2015 Golf R – ' 1543 - Control Module Incorrectly Coded '
disuye
Hong Kong
C?ID=258260
Full scan attached below. Address 5F / 1543 error, is the point of interest.
I've had this '1543' error in my VCDS scans ever since buying the car 2 years ago.
I never managed to find out what was causing the '1543' error, any idea where to start looking to clear it? If that's even possible? I've checked out the Byte_Coding ERRORs on the Long Coding screen, and the settings displayed are in agreement with the features my Golf R has installed. So ... confused.
Thanks in advance!
p.s: not sure if it's related but:
– the USB port below the infotainment has never worked / provided power despite the internal cable and plug appearing to be OK
– the Performance Monitor screen (boost gauges etc.) all work totally fine apart from the Coolant / Oil temp gauge, which has *never* displayed any values, just '---'. The Oil Temp on the dash display *does* work, assuming they're linked in some way.
Thursday,07,March,2019,13:43:47:30140
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.0.2 (x64)  HEX-NET CB: 0.4437.4
VIN: WVWZZZAUZEW308972   License Plate:
Mileage: 39211km-24364mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW308972   Mileage: 39211km-24364miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 B    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00322406010B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
   ROD: EV_ECM20TFS0205G0906259B.rod
   VCID: 2D12C2E07C6482224E-8079
21392 - Control Module for Exhaust Flap
          P14AB 00 [096] - Mechanical Malfunction
                    Mileage: 39198 km
                    Date: 2019.03.02
                    Time: 18:14:18
                    Vehicle speed: 255 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 12.597 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 1323 s
                    MAP_MES_SAE: 100 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 8120.0 kPa
Readiness: 0010 0001
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4319
   Revision: 05852204    Serial number: TFK01401280197
   ROD: EV_TCMDQ250021.rod
   VCID: 240427C42FAE436A91-8071
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 6035400000090D
   Coding: 01FA93A1542029740380070741C56980C92A94C0E08296F7004200B8C208
   VCID: 7BB63CB8F290DC9280-802F
   Revision: 00021000    Serial number: 0326667815
   Coding: 030C0C
   VCID: 3A38F9BCBD2A259ADB-806F
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120014200100011005000000101000
   VCID: 66807DCC9912717A4F-8033
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011404202066
   Coding: 03111A46C24122F30BA44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Component: WWS    140210  042 0551
   Serial number:         140212194131
   Component: RLFS  024 0042
   Serial number: Y14M02D15H05M34S24S6
   Coding: 00A8DD
   Serial number: 000000000ZY1401626GV
   Serial number: 00000000000058712165
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO26952525
   Coding: 181801
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331404400467
   Coding: 0031051011
   VCID: 3E30F5ACA10209BAE7-806B
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 03021441350064
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76A02D8CC9B281FAFF-8023
   Component: AirbagVW20    014 0385
   Serial number: 003F6R04P251
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41CA8E50D0FC76429A-8015
   Subsystem 1 - Part No SW: -----------    HW: 480 003 101 14
   Serial number: 3576700000012C74DE0
   Subsystem 2 - Part No SW: -----------    HW: 480 000 702 14
   Serial number: 358670000000C6F89E07
   Subsystem 3 - Part No SW: -----------    HW: 480 401 302 14
   Serial number: 35165029D11D1520D1E9
   Subsystem 4 - Part No SW: -----------    HW: 480 401 302 14
   Serial number: 35265029911D1525D185
   Subsystem 5 - Part No SW: -----------    HW: 480 400 602 14
   Serial number: 3556502BD13013F1F025
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10021404220770
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 79BA26B0F8ACEE8292-802D
   Part No SW: 5G6 920 870 E    HW: 5G6 920 870 E
   Component: KOMBI         322 2210
   Coding: 27AD0818BB80000E02082A00040000
   VCID: 312ADE90605CE6C26A-8065
   Revision: --------    Serial number: 0001496662
   Coding: 030100042B085900EF00026A9C0F00010001000000000000000000000000
   ROD: EV_GatewLear_010.rod
   VCID: 3FCE88A8A60800B2EC-806B
   Subsystem 2 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130001009760043432
   Coding: 25FFFF
   Serial number: 9655742503
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00020.01.14
   Coding: 0001
   VCID: 46C09D4CF9D2517AAF-8013
   Revision: 00000000    Serial number: 14000035193005
   Coding: DD00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424D7849F4ED3EA01-8061
   Serial number: 08021403110745
   Coding: 003F1220D001040000001000
