DRLs inactive when light switch at '0' position.
AlixKaur
C?ID=198164
Hi Folks,
Last week I found an option in VCDS to turn off the DRL's in my fathers VW Caddy Maxi Life, when the light switch was in the '0' position (totally to the left). I enabled/disabled it and it worked immediately as expected.
Now a week later dad has decided he would like the DRLs on all the time again (even when the light switch is all the way off) and for the life of me I cannot find the option within VCDS to leave this function back the way it was!
I was sure it was just a tick box with Cent-Electrics, but I have been through it with a fine tooth comb and cannot see the option. It's like it has disappeared!
I was literally something like "DRLs inactive when light switch at 0 position" or something very similar. I have found some options mentioning DRLs but nothing about what Im looking for.
Am I blind or has VCDS changed in the last week!?
I am using the new HEX-CAN V2 interface and the vehicle is just a few weeks old so 2019.
Thanks!
AlixKaur
C?ID=198164
Here is a full autoscan I completed on the car on the day dad brought it home. Please ignore the two faults as these didn't return once I cleared them.
Friday,01,March,2019,15:43:25:15959
VIN: [removed]   License Plate:
Mileage: 670km-416mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
VIN: WV2ZZZ2KZKX069396   Mileage: 670km-416miles
Address 01: Engine (J623-DFSB)       Labels: None
   Part No SW: 04L 906 016 KK    HW: 04L 907 309 AB
   Component: R4 2.0l TDI   H20 6642
   Revision: 8EH20---
   Coding: 011D0032046515090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01104L906016KK 004005
   ROD: EV_ECM20TDI01104L906016JS.rod
   VCID: 7CA1F6BE76688297C25-8028
   Part No SW: 02E 300 066 M    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 5210
   Revision: 06454104    Serial number: 00001812050456
   Shop #: WSC 35110 377 08192
   VCID: 2313EDC2A7D61D6FA3F-8076
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 60029000000484
   Coding: 1479409BB268B4872878027F4D882DD379F7F0
   VCID: 40D9424E5A002677DED-8014
   Part No SW: 1K8 907 426 AS    HW: 1K8 907 426 AS
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004083
   ROD: EV_ACManueBHBVW36X_VW32.rod
   VCID: 04518E5E0E98FA57BA5-8050
   Part No SW: 5K0 937 086 AD    HW: 5K0 937 086 AD
   Component: BCM PQ35 M+   122 0193
   Revision: BD122001
   Coding: 491A0A3E8025E16B088800839440016403D10008426F8720648087000041
   VCID: 76B5E49648C4D8C7B41-8022
   Subsystem 1 - Part No: 2K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 02011  61  0715
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 090119 05  50  0106
   Coding: 0228DD
   Subsystem 3 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0009
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39461831000162
   Coding: 0131161051
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: 3B2335A233E645AF8BF-806E
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1001190452AEF3
   Coding: 00001000FE0339
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3635249608C498C7741-8062
          U1101 00 [008] - Active
          [FAULT_ATP_IKA_FAILED]
                    Reset counter: 44
                    Mileage: 246 km
                    Date: 2019.02.24
                    Time: 15:57:18
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 16.41 m/s
                    Acceleration: 0.29 m/s²
0110 - Transport Mode Active
          U1105 00 [008] - -
          [FAULT_SCM_T_MODE_ACTIVE]
                    Fault Frequency: 25
                    Reset counter: 41
                    Mileage: 5 km
                    Date: 2019.01.24
                    Time: 05:04:31
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 12.4 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 2K5 959 655 E    HW: 2K5 959 655 E
   Component: VW10Airbag00K 010 0018
   Revision: --------    Serial number: 003EN00269U1
   Coding: 00000000000000000000000000000000304B
   VCID: 3E253CB620F45087AC1-806A
   Serial number: 3497ARB405J5MM6O3HH0
   Serial number: 3507ARB405P5MJ8IGI1W
   Serial number: 3517ARB405J5MM6OAGK2
   Serial number: 3527ARB40535MJ8KJA08
   Part No SW: 5K0 953 521 FG    HW: 5K0 953 569 BC
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20190108200487
   Coding: 1882C60008
   ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 76B5E4964844D8C7B41-8022
