Results 1 to 3 of 3
Thread: New to VCDS....No response from controller
    Mar 2019
    Good Morning,
    Just purchased my first VCDS/VAG-COM Diagnostic System (HEX-V2, 3 VIN). Trying to use this on my 2018 VW Tiguan SEL Premium to release EPB to access rear brake pad/rotors. Followed all recommended procedures... Battery Charger, Cycle parking brake but when I attempt to access Module 53 Parking Brake I get "No Response from controller". Any help on this would be much appreciated.
    Autoscan:
    Thursday,07,March,2019,07:48:13:18415
    VIN: 3VV4B7AX9JM004435   License Plate:
    Mileage: 87861km-54594mi   Repair Order:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
              47 4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
    VIN: 3VV4B7AX9JM004435   Mileage: 87861km-54594miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122466010FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00019
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C2135F4C6EFD917825-8068
       Part No SW: 09G 927 158 Q    HW: 09G 927 158
       Component: AISIN AQ8     206 3379
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00454
       ROD: EV_TCMAQ450031_VW32.rod
       VCID: 41DF4400A10DB4FFD13-8014
       Revision: 00000000    Serial number: 51137000000582
       Coding: 0BFA6BA454201B70C57B0303A2C849D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
       Shop #: WSC 01383 790 50316
       VCID: 77ABEAD8BF493A4FAF7-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0439124443
       Coding: 032C2C070F
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98155138
    14222592 - Databus
              [Message ELV_01 missing]
                        Reset counter: 103
                        Terminal_15_Kessy_specified_value: OFF
                        Terminal_15_Kessy_actual_value: OFF
                        Terminal_15_central electric_actual_value: Timeout
                        Terminal_15red_Kessy_specified_value: OFF
                        Terminal_15red_Kessy_actual_value: OFF
                        Terminal_S_Kessy_specified_value: OFF
                        Terminal_S_Kessy_actual_value: OFF
                        Terminal_S_central electric_actual_value: Timeout
                        ZAT_pressed: OFF
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 12.337 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Actuation to the inside: active
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: closed
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5NN 907 044 K    HW: 5NN 907 044 K
       Component: AC Automat    H35 R552
       Revision: 20K08000    Serial number: 00000D00005997
       Coding: 00020024200118001105010C1211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 54F17D544E7F31576A5-8000
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Fault Frequency: 25
                        Reset counter: 94
                        Mileage: 84418 km
                        Date: 2019.01.30
                        Time: 18:14:19
                        Outside air temperature: -11.5 °C
                        Voltage terminal 30: 14.7 V
                        System run time-Engine running time: 253 s
                        System run time-Terminal 15 on: 253 s
                        Air quality status: ERROR
       Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C86420041700QD
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0C41A534D6CF2997F25-8058
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170308  034 0373
       Serial number: 17030521045020
       Component: RLHS  042 0105
       Serial number: S5Y17M04D04H11M23S20
       Coding: 00A8DD
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 0
                        Mileage: 78375 km
                        Date: 2018.11.15
                        Time: 21:43:49
    204546 - Remote key 2
                        Reset counter: 56
                        Mileage: 69935 km
                        Date: 2018.10.08
                        Time: 19:02:52
       Serial number: 000308418617104
       Coding: 0471655011
       VCID: 4BC3662893416EAF3BF-801E
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 320000C158FF8728749C8145304097
       VCID: 3E253FFCD0F3CB07AC1-806A
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 81
                        Mileage: 83446 km
                        Date: 2019.01.19
                        Time: 13:28:53
                        Voltage terminal 15: 14.7 V
                        Control Module temperature: 10 °C
                        Velocity_vehicle_reference: 3.31 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.28 m/s²
    196741 - Sensor for Automatic Distance Control
              [FCTSEN_BLOCKAGE]
                        Reset counter: 105
                        Mileage: 85688 km
                        Date: 2019.02.12
                        Time: 13:52:06
                        Velocity_vehicle_reference: 20.47 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.19 m/s²
    196742 - Sensor for Automatic Distance Control
              [FCTSEN_DEC_BLOCKAGE]
                        Reset counter: 77
                        Mileage: 85694 km
                        Date: 2019.02.12
                        Time: 13:58:20
                        Voltage terminal 15: 14.6 V
                        Control Module temperature: 11 °C
                        Velocity_vehicle_reference: 19.73 m/s
    196743 - Sensor for Automatic Distance Control
              [FCTSEN_INC_BLOCKAGE]
                        Reset counter: 77
                        Mileage: 85676 km
                        Date: 2019.02.12
                        Time: 13:42:48
                        Velocity_vehicle_reference: 20.14 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.56 m/s²
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM059YC9
       Coding: 8CCCFC00000000005000001AC20800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 05579010F5A558DFADB-8050
