New to VCDS....No response from controller
Good Morning,
Just purchased my first VCDS/VAG-COM Diagnostic System (HEX-V2, 3 VIN). Trying to use this on my 2018 VW Tiguan SEL Premium to release EPB to access rear brake pad/rotors. Followed all recommended procedures... Battery Charger, Cycle parking brake but when I attempt to access Module 53 Parking Brake I get "No Response from controller". Any help on this would be much appreciated.
Autoscan:
Thursday,07,March,2019,07:48:13:18415
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: 3VV4B7AX9JM004435 License Plate:
Mileage: 87861km-54594mi Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
47 4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AX9JM004435 Mileage: 87861km-54594miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 5NA 907 115 A HW: 06L 907 309 B
Component: R4 2.0l TFSI H30 0004
Revision: 1DH30000
Coding: 012A00122466010FB4000000000000000000000000000000
Shop #: WSC 00066 790 00019
ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
ROD: EV_ECM20TFS0115NA907115A.rod
VCID: 3C2135F4C6EFD917825-8068
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 Q HW: 09G 927 158
Component: AISIN AQ8 206 3379
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00454
ROD: EV_TCMAQ450031_VW32.rod
VCID: 41DF4400A10DB4FFD13-8014
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 51137000000582
Coding: 0BFA6BA454201B70C57B0303A2C849D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
VCID: 77ABEAD8BF493A4FAF7-8022
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0439124443
Coding: 032C2C070F
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98155138
14222592 - Databus
[Message ELV_01 missing]
Reset counter: 103
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
ZAT_pressed: OFF
Park selector lever position: Engaged and locked
Enabling immobilizer: Condition not met
Control Module Voltage: 12.337 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Actuation to the inside: active
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 K HW: 5NN 907 044 K
Component: AC Automat H35 R552
Revision: 20K08000 Serial number: 00000D00005997
Coding: 00020024200118001105010C1211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 54F17D544E7F31576A5-8000
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Frequency: 25
Reset counter: 94
Mileage: 84418 km
Date: 2019.01.30
Time: 18:14:19
Outside air temperature: -11.5 °C
Voltage terminal 30: 14.7 V
System run time-Engine running time: 253 s
Air quality status: ERROR
Part No SW: 5Q0 937 087 AS HW: 5Q0 937 087 AP
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C86420041700QD
ROD: EV_BCMBOSCH_018.rod
VCID: 0C41A534D6CF2997F25-8058
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 170308 034 0373
Serial number: 17030521045020
Component: RLHS 042 0105
Serial number: S5Y17M04D04H11M23S20
Coding: 00A8DD
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 0
Mileage: 78375 km
Date: 2018.11.15
Time: 21:43:49
204546 - Remote key 2
Reset counter: 56
Mileage: 69935 km
Date: 2018.10.08
Time: 19:02:52
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617104
Coding: 0471655011
VCID: 4BC3662893416EAF3BF-801E
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 320000C158FF8728749C8145304097
VCID: 3E253FFCD0F3CB07AC1-806A
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 81
Mileage: 83446 km
Date: 2019.01.19
Time: 13:28:53
Voltage terminal 15: 14.7 V
Control Module temperature: 10 °C
Velocity_vehicle_reference: 3.31 m/s
Longitudinal_acceleration_vehicle_reference: -0.28 m/s²
Status_ACC_System: ACC_Off_MainSwitch_Off
196741 - Sensor for Automatic Distance Control
[FCTSEN_BLOCKAGE]
Reset counter: 105
Mileage: 85688 km
Date: 2019.02.12
Time: 13:52:06
Velocity_vehicle_reference: 20.47 m/s
Longitudinal_acceleration_vehicle_reference: 0.19 m/s²
196742 - Sensor for Automatic Distance Control
[FCTSEN_DEC_BLOCKAGE]
Reset counter: 77
Mileage: 85694 km
Date: 2019.02.12
Time: 13:58:20
Voltage terminal 15: 14.6 V
Control Module temperature: 11 °C
Velocity_vehicle_reference: 19.73 m/s
196743 - Sensor for Automatic Distance Control
[FCTSEN_INC_BLOCKAGE]
Reset counter: 77
Mileage: 85676 km
Date: 2019.02.12
Time: 13:42:48
Velocity_vehicle_reference: 20.14 m/s
Longitudinal_acceleration_vehicle_reference: -0.56 m/s²
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM059YC9
Coding: 8CCCFC00000000005000001AC20800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 05579010F5A558DFADB-8050
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000783UU
Coding: 303352
Subsystem 2 - Part No SW: ----------- HW: 480 000 704 17
Serial number: 35700000000257058223
Subsystem 3 - Part No SW: ----------- HW: 480 000 704 17
Serial number: 35800000000B84FC622X
Subsystem 4 - Part No SW: ----------- HW: 480 400 704 17