   VCID: 40CC8B54DBF67F4A95-8015
   Serial number: 00000000000001860787
   Coding: 1D0000
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3522EA809434CAE236-8061
   Serial number: 26011403111441
   Coding: 003F1020DE01040000801000
   Serial number: 00000000000001876220
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 02A602000B000200
   VCID: 3D32F2A0AC0412A2FE-8069
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 3Q0 035 877 A    HW: 3Q0 035 877 A
   Component: MU-S--ROA     H24 0245
   Serial number: VWZAZ2R0315928
   Coding: 02730000FF00000051150001001028001F0207D40120010002
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 3326D4989A40D4D218-8067
   Subsystem 1 - Part No SW: 5GD 919 605 A    HW: 5GD 919 605 A
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RFB003RW
          U1014 00 [009] - -
                    Reset counter: 95
                    Mileage: 39169 km
                    Date: 2019.03.02
                    Time: 11:36:12
                    Voltage terminal 30: 14.5 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
          U11B8 00 [009] - No Communications
          [USB - communication error]
                    Reset counter: 95
                    Mileage: 39169 km
                    Date: 2019.03.02
                    Time: 11:36:13
                    Interface for external media: status-Status: Open circuit
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 140117200127
End----(Elapsed Time: 01:25, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
disuye
Hong Kong
C?ID=258260
p.p.s: also not sure if this is related, in the 5F Info Elect. Long Coding page, Byte 0-2 is *currently* set as "VW Golf Variant (BX5)" – which seems incorrect – aren't 2014/15 Golf R's supposed to be "VW Golf (5G1/BN2)"? Thanks.
NEtech
C?ID=56995
As far as I can see, your coding 027300 should be showed correct:
Model: VW Golf (5G1/BN2) [PR-7LG/7ZQ+K8G]
For U1014, I would try these changes, in the showed order, one at a time, or if necessary all
Check if DTC show "Intermittent"
Byte 8 From 51 to 21
Byte 17 From 02 to 00
Byte 24 From 02 to 00
disuye
Hong Kong
C?ID=258260
Thanks NETech – I just tried the three changes you suggested, and still getting the same U1014 trouble code.
In fact changing Byte 8 to 21 results in Byte Coding Condition = ERROR (when Byte 8 was 51, Byte Coding Condition = OK). New scan attached below.
Friday,08,March,2019,21:43:59:30140
   Revision: --H13---
Readiness: 1010 0001
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
          P1734 00 [002] - -
   Coding: 030C0C
   Revision: 00001K06
   Coding: 00A8DD
   Sun Roof:
   Coding: 181801
   Coding: 0031051011
   Coding: 0410
   Coding: 25FFFF
   Coding: 0001
   Coding: 1D0000
   Coding: 8103
   Coding: 050000
   Coding: 2E0000
   Coding: 2E0000
   Coding: 02730000FF00000021150001001028001F0007D60120010000
   Shop #: WSC 00046 123 12345
          U1014 00 [009] - -
                    Reset counter: 98
                    Mileage: 39211 km
                    Date: 2019.03.08
                    Time: 21:38:00
                    Voltage terminal 30: 12.3 V
                    Byte_Coding_Condition-byte_8_condition: ERROR
                    Reset counter: 98
                    Mileage: 39211 km
                    Date: 2019.03.08
                    Time: 21:38:01
End----------(Elapsed Time: 01:25, VBatt start/end: 14.8V/14.7V)-----------
DV52
C?ID=194404
Here's a more readable table of the software switches on the code-string for your 5F module
Name	Original		Changed
Byte	Hex	Binary	        Hex	Binary
0	02	00000010	02	00000010
1	73	01110011	73	01110011
2	00	00000000	00	00000000
3	00	00000000	00	00000000
4	FF	11111111	FF	11111111
5	00	00000000	00	00000000
6	00	00000000	00	00000000
7	00	00000000	00	00000000
8	51	01010001	21	00100001
9	15	00010101	15	00010101
10	00	00000000	00	00000000
11	01	00000001	01	00000001
12	00	00000000	00	00000000
13	10	00010000	10	00010000
14	28	00101000	28	00101000
15	00	00000000	00	00000000
16	1F	00011111	1F	00011111
17	02	00000010	00	00000000
18	07	00000111	07	00000111
19	D4	11010100	D6	11010110
20	01	00000001	01	00000001
21	20	00100000	20	00100000
22	01	00000001	01	00000001
23	00	00000000	00	00000000
24	02	00000010	00	00000000
I've highlighted Byte 19, Bits 7 & 8 which are set. Perhaps you might try un-setting these bits in the first instance - clear the fault and see if it re-appears. If the error is cleared, then try setting just Bit7 (leave Bit 6 = 0) - see below
Does your car have voice control working? if not Byte 24 suggested change is correct.
disuye
Hong Kong
C?ID=258260
Thanks DV25 / Don, will try and later today and report back.
disuye
Hong Kong
C?ID=258260
Just a quick update – a combination of coding changes as suggested by both @DV25 and @NEtech has cleared all my outstanding '5F Information Electronics' faults. Thanks, and very much appreciated!
