Results 1 to 5 of 5
Thread: 2013 Audi Q5 Hybrid - P2681 P2682
    Feb 2019
    Check engine light came on. Scanned 2 codes.
    P2681 Control Circuit for Coolant Bypass Valve(Open Circuit)
    P2682 Control Circuit for Coolant Bypass Valve (Short to GND)
    Vehicle otherwise runs fine.
    Cabin heating operates fine.
    No noticeable coolant loss.
    I read that it could be related to solenoid valve N82. I found 2 identical solenoid valves at the back of the engine, mounted back to back. One on top of a plate, the other below the plate.
    I replaced the top one. Some documentation suggests it is N82, other documentation suggests it another valve identified simply as '3' on a cooling system diagram.
    Appreciate any suggestions on how to troubleshoot this further.
    Saturday,23,February,2019,13:19:01:39136
    VCDS Version: 18.9.1.0 (x64)
    VIN: WA1C8AFP2DA0797xx   License Plate:
    Mileage: 119510km-74260mi   Repair Order:
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 40 42 44 46 47 51 52 53
              56 5F 62 6C 6D 72 8C
    VIN: WA1C8AFP2DA0797xx   Mileage: 119510km-74260miles
    40-AC Compressor -- Status: OK 0000
    Address 01: Engine (0-MA--CHJA)       Labels: None
       Part No SW: 8R1 907 115 D    HW: 8R0 907 115 G
       Component: 2.0l R4/4V TF H57 0003
       Revision: NDH57---
       Coding: 6A2A0013442600062000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TFS0118R1907115D 002005
       ROD: EV_ECM20TFS_AU48.rod
       VCID: 3668EEB789DF9DFA37-8062
    13056 - Control Circuit for Coolant Bypass Valve
              P2681 00 [039] - Open Cricuit
                        Mileage: 119490 km
                        Date: 2019.02.23
                        Time: 11:25:15
                        Coolant temperature: 90 °C
                        Intake air temperature: 45 °C
                        Voltage terminal 30: 13.099 V
                        CAN status - engine control module-Bits 0-7: 00000000
                        CAN status - transmission control module-Bits 0-7: 00000000
                        CAN status - brake control module 1-Bits 0-7: 00000000
                        CAN status - brake control module 2-Bits 0-7: 00000000
                        Cruise control switch actuation-Bits 0-7: 00000000
    13059 - Control Circuit for Coolant Bypass Valve
              P2682 00 [172] - Short to GND
                        Fault Frequency: 7
                        Mileage: 119481 km
                        Date: 2019.02.23
                        Time: 11:06:56
                        Engine speed: 2066.50 /min
                        Normed load value: 36.5 %
                        Vehicle speed: 111 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 17 °C
                        Voltage terminal 30: 14.606 V
    Readiness: 0000 0100
       Part No SW: 8R1 927 158 K    HW: 0BW 927 156 P
       Component: 0BW 20TFSIUSA H16 1001
       Revision: --H16---
       Coding: 000001
       ASAM Dataset: EV_TCMAL551111 002022
       ROD: EV_TCMAL551111_002.rod
       VCID: 46889E77F93F0D7AA7-8012
       Part No SW: 8R0 907 379 T    HW: 8R0 907 379 T
       Component: ESP8 quattro  H09 0060
       Coding: 2D1D1C
       Shop #: WSC 06335 000 00000
       VCID: 51A2BD2B0871DAC202-8004
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H12 0633
       Coding: 0DC54040000000000000
       VCID: 040C447F8783FF6AF9-8050
       Serial number: 2313000032195016
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01130320130194
       Coding: 64C120C000
       VCID: 3972E58BB0C17282DA-806C
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000566091301
       Coding: 26000091863CAFC00000480300003D0D0F1C4608E0090221000008004000010200040034000000
       VCID: 7AF03A87F547B99A93-802E
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130226  H11 0050
       Serial number: 90243014130220175918
       Coding: 01DD13
       Serial number: 21069430
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000203130394
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R56T802
       Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 61384896000000000001
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Serial number: 003GPD91CZF0
       Coding: 303634313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 47969373FE3514725C-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R130000DK64
       Serial number: 6334MSME78661712B
       Serial number: 6344MSME76251538B
       Serial number: 6352QSME672F374EZ
       Serial number: 6362QSME6A2C3848V
       Serial number: 63732SME4D2D0270/
       Serial number: 63832SME4D2D10482
       Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
       Revision: --------    Serial number: 90372MC10019P
       Coding: 000037
       VCID: 438E8763C20D385280-8016
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 981 D    HW: 8R0 920 981 D
       Component: KOMBIINSTR.   H35 0556
       Revision: 00200000    Serial number: UWU31AA3E
       Coding: 8BB723000B01D705020000
       VCID: 3B7EFF83BAFD4092C8-806E
       Part No SW: 8R0 907 468 K    HW: 8R0 907 468 E
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 2A120022    Serial number: 2242A132060014
       Coding: 80D00AFF00
       VCID: 47969373F63514725C-8012
       Subsystem 1 - Part No SW: 8R0 915 181 A    HW: 8R0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 40067D06131581109637
       Subsystem 2 - Part No SW: 8R0 915 181 B    HW: 8R0 915 181 B
       Component: J367-BDMLear2  H07 5040
       Serial number: 00000000001770211980
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000053508861
       Coding: 00581B00000000000000
       VCID: 42808267DD17315A8B-8016
