- Joined
- Apr 18, 2014
- Messages
- 679
- Reaction score
- 216
- Location
- Stoke on Trent, England
- VCDS Serial number
- C?ID=122432
Hi guys.
I've just plugged it in to do my normal scan VCDS Release 14.10.0 after it finished I thought I would give the VCDS Beta 14.9.0 ago. All buttons were disabled and a message at the top said it out of date. I went online the http://www.ross-tech.com/vcds/download/beta/current.html and its showing the VCDS Beta 14.9.0 I have installed. If you click the download it goes to the normal download page VCDS Release 14.10.0 which I have installed.
As the Beta version finished or is it a bad link on the download button?
Just another quick point while I'm posting. After every scan I've done and saved the log file. Out of 24 scans done on my GTD 14 of them have the mileage added to the filename, Mileage: isn't shown in the files without it. Why doesn't it save or show the mileage every time?
Only one error code showed which I will have to look into.
Data version: 20141022
Dealer/Shop Name: Keith Stanier
VIN: WVWZZZ1KZAW267666 License Plate: GTD U
Mileage: 42950km-26687mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW267666 Mileage: 42950km-26687miles
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LC HW: 03L 906 022 G
Component: R4 2,0L EDC 0000SG 6655
Revision: 13H03--- Serial number:
Coding: 0001072
Shop #: WSC 00256 210 88209
VCID: 71EC587868FBDAA9905-8024
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B600D09280001681106EA901F0082340800
VCID: 78FA655CCB818BE157B-802D
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7DF47448ECA3AEC904D-8028
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0575
Revision: 00103 AG
Coding: 48180A3A9025F1C044080080340001E443510088536D8160648000200000
VCID: 306A9D7C637193A1DFB-8065
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 16120 21 0512
Coding: 009795
Component: RLS 211209 05 54 0402
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H10 9003
00532 - Supply Voltage B+
Reset counter: 159
Mileage: 42853 km
Date: 2014.11.10
Time: 15:28:21
Voltage: 14.30 V
Term 50 Off
Fault Status: 00100001
Reset counter: 162
Mileage: 42932 km
Term 15 Off
Voltage: 15.05 V
Term 50 Off
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA26LAS
Coding: 00003133
VCID: 3B70BA50B23760F97A9-806E
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7741744EZZZ+
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5961654EZZZ1
Serial number: 3512QSME2E1E455EZZZ7
Serial number: 3522QSME2C524572ZZZV
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000502
VCID: 78FA655C0B818BE157B-802D
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5K6 920 970 E HW: 5K6 920 970 E
Component: KOMBI H03 0305
Coding: 470900
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 3666AB648915BD91857-8063
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K09C11031B
Coding: E9807F06000212000003
VCID: 69DC3018402B2269D85-803C
Component: IMMO H03 0305
VCID: 6ADE4F148D2D2971D1F-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667727711
VCID: 26467B2451B5CD11357-8073
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2114
Coding: 0000692
VCID: 316C9878A87B9AA9D05-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2140
Coding: 0000692
VCID: 3462916C5769AF81BB3-8061
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 00000000 Serial number: VWZ1Z2I7269487
Coding: 0100040004
VCID: 65C43C286C330609FCD-8030
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 3564AC685C13B6898CD-8060
End-------------------------(Elapsed Time: 01:59)--------------------------
VAG Error Code: 00532
EOBD II Error Code: P1750
Fault Location:
Supply Voltage B+ - Open Circuit/Signal too Low/Signal too High/Lower Limit Exceeded/Upper Limit Exceeded - Intermittent
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) active.
Fuse(s).
Wiring/Connectors from/to ABS Control Module (J104)/Brake Electronics Control Module (J104).
This Diagnostic Trouble Code (DTC) is only stored, if it occurs the first time the vehicle exceeds 6 km/h.
As soon as the supply voltage is again within the valid voltage range, the system is switched back on and the warning lights turn off.
Open circuit or resistance too high between voltage supply of terminal 15 and ABS Control Module (J104)/Brake Electronics Control Module (J104) (terminal 1).
Open circuit or resistance too high in earth supply to ABS Control Module (J104)/Brake Electronics Control Module (J104) terminals 28 & 29.
Voltage jumps in vehicle.
Power Supply (Battery/Generator) faulty.
Possible Solutions:
Check/Replace Fuse(s).
Check/Replace all faulty Wiring/Connectors from/to Control Module.
Check Power Supply (Battery/Generator).
Read Measuring Value Blocks (MVB).
Special Notes:
When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
