Hi all.
I'm Richard from The Netherlands and i need help with a light sensor 'problem' on a Audi A3.
A friend of my owns a Audi A3 from 2010 and he wanted a few changes ;
1. Activate Needle Sweep
2. Mirror Dip
3. Oil temp on MFI
4. Turning off Start/Stop ( Voltage limit changed into 12.1v (default 7.6v)
5. Back lights with DRL
1,2,3 and 4 were succesfully changed. But not number 5. I did the following coding :
[09-Board]
[Security Access-16]
Enter code '31347' [Adjust-10]
[Channel 09] choose: 'Leuchte23SL HLC10-Lichtfunktion D23'
Set value to 'active'
[Channel 09] choose: 'Leuchte24SL HRA65-Lichtfunktion D24'
It worked but when i locked the vehicle the taillights stayed on after the coming home timer of 20 seconds. After little bit later the taillights were shut down.
So i changed the coding to the default setting.
The problem now is that suddenly the lights (xenon and taillights) stays on all the time with the switch on AUTO.
It don't matter if the car is in broad daylight or in a pitch black garage. There also is no difference with a running engine or not.
(i did not make any changes in Long coding or in adaptation from the lights or sensor)
Before the codings i did make an Auto Scan. There were some faults and one of them was the rain/light sensor. i've noticed a higher mileage of the sensor in the scan. This was because the front windshield was replaced and also the rain/lightsenor. This was a second hand sensor. But everything was working properly.
After deleting the faults only the tankflap lock comes back.
I really dont know that the problem is or what to do.
I hope you can help me. Thank you in advance.
P.S. Sorry for my bad English.
Best Regards,
Richard
2. Mirror Dip
3. Oil temp on MFI
[09-Board]
Best Regards,
Richard
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1F1086596 Kilometrage: 59589km
01-Motor -- Status: OK 0000
03-ABS Systeem -- Status: Defect 0010
08-Airco/Verwarming -- Status: Defect 0010
09-Centr.Electr. -- Status: Defect 0010
16-Stuurwiel -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
19-CAN-bus Interface -- Status: OK 0000
42-Portierelektr.,LV -- Status: OK 0000
44-Stuurhulp -- Status: OK 0000
52-Portierelectr.,RV -- Status: OK 0000
55-Koplamp Niveau -- Status: OK 0000
5F-Informatie Electr. -- Status: OK 0000
BB-Deur Achter Links -- Status: OK 0000
BC-Deur Achter Rechts -- Status: OK 0000
Adres 01: Motor (J623-CZEA) Labels: 04E-907-309-V1.clb
Onderdeel No SW: 04E 906 027 BL HW: 04E 907 309 AB
Component: 1.4l R4 TSI H21 8235
Revisie: R6H21---
Codering: 02190012242401082000
Werkplaats#: WSC 06385 790 00016
ASAM Dataset: EV_ECM14TFS01104E906027BL 001007
ROD: EV_ECM14TFS01104E906027BL.rod
VCID: 6FBA251AC714C20FC43-803A
CAN omvormer 01:
1 Fout Gevonden:
4511 - Nokkenasstandsensor=>sensor
P0366 00 [096] - Onaannem. Signaal (G300)
Intermitterend - Niet Bevestigd - Getest sinds Geheugen Wissen
Gereedheid: 0000 0000
Adres 03: ABS Systeem (J104) Labels: 5Q0-907-379-IPB-V1.clb
Onderdeel No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revisie: 00000000 Serienummer: 63204000003694
Codering: 13F16AA224282A72017C060941C929C856245480608294F2022100788208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 3D26CF52DDF8609F06F-8068
1 Fout Gevonden:
16401 - Waarschuwing bandenspanning
C102D 00 [008] - -
Intermitterend - Bevestigd - Getest sinds Geheugen Wissen
Bevries Frame:
Fout Status: 00000001
Fout Prioriteit: 2
Fout Frekwentie: 3
Reset teller: 187
Kilometrage: 51230 km
Datum: 2018.06.21
Tijd: 17:18:26
Adres 08: Airco/Verwarming (E87) Labels: 8V0-820-043.clb
Onderdeel No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0060
Revisie: 20027000 Serienummer: 00000000499956
Codering: 03000004000000011000000000001100
VCID: 323CEC6E14A6AFE7EBD-8066
Sensor voor luchtvochtigheid: buiten:
Subsysteem 1 - Onderdeel No SW: 4H0 907 658 HW: 4H0 907 658
