so why not enable it?
  14. Likes Dana liked this post
  15. #9
    Apr 2018
    ITALY
    Quote Originally Posted by PetrolDave
    cause I am not a driving instructor
  16. Likes Dana liked this post
  17. #10
    United States
    If my husband was a member of this forum he'd explain that particular function fine tunes spouse micromanagement As a passenger, I didn't need to use my imaginary brake pedal as frequently because I could see the speed!
    Don I will tweak that and report back. I'm sure Chad will be thrilled it if can be enabled
  18. Likes Uwe, PetrolDave liked this post