Serial number: 3510001B524CEFC6F4E
Subsystem 5 - Part No SW: ----------- HW: 480 400 704 17
Serial number: 3520001A525672E632F2
Subsystem 6 - Part No SW: ----------- HW: 480 400 604 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C52502AF2F7BE
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 104 17
Component: FrontSensor_P 000 6149
Serial number: 35600019D255D292D6CK
Part No SW: 5Q0 953 507 JF HW: 5Q0 953 549 D
Component: Lenks. Modul 004 0140
Revision: -------- Serial number: 21041704401432
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 03538E08FB9166EF83F-8056
Part No SW: 5NA 920 891 B HW: 5NA 920 891 B
Component: KOMBI 406 3192
Coding: 0BA4001AEF88CF0502886B0B5401000020000000
VCID: 43D34E08BB11A6EFC3F-8016
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Fault Frequency: 48
Reset counter: 101
Mileage: 78042 km
Date: 2018.11.13
Time: 20:12:18
Component: GW MQB High 518 5286
Serial number: 26051700840138
Coding: 030500347F085900FB07225A1E0F00010001050000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F3B12B80799328F377-807A
Subsystem 2 - Part No SW: 5NN 959 442 A HW: 5NN 959 442 A
Component: E221__MFL-TAT H06 0023
Serial number: 0971718391101839BO2B
Coding: 2E0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 0377873604
Serial number: HA1-00025.01.17
Coding: 0101
VCID: 4ACD632C9C3B77A7009-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45D75010B52598DFEDB-8010
Component: ELV-MQBB H05 0032
Serial number: 17000099839012
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD4C0D12D647F613-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0021
Serial number: Y0006QD422694
Coding: 0010000000000500018280808080000000008101000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
Reset counter: 107
Mileage: 87858 km
Date: 2019.03.06
Time: 12:46:41
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0438947047
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D2738F0DDF5D01FB5B-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0437103107
Coding: 020111
Component: TSG FS 010 0032
Serial number: 5028711600345
Coding: 003F1B205200028000000000
VCID: 47CB5A188F298ACF1F7-8012
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001665557
Coding: 01000011004001
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 40D94104AA07BDF7DED-8014
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1HBA03AZ4H
VCID: 6D87C8B0CD15809F45B-8038
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 05041700840372
Coding: 0000000501001D5200210F01090000000000000000000000000000000000
VCID: 72BDDBCCD42B5F67989-8026
Component: TSG BFS 010 0032
Serial number: 6028706600277
Coding: 003F13205E00028000000000
VCID: 46D5571C882393C7E41-8012
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0755
Coding: 027306020000000051220002001808001F0500E401200005C6
Shop #: WSC 00066 790 00442
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323D1BCC14AB1F67589-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8120
Serial number: VWZ6ZHT1262966
Subsystem 2 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
B11CF 53 [009] - Deactivated
Reset counter: 243
Mileage: 64014 km
Date: 2018.09.08
Time: 14:29:15
Voltage terminal 30: 12.2 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Not available
SDARS_tuner_status_2-Antenna current: 135 mA
SDARS_tuner_status_2-Reception quality: weak_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 B HW: 5Q0 907 556
Component: Areaview 2 H13 0607
Serial number: C854707JG011168
Coding: 01230601A20F20000000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
VCID: 382929E4F2D7F53766D-806C
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
Coding: 0A28
VCID: 42DD4B0CA40BAFE7C89-8016
Component: OCULowMQBUS 007 0570
Coding: 02230602C2823A037F1E06020000
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 04041711K21371
Coding: 0003070601020201002213548050490084000E200020
VCID: 3B2336E8C3E1DE2F8BF-806E
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000251246358
Coding: 002011200101028000000000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 49CF5C20993D7CBF093-801C
Component: TSG HBFS 012 0032
Serial number: 0000251246356
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 00804073260C
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675C75C9803E347541-8042
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:25, VBatt start/end: 14.8V/14.8V)-----------
Are you sure you got right instructions?
There is no "53" before actual autoscan. See next line after "Chassis Type: AX-VW37 (3Q0)".
Post Thanks / Like - 1 Likes
Uwe liked this post
This is a newer, MQB Tiguan, with an MK100IPB. I think IPB stands for "Integrated Parking Brake".
This instructions should apply:
http://wiki.ross-tech.com/wiki/index...#Basic_Setting
Eric liked this post
