Results 1 to 6 of 6
Thread: Superb 3 and code lane assist
    Feb 2019
    Slovakia
    Hello everybody.
    I would like ask you if mentioned car have all necessary HW for coding of line assist or not .It is superb 3v 2016.Is it enough A5 camera or not ? please check autoscan too.
    Thursday,28,February,2019,10:15:47:43301
    VIN: TMBJH9NP0G7061597   License Plate: PETOSUPERB
    Mileage: 165405km-102777mi   Repair Order:
    Chassis Type: NP-SK48 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 36 42 44 52 55 5F 69 6C 6D
              A5 BB BC CA
    VIN: TMBJH9NP0G7061597   Mileage: 165405km-102777miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H22 1990
       Revision: B5H22---
       Coding: 011D0012047401082000
       Shop #: WSC 33361 790 00063
       ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
       ROD: EV_ECM20TDI01104L906026FL.rod
       VCID: 0058753CCA8991579ED-8054
              U0428 00 [032] - -
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [032] - Implausible Signal
       Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4905
       Revision: 06253104    Serial number: TFK01601150122
       ROD: EV_TCMDQ250021.rod
       VCID: 1D662C485D3B5CBF95B-8048
    9 Faults Found:
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21154 - Gear 2
              P072D 00 [002] - Not Selectable
    21155 - Gear 3
              P072E 00 [002] - Not Selectable
    21156 - Gear 4
              P072F 00 [002] - Not Selectable
    21157 - Gear 5
              P073A 00 [002] - Not Selectable
    21159 - Gear R
              P072B 00 [002] - Not Selectable
    10731 - Valve 3 in Transmission Part 1
              P174A 00 [002] - Electrical malfunction
    10732 - Valve 3 in Transmission Part 2
              P174E 00 [002] - Electrical malfunction
    10906 - Cooling Oil Valve
              P179D 00 [002] - Electrical Malfunction
       Revision: 00000000    Serial number: 60256000000220
       Coding: 1E076A9C34260B6D077C060941CA4978562CD0E0608292F51861F078C202
       VCID: 7AAC07D4AC55CB87D09-802E
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 103
                        Mileage: 158906 km
                        Date: 2018.10.27
                        Time: 12:16:42
       Part No SW: 3V0 907 044 AR    HW: 3V0 907 044 AR
       Component: AC Automat    H32 3701
       Revision: 20K05000    Serial number: 00000B00064955
       Coding: 12010104002100011005000000101002
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_ACClimaPrehVW37X 002012
       ROD: EV_ACClimaPrehVW37X_SK37.rod
       VCID: 0450792CDE918D77BA5-8050
    263425 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Reset counter: 157
                        Mileage: 152908 km
                        Date: 2018.09.24
                        Time: 10:48:15
                        Outside air temperature: 15.5 °C
                        Voltage terminal 30: 11.8 V
                        System run time-Terminal 15 on: 253 s
                        Air quality status: ERROR
       Serial number: 01061603608001
       Coding: 0CD21A46C2C722FB57C44004001C57280000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: 48x LL 160122  032 0121
       Serial number: 00000001601200303124
       Coding: 165DDD
       Component: RLHS  037 0059
       Serial number: S5Y16M02D08H20M37S05
       Coding: 00084D
    204546 - Remote key 2
                        Reset counter: 107
                        Mileage: 163798 km
                        Date: 2019.01.08
                        Time: 16:51:46
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391603303543
       Coding: 0071151951
       Shop #: WSC 35110 377 09999
       VCID: 44D0B92C9E114D77FA5-8010
       Component: ACC BOSCH MQB H04 0192
       Coding: 320067CA51FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3430E9ECCEB1FDF74A5-8060
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 179
                        Mileage: 164765 km
                        Date: 2019.02.13
                        Time: 16:40:49
                        Control Module temperature: 18 °C
                        Voltage terminal 15: 14.4 V
                        Velocity_vehicle_reference: 16.52 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.12 m/s²
       Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
       Component: AirbagVW21    005 0130
       Serial number: 003NSR1EWXXM
       Coding: 98FCC0C0000000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 03527A30DB9F8A4F83F-8056
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3V0857701C0040Q01566
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3V0857702C0041Q00174
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 000 202 16
       Serial number: 35700000000AD42DE81.