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H04 0060
       Serial number: 0191984086
       Coding: 010211
       Shop #: WSC 06334 000 00000
       VCID: 3F868B93A6E55CB2E4-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H04 0060
       Serial number: 0192980649
       Coding: 000102
    733440 - Control Module for Lane-Change Assist
              C1114 F3 [008] - Limited Visibility
                        Reset counter: 106
                        Mileage: 118949 km
                        Date: 2019.02.06
                        Time: 08:00:09
    733696 - Control Module 2 for Lane-Change Assist
              C1115 F5 [008] - Limited Visibility
                        Reset counter: 106
                        Mileage: 118948 km
                        Date: 2019.02.06
                        Time: 07:56:09
    Address 40: AC Compressor (J842)       Labels: 8R0-260-797.clb
       Part No SW: 8R0 260 797 C    HW: 8R0 260 797 C
       Component: ES34          H01 0001
       ASAM Dataset: EV_AirCondiCompr_ES34 S03001
       ROD: EV_AirCondiCompr_ES34.rod
       VCID: 3C7CFC9FB7F347AAC1-8068
       Component: TSG FA        H02 0508
       Revision:             Serial number: 0000053763076
       Coding: 011D13205E00440004
       VCID: 4FA6BB531E45CC3214-801A
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Revision: 00001000    Serial number: 0024298047
       Coding: 000000000100
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B7EFF83B2FD4092C8-806E
       Revision: 00002001    Serial number: 0301729952
       Coding: 0126023A20FA709584B005321004000D
       Component: GTO BF  H01 0080
       Serial number: 00000000000000644899
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H05 0220
       Revision: 00005001    Serial number: 94813012016802
       VCID: 2D5AC1DB7489DE2246-8078
    Address 51: Electric Drive (J841)       Labels: 06F-907-080.clb
       Part No SW: 06F 907 080 H    HW: 06F 907 080 H
       Component: MLB HYBRID    H19 0001
       Revision: --------
       ASAM Dataset: EV_DMCM030202106F907080H 001003
       ROD: EV_DMCM030202106F907080H.rod
       VCID: 2C5CCCDF4793D72A51-8078
       Component: TSG BF        H02 0508
       Revision:             Serial number: 0000054101529
       VCID: 4E98A657194FC53A1F-801A
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000182048
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3874E08F83CB6B8A25-806C
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156CW0D7703407
       Coding: 020007010000000001
       VCID: 244C24FF27431F6A99-8070
       Part No SW: 8R1 035 746 G    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 0901
       Revision: --------    Serial number: 204C00D7567398
       Coding: 170200060005A1EF51038B4E00000403140000000000000002
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H42 0104
       Serial number: A130CR0D2674750
       Serial number: 00000001437307
       Component: CD-Database  4949
       Revision:             Serial number: 0000054465179
       Coding: 010C13204000240004
       VCID: 46889E77F13F0D7AA7-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H07---    Serial number: 525PA8-J2ZA5F3
       Coding: 1020010
       VCID: 346CD4BF57A38FEA09-8060
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Revision:             Serial number: 0000054465127
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 8R0 915 591     HW: 8R0 915 591
       Component: BMS           H08 0543
       Coding: 0A0200
       Shop #: WSC 49905 001 1048576
       ASAM Dataset: EV_BECM0722011 004016
       ROD: EV_BECM0722011_004_AU48.rod
       VCID: 78F4208FC34BAB8AE5-802C
    End-------------------------(Elapsed Time: 04:32)--------------------------
  2. Likes Treborg liked this post
  3. #2
    Mar 2015
    I just had the same (P2681) code on my Q5 Hybrid. Did your solenoid change fix the problem?
    Mar 2015
    I've been searching thru my copy of the shop manual, and it is the lower solenoid valve N82 that is the culprit for P2681. Damn thing is virtually impossible to see from the top - one can see the hoses going in and out, and I think I put a finger on the connector toward the back but I can't actually see the connector or the wires. Draining the engine coolant is the first step in the replacement process according to the manual. The R&R instructions seem to be very simple, a page or so and a few lines, but access there is really difficult. I'm going to try finding the actual part on-line to see how its shaped and whether or not I did touch its connector.
    Feb 2019
    I changed the top valve (N422) originally thinking that was actually N82. It made no difference.
    Changing that top one is real awkward. Very hard to access the back of the engine. But I was able to do it.
    Then I realized that N82 is underneath that one. I tried to get to that, but access is almost impossible. It seems simple enough per the manual, but actually accessing it in the real world is a nightmare.
    I couldn't even get the N82 connector off to troubleshoot any further.
    So it is in at the dealer right now.....
    Feb 2019
    Okay back from the dealer.
    The N82 coolant solenoid valve was leaking into the electrical connector and through the wiring harness towards the ECU.
    New valve, new connector, 6 inches of wiring harness replaced.
    Moral of the story: It is disappointing how much damage these dumb valves can potentially do. Pro-actively checking the connectors on these valves for leakage is probably a wise move.
    Unfortunately, some of them are very difficult to access.
    If you get a MIL code and suspect one of these solenoid valves I'd suggest getting on it right away to limit the damage.
  7. Likes Uwe, PetrolDave liked this post
