Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Faulty coil or fuel injektor 2.0 tfsi
    Feb 2019
    Sweden
    Jack, I’m sorry for not being able to express myself in English.
    No fault codes present as of now (only got the fault codes from first post who I erased back then)
    The misfire counter number must be from cars birth and that’s why I would like to reset the counter.
    The “750” number can be read just with key on (engine NOT running).
    Wife have driven car +60km on one used and 3 original to the car coilpack with no fault code
    The 4 new coilpacs is to arrive monday or tuesday.
    After installing them I would like to reset the counter..
    //Lars
  2. #12
    Feb 2019
    Sweden
    This is the counter numbers which i wonder if they can be reset?
    Saturday,16,March,2019,13:04:21:21588
    VCDS Version: 18.9.1.0
    VIN: WAUZZZ8T7AAxxxxxx   License Plate:
                    Address 01: Engine  (8K2 907 115 AJ)
    13:03:53
      IDE00604   Short term adaptation of mixture formation bank 1 -1.6 %
      IDE01975   Numb.of misfir.: cylinder 1 205
      IDE01976   Numb.of misfir.: cylinder 2 214
      IDE01977   Numb.of misfir.: cylinder 3 774
      IDE01978   Numb.of misfir.: cylinder 4 496
    and hers a autoscan now after about 120km
     Sunday,17,March,2019,10:05:32:21588
    VIN: WAUZZZ8T7AAzzzzzz   License Plate: ORD666
    Mileage: 129380km-80393mi   Repair Order:
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
    VIN: WAUZZZ8T7AA017306   Mileage: 129380km-80393miles
    Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AJ    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H15 0002
       Revision: E1H15---
       Coding: 0114000C240F0160
       Shop #: WSC 52341 002 1048576
       ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
       ROD: EV_ECM20AVS.rod
       VCID: 77F9D27DCE9910F2EC-8022
    Readiness: 0000 0100
       Part No SW: 8K0 927 156 F    HW: 0B5 927 156 E
       Component: 0B5 20TFSIRdW H03 0011
       Revision: --H03---    Serial number: 0000000066
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501 A02044
       ROD: EV_TCMDL501.rod
       VCID: 3779127D8E19D0F22C-8062
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 090D08
       VCID: 7AFFCB49F58B0D9A93-802E
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0324
       Coding: 010400
       VCID: 010DBCA5985D5E42D2-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0509000046228012
       Serial number: 0209000059431008
       Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serial number: 01290820091718
       Coding: 64000000
       VCID: 7DF5C055E4A53AA2B6-8028
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000452480
       Coding: 2600D0914034AF010009000300005D5D0F1C430800010101000000
       VCID: 3C730D51BF3FF3AAC1-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 030909  H14 0070
       Serial number: SWF09090035175
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10579268
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001708090723
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0050
       Revision: 11001001    Serial number: 39840923802476
       Coding: 100107
       VCID: 408B79A1D3D7974A9D-8014
       Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EFD057NUO
       Coding: 30343438363030303030554A304C38543053
       VCID: 418D7CA5D0DD9E4292-8014
       Serial number: 6334MSME4A012A000
       Serial number: 6344MSME4A633A37K
       Serial number: 6352QSME25394E2CS
       Serial number: 6362QSME52394E2CT
       Serial number: 63732SME5A384424$
       Serial number: 63832SME69384B10%
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304IHR0005U
       Coding: 000016
       VCID: 3D750055A425FAA2F6-8068
       Part No SW: 8T0 920 900 N    HW: 8T0 920 900 N
       Component: KOMBIINSTR.   H33 0253
       Revision: 00000000    Serial number: BX420Z589
       Coding: 0F07310003000008010000
       VCID: 3E770759A923E1BAEF-806A
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G098168146
       Coding: 00C303
       VCID: 50AB49E103B767CA0D-8004
       Component: J367-BDM  H06 0170
       Serial number: 1908A6D7050809
                000 -  -  - Intermittent
                        Fault Frequency: 70
                        Reset counter: 28
                        Mileage: 121634 km