Serienummer: 5D290A57000000000001
1 Fout Gevonden:
328964 - Stelmotor luchtverdelingsklep voorin
B1091 71 [008] - Actuator vast
Bevries Frame:
Fout Prioriteit: 2
Fout Frekwentie: 1
Reset teller: 249
Kilometrage: 59131 km
Datum: 2019.02.16
Tijd: 12:35:09
Spanning contact 30: 14.4 V
Interieurtemperatuur: 22.4 °C
Buitentemperatuur: 21 °C
Luchtverdeelklep voorin - werk. waarde: 97.5 %
Luchtverdeelklep voorin - werk. waarde: 119
Luchtverdeelklep voorin - voorg. waarde: 87
Adres 09: Centr.Electr. (J519) Labels: 5Q0-937-08X-HV1.clb
Onderdeel No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serienummer: 01011431001462
Codering: 04040A42C24122FD43C04004001807A80000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 005876A6EA8ACD772D9-8054
Regelapparaat voor wissermotor:
Subsysteem 1 - Onderdeel No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141106 042 0585
Serienummer: 141115045221
Codering: 0A47F7
Sensor voor regen- en lichtherkenning:
Subsysteem 2 - Onderdeel No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serienummer: 23453057
Codering: 00006C
Lichtschakelaar:
Subsysteem 3 - Onderdeel No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Component: E1 - LDS MQB H05 0032
Serienummer: 19 09 2014 00000109
4 Fouten Gevonden:
197644 - Aansturing van tankklepontgrendeling
B1263 01 [009] - Electrische fout
Bevries Frame:
Fout Prioriteit: 4
Fout Frekwentie: 118
Reset teller: 231
Kilometrage: 1048574 km
Datum: 2000.00.00
Tijd: 00:00:00
204290 - Sleutel 1
B1479 18 [008] - Stroom te laag
Bevries Frame:
Fout Prioriteit: 4
Fout Frekwentie: 1
Reset teller: 248
Kilometrage: 46674 km
Datum: 2018.03.05
Tijd: 07:45:09
934148 - Sensor voor regen- en lichtherkenning
U10F6 00 [008] - Geen communicatie
Bevries Frame:
Fout Prioriteit: 2
Fout Frekwentie: 1
Reset teller: 251
Datum: 2000.00.00
Tijd: 00:00:00
939524 - Sensor voor luchtvochtigheid
U10F5 00 [008] - Geen communicatie
Bevries Frame:
Fout Prioriteit: 2
Fout Frekwentie: 1
Reset teller: 251
Datum: 2000.00.00
Tijd: 00:00:00
Adres 15: Airbags (J234) Labels: 5Q0-959-655.clb
Onderdeel No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serienummer: 003MMR02GTA2
Codering: 98CCC0000C0000005C5400CA004800000065
Ongevalsensor voor zij-airbag: bestuurderszijde:
Subsysteem 1 - Onderdeel No SW: ----------- HW: 480 001 411 14
Serienummer: 357670000009E094B11Y
Codering: 2D2D2D
Ongevalsensor voor zij-airbag: bijrijderszijde:
Subsysteem 2 - Onderdeel No SW: ----------- HW: 480 001 411 14
Serienummer: 35867000000D3294B11U
Codering: 2D2D2D
Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
Subsysteem 3 - Onderdeel No SW: ----------- HW: 480 400 511 14
Serienummer: 3516502BF1860BA4B24J
Codering: 2D2D2D
Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
Subsysteem 4 - Onderdeel No SW: ----------- HW: 480 400 411 14
Serienummer: 3526502C91860BC632CJ
Codering: 2D2D2D
Ongevalsensor voorairbag: bestuurderszijde:
Subsysteem 5 - Onderdeel No SW: ----------- HW: 480 400 910 14
Serienummer: 3556502B118166A243B4
Codering: 2D2D2D
Ongevalsensor voetgangersbesch. bestuurderszijde:
Subsysteem 6 - Onderdeel No SW: ----------- HW: 480 400 411 14
Component: PedP_Sensor_D 001 6149
Serienummer: 2286502BD1860BC5633I
Codering: 2D2D2D
Ongevalsensor voetgangersbesch. bijrijderszijde:
Subsysteem 7 - Onderdeel No SW: ----------- HW: 480 400 411 14
Component: PedP_Sensor_P 001 6149
Serienummer: 2296502BB1860BC4125C
Codering: 2D2D2D
Ongevalsensor voetgangersbesch. bestuurderszijde 2:
Subsysteem 8 - Onderdeel No SW: ----------- HW: 480 003 009 14
Component: PedPSensor_D2 001 0887
Serienummer: I0M800000008C60D1114
Codering: 2D2D2D
Ongevalsensor voetgangersbesch. bijrijderszijde 2:
Subsysteem 9 - Onderdeel No SW: ----------- HW: 480 003 009 14
Component: PedPSensor_P2 001 0887
Serienummer: I0N800000008B1A85118
Codering: 2D2D2D
Geen Fout Code Gevonden.