       Subsystem 4 - Part No SW: -----------    HW: 480 000 202 16
       Serial number: 35800000000BD8E0091T
       Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
       Serial number: 35100029F18166C60290
       Subsystem 6 - Part No SW: -----------    HW: 480 400 502 16
       Serial number: 35200029F18166C38296
       Subsystem 7 - Part No SW: -----------    HW: 480 400 202 16
       Serial number: 3550002B71E9F0E2F36Q
       Part No SW: 5Q0 953 521 GB    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160205400722
       Coding: 6410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 78A81DDC9259D997A6D-802C
       Part No SW: 3V0 920 751     HW: 3V0 920 751
       Component: KOMBI         313 6422
       Coding: 07A5090A2F84000801887A091000000000000000
       Shop #: WSC 73430 031 00063
       VCID: 71BE20F8F12388DF613-8024
    16777008 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_SWA_0x1A keine Kommunikation]
                        Reset counter: 107
                        Mileage: 163801 km
                        Date: 2019.01.11
                        Time: 19:45:05
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 06021610803459
       Coding: 030100345F087300EB00025E1C0F00010001070000000000000000000000
       Shop #: WSC 33361 790 00068
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 79AE18D8A953C09FD93-802C
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000D1581270116
       Serial number: 3546799103
       Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
       Component: Sitzmemory    H06 0009
       Serial number: Y0006PAN13259
       Coding: 001000000000010001A080808080000000008181000000D4
       ASAM Dataset: EV_SeatMemorDriveSide 001015
       ROD: EV_SeatMemorDriveSide_001.rod
       VCID: 3B22C2D0E3EF328F8BF-806E
       Serial number: 161215ELF08385
       Coding: 001D0920DE00048000001100
       VCID: 43D2BA309B1F4A4FC3F-8016
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000599272
       Coding: 01000010005001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3D26CCC8FDFB3CBFB5B-8068
       Serial number: 191215ELI1077A
       Coding: 001D0320DE00048000001100
       VCID: 42DCBF3484054347C89-8016
       Coding: 06DA00003F010000
       VCID: 40D8B53C8A095157DED-8014
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0006
       Coding: B20000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0006
       Coding: B20000
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 021 B    HW: 3V0 035 021
       Component: MU-H-LND-EU   H50 0318
       Serial number: A674B0GB006184
       Coding: 03840201FF0000001111120100880A102F0000C4012001009E
       Shop #: WSC 33361 790 00030
       VCID: 261403A4086D9F67C41-8072
       Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
       Component: ABT_High-2  H46 1031
       Serial number: SKZ8Z9SFP00740
       Subsystem 2 - Part No SW: V03 959 801 JR    HW: -----------
       Component: ECE 2019  --- 0175
       Component: Gracenote2  --- 1012
       Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
       Component: Anhaenger     H21 0203
       Revision: 8B001003    Serial number: 0393013403
       Coding: 0100000202000000
       VCID: 3C20C1CCE6E135B7825-8068
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 04840201A3002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW41.rod
       VCID: 77AA1EE09F47D6EFAF7-8022
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30452295800000
       Coding: 0D80
       ASAM Dataset: EV_DeckLidCONTIAU736 001012
       ROD: EV_DeckLidCONTIAU736_VW41.rod
       VCID: 3FDAB6C0F7F72EAFA77-806A
       Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0024
       Serial number: 30011611K11384
       Coding: 0204080200000401002223458040A00010000E100000
       VCID: 3828DDDCD2D9199766D-806C
    0645 - Windscreen Heater for Front Sensors
              B11CE 15 [008] - Open or Short to Plus
                        Fault Frequency: 188
                        Reset counter: 197
                        Mileage: 163764 km
                        Date: 2018.12.13
                        Time: 12:31:38
                        Control Module temperature: 43 °C
                        Outside air temperature: 15.0 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 2428.0 s
                        Voltage terminal 15: 10.4 V
                        mid: 00 58
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 4
                        Software_Info_3: 2
                        Software_Info_2: 0
                        Software_Info_1: 0
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 130116BAD02406
       Coding: 001801208000048000001100
       Serial number: 130116BAD02403
       Part No SW: 4M0 907 594 D    HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 208040648202
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 372ADEE0DFC716EF6F7-8062
    End----------(Elapsed Time: 01:45, VBatt start/end: 14.5V/14.5V)-----------
    Jun 2017
    Lane Change assist or Lane Departure Warning Assist?
  3. Likes Uwe liked this post
    Feb 2019
    Slovakia
    What is different between? I would like holding car in lane. Is it possible ? Do we have some manual which is tested?
    Dec 2016
    DE
    That would be Lane Departure Warning alias Lane Assist.
    This thread here should help you: https://forums.ross-tech.com/showthr...da-Superb-2018
    May 2016
    I have other question. Can you provide me adaptionmaps of 09? I retrofit this headlights. Hope you can help me.
    Regards
    Jun 2017
    Quote Originally Posted by vastechnics View Post
    Regards
    Open a new thread please. This has nothing to do with this topic.
  8. Likes Uwe liked this post