U1014 error was fixed by changing this:
- Byte 17 From 02 to 00
- Byte 24 From 02 to 00
U11B8 error was fixed by this (note the USB port doesn't appear to work, but the error has at least cleared):
- Byte 19 From D4 to 96
02730000FF00000051150001001028001F0207D40120010002 <- My initial 5F coding (first post above)
02730000FF00000051150001001028001F0007960120010000 <- New 5F coding, no errors reported
Now I just need to figure out why the engine temperature isn't showing up on the Performance Monitor and I'm sorted :)
NEtech
C?ID=56995
Can you post a current Autoscan again ?
Even though you told there was an error changing Byte 8 to 21, it is changed in the Autoscan shown in post #4
disuye
Hong Kong
C?ID=258260
Sure – I think this was the last scan:
Saturday,09,March,2019,16:56:56:30140
   Revision: --H13---
Readiness: 1110 0001
          P1734 00 [002] - -
   Coding: 030C0C
   Revision: 00001K06
   Coding: 00A8DD
   Sun Roof:
   Coding: 181801
   Coding: 0031051011
   Coding: 0410
   Coding: 25FFFF
   Coding: 0001
   Coding: 1D0000
   Coding: 8103
   Coding: 050000
   Coding: 2E0000
   Coding: 2E0000
   Coding: 02730000FF00000051150001001028001F0007960120010000
End----(Elapsed Time: 01:24, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
DV52
C?ID=194404
^^^^ so - just to be clear - the fix is like this:
Name   initial 5F coding	New 5F coding
8	51	01010001	51	01010001
19	D4	11010100	96	10010110
disuye
Hong Kong
C?ID=258260
@DV25, yes in my case that worked.
tomekd77
Leonartown, MD, USA
C?ID=342201
MY2015 Golf TSI 1.8 "1543 - Control Module Incorrectly Coded"
I'm having similar error "1543 - Control Module Incorrectly Coded".
I didn't want to start new post. Would the "R" fix be applicable?
I think the Infotainment is different on these two cars.
Thanks in advance.
Saturday,13,April,2019,18:33:01:30494
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: 3VW217AU8FM020225   License Plate:
Mileage: 64019km-39779mi   Repair Order:
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75
VIN: 3VW217AU8FM020225   Mileage: 64019km-39779miles
Address 01: Engine (J623-CXBA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 D    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 091A00122424002F1000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM18TFS0208V0906264D 001003
   ROD: EV_ECM18TFS0208V0906264D_VW37.rod
   VCID: 3D32C01BAC06B0A2F6-8068
Readiness: 1110 1101
   Part No SW: 09G 927 749 D    HW: 09G 927 749 D
   Component: AISIN AG6 G3  109 2866
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 3A38CB07BD28879AD3-806E
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51714000002056
   Coding: 01FA6AA12422096C0079020281C8298056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   VCID: 44C4B5FFCFECC16AB9-8010
   Revision: 00021000    Serial number: 0337494431
   Coding: 030C0C
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00020014100100000005004012111800
   VCID: 73A62623DAC236D2D0-8026
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86582707140802
   Coding: 00111846404182E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00206
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 46C0AFF7F9D0F37AA7-8012
   Component: WWS    140722  043 0581
   Serial number:         140730154514
   Component: RLHS  037 0059
   Serial number: S4Y14M07D03H07M36S34
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO30546700
   Coding: 181801
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00L7MS
   VCID: 51EA8CAB009E24C202-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140000ZSXB05
   Coding: 303337
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 14
   Serial number: 357000000009D1ECDF06
   Subsystem 3 - Part No SW: -----------    HW: 480 000 206 14
   Serial number: 35800000000432E8CF0V
   Subsystem 4 - Part No SW: -----------    HW: 480 400 406 14
   Serial number: 3510002AD156EA03A2A9
   Subsystem 5 - Part No SW: -----------    HW: 480 400 406 14
   Serial number: 35200029D1617D20B18+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 306 14
   Serial number: 3550002C115C421292E.