       Occupant Detection:
       Serial number: IBH00000000000783UU
       Coding: 303352
       Subsystem 2 - Part No SW: -----------    HW: 480 000 704 17
       Serial number: 35700000000257058223
       Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
       Serial number: 35800000000B84FC622X
       Subsystem 4 - Part No SW: -----------    HW: 480 400 704 17
       Serial number: 3510001B524CEFC6F4E
       Subsystem 5 - Part No SW: -----------    HW: 480 400 704 17
       Serial number: 3520001A525672E632F2
       Subsystem 6 - Part No SW: -----------    HW: 480 400 604 17
       Serial number: 3550001C52502AF2F7BE
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 104 17
       Component: FrontSensor_P  000 6149
       Serial number: 35600019D255D292D6CK
       Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
       Component: Lenks. Modul  004 0140
       Revision: --------    Serial number: 21041704401432
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 03538E08FB9166EF83F-8056
       Part No SW: 5NA 920 891 B    HW: 5NA 920 891 B
       Component: KOMBI         406 3192
       Coding: 0BA4001AEF88CF0502886B0B5401000020000000
       VCID: 43D34E08BB11A6EFC3F-8016
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Fault Frequency: 48
                        Reset counter: 101
                        Mileage: 78042 km
                        Date: 2018.11.13
                        Time: 20:12:18
       Component: GW MQB High   518 5286
       Serial number: 26051700840138
       Coding: 030500347F085900FB07225A1E0F00010001050000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 2F3B12B80799328F377-807A
       Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
       Serial number: 0971718391101839BO2B
       Coding: 2E0000
       Serial number: 0377873604
       Serial number: HA1-00025.01.17
       Coding: 0101
       VCID: 4ACD632C9C3B77A7009-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45D75010B52598DFEDB-8010
       Serial number: 17000099839012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD4C0D12D647F613-8024
       Component: Sitzmemory    H08 0021
       Serial number: Y0006QD422694
       Coding: 0010000000000500018280808080000000008101000000F400
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                        Reset counter: 107
                        Mileage: 87858 km
                        Date: 2019.03.06
                        Time: 12:46:41
       Component: HRE_Master    H12 0080
       Serial number: 0438947047
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D2738F0DDF5D01FB5B-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0437103107
       Coding: 020111
       Component: TSG FS        010 0032
       Serial number: 5028711600345
       Coding: 003F1B205200028000000000
       VCID: 47CB5A188F298ACF1F7-8012
       Revision: 00000000    Serial number: 0001665557
       Coding: 01000011004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
       VCID: 40D94104AA07BDF7DED-8014
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H30 0150
       Revision: 00000001    Serial number: VWZ8Z1HBA03AZ4H
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6D87C8B0CD15809F45B-8038
       Component: FCM MQB Low   001 0285
       Serial number: 05041700840372
       Coding: 0000000501001D5200210F01090000000000000000000000000000000000
       VCID: 72BDDBCCD42B5F67989-8026
       Component: TSG BFS       010 0032
       Serial number: 6028706600277
       Coding: 003F13205E00028000000000
       VCID: 46D5571C882393C7E41-8012
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0755
       Coding: 027306020000000051220002001808001F0500E401200005C6
       Shop #: WSC 00066 790 00442
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 323D1BCC14AB1F67589-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8120
       Serial number: VWZ6ZHT1262966
       Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
              B11CF 53 [009] - Deactivated
                        Reset counter: 243
                        Mileage: 64014 km
                        Date: 2018.09.08
                        Time: 14:29:15
                        Voltage terminal 30: 12.2 V
                        SDARS_tuner_status_2-Antenna current: 135 mA
                        SDARS_tuner_status_2-Reception quality: weak_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
       Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
       Component: Areaview 2    H13 0607
       Serial number: C854707JG011168
       Coding: 01230601A20F20000000400C
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       VCID: 382929E4F2D7F53766D-806C
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0A28
       VCID: 42DD4B0CA40BAFE7C89-8016
       Component: OCULowMQBUS   007 0570
       Coding: 02230602C2823A037F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 04041711K21371
       Coding: 0003070601020201002213548050490084000E200020
       VCID: 3B2336E8C3E1DE2F8BF-806E
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       012 0032
       Serial number: 0000251246358
       Coding: 002011200101028000000000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       VCID: 49CF5C20993D7CBF093-801C
       Component: TSG HBFS      012 0032
       Serial number: 0000251246356
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
       Component: SAD_STG_1     013 0005
       Coding: 00804073260C
       VCID: 1675C75C9803E347541-8042
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:25, VBatt start/end: 14.8V/14.8V)-----------
    Nov 2017
    Latvia
    Are you sure you got right instructions?
    There is no "53" before actual autoscan. See next line after "Chassis Type: AX-VW37 (3Q0)".
  3. Likes Uwe liked this post
    This is a newer, MQB Tiguan, with an MK100IPB. I think IPB stands for "Integrated Parking Brake".
    This instructions should apply:
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
  5. Likes Eric liked this post