Adres 16: Stuurwiel (J527) Labels: 5Q0-953-549.clb
Onderdeel No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revisie: -------- Serienummer: 18111408491125
Codering: A008
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7CA002568662A997711-8028
Adres 17: Instrumenten (J285) Labels: 5G0-920-XXX-17.clb
Onderdeel No SW: 8V0 920 871 HW: 8V0 920 871
Component: KOMBI H02 4291
Codering: 07A419002B8000080D00E8001000000000000000
VCID: 79AE1B4289509CBF6A7-802C
Adres 19: CAN-bus Interface (J533) Labels: 5Q0-907-530-V1.clb
Onderdeel No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revisie: -------- Serienummer: 03111410800505
Codering: 030100043F0857005B000248080B00000001010000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72BC2C6ED426EFE72BD-8026
Dynamo:
Regelapparaat voor multifunctiestuurwiel:
Subsysteem 2 - Onderdeel No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serienummer: 08 11 2014 C0025973
Regelapparaat voor accubewaking:
Subsysteem 3 - Onderdeel No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serienummer: 74185703001411150278
Adres 42: Portierelektr.,LV (J386) Labels: 5QX-959-X93-42.clb
Onderdeel No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serienummer: 09111402081336
Codering: 001C8F204000040000001002
VCID: 42DCBCAEA4061F677BD-8016
Adres 44: Stuurhulp (J500) Labels: 5Q0-909-144.clb
Onderdeel No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Codering: 8103
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 43D2B9AABB1C166F70B-8016
Adres 52: Portierelectr.,RV (J387) Labels: 5QX-959-X92-52.clb
Onderdeel No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serienummer: 08111401101015
Codering: 001C87204000040000001002
VCID: 41DEB3A2A100047F627-8014
Adres 55: Koplamp Niveau (J431) Labels: 5Q0-907-357.clb
Onderdeel No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revisie: -------- Serienummer: --------------
Codering: 019A000001000000
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75B61772A548F8DF0EF-8020
Adres 5F: Informatie Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
Onderdeel No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 041 0420
Serienummer: A3F01811140814
Codering: 01730101FF0A000021110001000A00002F0004040100010006
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 3A2CC44ECCD657A723D-806E
Sticker met gegevens:
Subsysteem 1 - Onderdeel No SW: 8V0 919 866 C HW: -----------
Component: ECE 2015 --- 0045
Serienummer: --------------------
Beeldscherm 1 voor multimedia:
Subsysteem 2 - Onderdeel No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serienummer: AUZ8Z9EY307XN9
Bedieningseenheid voor multimedia:
Subsysteem 3 - Onderdeel No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serienummer: C1000029091400030353
Adres BB: Deur Achter Links (J388) Labels: Geen
Onderdeel No SW: 5Q0 959 595 D HW: 5Q0 959 595 B
Component: TSG HFS 020 0028
Serienummer: 15101403111039
Codering: 000C87204000040000001002
VCID: 44D0BAB6BE121157491-8010
Adres BC: Deur Achter Rechts (J389) Labels: Geen
Component: TSG HBFS 020 0028
Serienummer: 15101406071024