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 306 14
   Serial number: 35600029915C4212813U
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140530400393
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 044475FF8F6C016AF9-8050
   Part No SW: 5G1 920 840     HW: 5G1 920 840
   Component: KOMBI         243 4270
   Coding: 0BA5191A2180CF0502087A001000000000000000
   VCID: 6484557F6F2CA16A59-8030
   Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2186
   Revision: --------    Serial number: 28061410000338
   Coding: 0101000820085900EF0002081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 41CABCEBD0FED44292-8014
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H14 0101
   Serial number: 27140001463420044263
   Coding: 29FFFF
   Revision: 00000000    Serial number: 14000151463005
   Coding: 5D00000000000000
   VCID: 3424E53F9F4C71EA09-8060
   Serial number: 17071406050AIR
   Coding: 003A13200000040000000000
   VCID: 40CCB9EFDBF4DD4A9D-8014
   Serial number: 00000000000002950015
   Coding: 011000
   Coding: 0102
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401BBF
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001006
   ROD: EV_AMPMst11CALPI.rod
   VCID: 638656636A22A652A0-8036
   Serial number: 090714060502BC
   VCID: 3FCEBA13A60AA2B2E4-806A
   Serial number: 00000000000003008461
   Coding: 191000
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0645
   Serial number: V7B01206143134
   Coding: 027300020000000021220002001800001F010034010001054E
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 699A444B880EFC026A-803C
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS6004BU
   Subsystem 2 - Part No SW: 5G0 919 866 H    HW: -----------
   Component:  NAR 2014/15  --- 0020
          U1014 00 [009] - -
                    Reset counter: 124
                    Mileage: 64019 km
                    Date: 2019.04.13
                    Time: 18:28:49
                    Voltage terminal 30: 12.1 V
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 024873E795780F5ACB-8056
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
Have you previously made any coding changes in this module?
Is the module the original one in the car?
tomekd77
Leonartown, MD, USA
C?ID=342201
Uwe,
Yes, this is original module, but I must have made a change without documenting it properly. Thanks for pointing this out.
Old scan from last year shows Coding: 027300020000000021220002001800001F0100340100010546 vs 027300020000000021220002001800001F010034010001054E.
Looks like this is self inflicted error. No idea why I changed it.
quailallstar
Florida & the Nation's Capital
C?ID=53119
I too have this 1543 - Control Modle Incorrectly Coded error. I've had it as long as I could remember and never have got around to looking into what is wrong.
Safe to assume that I can try the posted fix in post #7?
Unrelated issue (I think). There is a driver profile stuck shown in the radio that I can not erase, modify the name or do anything with. Could this be tied to my error below?
Sunday,06,March,2022,10:30:01:61205
VCDS Version: Release 22.3.0 (x64) Running on Windows 11 x64
                Address 5F: Information Electr.       Labels: 5G0-035-MIB-STD2.clb
Control Module Part Number: 3Q0 035 844 B    HW: 3Q0 035 844 B
  Component and/or Version: MU-S-S-US     722 0867
           Software Coding: 02731000BE00000051220001001828001F0003D401B0050006
            Work Shop Code: WSC 00046 123 12345
              ASAM Dataset: EV_MUStd4CDELP 001001 (VW37)
                       ROD: EV_MUStd4CDELP_VW26.rod
                      VCID: 2E050E489099B42B6DE-807A
          U1014 00 [009] - -
                    Reset counter: 125
                    Mileage: 86944 km
                    Date: 2022.03.06
                    Time: 10:09:41
                    Voltage terminal 30: 12.2 V
2564 - GPS Antenna
          B1054 11 [009] - Short to Ground
          [GPS aerial - short circuit to ground]
                    Reset counter: 125
                    Mileage: 86944 km
                    Date: 2022.03.06
                    Time: 10:09:42
DV52
C?ID=194404
@quailallstar: hmm....... there are 200 individual software switches in the hex 5F module long-code string (i.e. 25 Bytes in total each having 8 x Bits). Any one, or multiples of one could be incorrectly set
I guess there must be a finite possibility that OP fix will also work on your module - but it's drawing a very long bow!
Does the module have voice control and does it have navigation?
PS: Complete auto-scan would help enormously
quailallstar
C?ID=53119
Hey Don,
The unit does not have built-in navigation, but it does have voice control. I'll get a complete auto-scan completed and posted here in the next 24-hours. Thanks!
DV52
C?ID=194404
@quailallstar: OK - then maybe this might be of interest: for your hex5F module, Byte 24 =hex06=0000 0110. Remembering that binary numbers are read from right-to-left (so, Bit 0 is the right=most digit), this means that as currently coded, Bit 1 and Bit 2 are set.
  • Bit 1 is the software switch for Voice Control System - so, this is set correctly
  • Bit 2 is the software switch for Navigation System - so, a "boo-boo" (this is an arcane technical term that's occasionally used in the industry)!! ;)
What needs to happen (I think) is to change Bye24=hex02=0000 0010.