                        Date: 2018.08.29
                        Time: 07:53:57
                        Bin. Bits:    10111
                        Voltage: 11.30 V
                        Count: 6
       Part No SW: 8T0 959 793 D    HW: 8T0 959 793 A
       Component: TSG FA        H07 1101
       Coding: 011C02624000450005
       VCID: 4A9F5B89E5EB5D1A43-801E
       Revision: 00002001    Serial number: 0121095385
       Coding: 011A0620203900000030040000000000
       Shop #: WSC 06342 000 00000
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 52
                        Reset counter: 245
                        Mileage: 117004 km
                        Date: 2018.04.18
                        Time: 14:10:19
    02615 - Fuel Tank Cap; Lock
                        Fault Frequency: 46
                        Reset counter: 245
                        Mileage: 117008 km
                        Date: 2018.04.19
                        Time: 08:46:55
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
       Component: DSP Prem      H17 0320
       Revision: 00017001    Serial number: 34834004452502
       Coding: 0203010301
       Shop #: WSC 40970 222 96083
       VCID: 7EF7C759E9A321BAAF-802A
       Part No SW: 8T0 959 792 D    HW: 8T0 959 792 A
       Component: TSG BF        H07 1101
       Coding: 011C02224000450005
       VCID: 499D6485E0ED56024A-801C
                        Fault Frequency: 60
                        Reset counter: 27
                        Mileage: 122881 km
                        Date: 2018.09.21
                        Time: 08:39:20
       Revision: 00000003    Serial number: 00000000434661
       VCID: 34632571976F3BEA09-8060
       Part No: 8K5 907 357
       Shop #: WSC 06324 000 00000
       VCID: 77F9D27D069910F2EC-8022
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H04 0310
       Revision: 00000007    Serial number: AUZ5Z6I1262726
       Coding: 0503008001040500415B070000
       VCID: 448375B1C7CF8B6AB9-8010
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
       Part No SW: 8T0 959 795 E    HW: 8T0 959 795 B
       Component: TSG HL        H05 1101
       Coding: 010C02224000450005
       VCID: 4D95509514854A2266-8018
                        Fault Frequency: 41
                        Reset counter: 32
                        Mileage: 121231 km
                        Date: 2018.08.06
                        Time: 08:33:46
       Component: TSG HR        H05 1101
    End-------------------------(Elapsed Time: 03:38)--------------------------
  3. #13
    Reset the fault memory 3-5 times fast and without an engine restart It should reset I believe when checking after a verified key cycle and being re-coded.
    Then cold reboot the car battery with bridge.
  4. #14
    Feb 2019
    Sweden
    Jack thank you very much.
    I understand the procedure until here.
    Caldstart (disconnect battery wait a bit than reconnect the battery) but what is the bridge??
    ….. discharge positive cable while disconnected???
    Please have patience with me I’m just a dumbas and not in my native language...
    Lars
  5. #15
    Did you when battery is disconnected, connect a bridge wire from one side to other of terminals in car & "NOT the Battery"!, than turn ignition ON during wait time than turn key off, remove bridge and reconnect battery?
  6. #16
    Feb 2019
    Sweden
    No, done nothing yet. Still waiting for the colipacks to arive. But now i understand the bridge and why to do it. I'l be back reporting the outcom as son as i installed new coilpacks and executed your counter clearing instruction.
    Lars
  7. #17
    Feb 2019
    Sweden
    I replaced the coilpacks some 2 weeks ago and tried only half the reset advice
    “Reset the fault memory 3-5 times fast and without an engine restart it should reset I believe”
    -no misfire counter reset.
    I now need to know if I need a code to reactivate the “Bang & Olufssen” system if I disconnect the battery.
    I bought a new battery that I will replace it as soon as I know that I will be able to play music afterwards (the old battery is just that, old and a litle weak)
    -and then I will perform the entire procedure including drain all current from system (the bridge thing) before reconnecting the new battery.
    I will report when I know the result.