   Subsystem 1 - Part No SW: 2K0 959 442 A    HW: 2K0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 3511815333801470BC1B
   Coding: 2C0000
   Part No SW: 2K5 920 976 J    HW: 2K5 920 976 J
   Component: KOMBI         H02 2030
   Coding: 110A011200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 3D273BBA2DF24B9FB5B-8068
          [ECU component protection active]
                    Reset counter: 44
                    Mileage: 246 km
                    Date: 2019.02.24
                    Time: 15:57:17
   Part No SW: 7N0 907 530 BQ    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1691
   Revision:   H56       Serial number: 050119F1001845
   Coding: 357431
   VCID: 0059824E1A00E6779ED-8054
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A8DC0E60CFC0C27209-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71BFD78A2DAAFFFF613-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 315    3501
   Revision: 00H22000
   VCID: 392F2FAA355A77BF993-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72BDD88628ACC4E7989-8026
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0475
   Serial number: VWZAZ2W0714335
   Coding: 06330701BE00000011111101008808001F0100D600200100CF
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2517F3DAA562E35FCDB-8070
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 41
                    Mileage: 13 km
                    Date: 2019.02.13
                    Time: 01:38:43
                    Voltage terminal 30: 12.6 V
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1691
   Coding: 030F7873
   VCID: 71BFD78A21AAFFFF613-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75885803001812170622
End----(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
AlixKaur
C?ID=198164
I think its possible the option I am looking for is
"Select daytime running lights only in switch position auto"
I found this from some googling but it mentions inputting a security code to access this, which I definitely didnt do the first time around.
AlixKaur
C?ID=198164
Thanks for that Uwe. I actually made a note of the codes before I changed anything. And I have now looked at the two logs you suggested from that link and I can see what codes were changed to what.
I am aware that when you tick or untick boxes this then changes the long code, which is recorded. Does VCDS record the individual options in a plain English format anywhere? So instead of telling me 11222333444555 was changed to 55544433322111 it would tell me that Cornering lights were enabled when turning the wheel or whatever the listing is beside the tick box.
Thanks for your help.
Oh and actually, from your experience over the years, would there be any chance that changing the instrument cluster from UK to ROW would some how make some tick boxes 'disappear'? As this is something that I did do in order to get the large digital MPH up in the MFD.
AlixKaur
C?ID=198164
In addition to my previous question (sorry for asking another before you have had time to answer my previous) would the newer HEX-CAN V2 show different options than the older HEX-CAN, for the same control module? As I believe I changed this mystery option with the older interface, realised it couldnt access all the control modules, then purchased the new interface which Im using now.
I know the newer one gives access to more modules but regarding the same module that can be accessed with both interfaces, can options be different depending what interface you use?
Thanks.
No, it does not.
No, I don't see how it could.
New interfaces support a different data source for coding of UDS modules, but your 09: Cent. Elect. (J519) is not a UDS module, so that's not applicable at all.
AlixKaur
C?ID=198164
Thanks Uwe.
Dana
Western PA, USA
Based on that PQ35 BCM I'd say the Audi tweak applied
Daytime Running Lights enabled with OFF and Auto switch positions - common when importing vehicles from the US -to- Canada
Disable "Daytime Running Light (DRL) only active with Assistance Driving Light (ADL) active"
We don't have that on the Golf 6 page - but back when I created it NAR Golfs/GTIs weren't equipped with RLS sensors. I suppose I could add that to this page.
Edit, I added that to the Golf 6 page and the Long Coding Helper text is identical (Byte 26, Bit 3) to the 8P BCM.
AlixKaur
C?ID=198164
Thanks for commenting Dana. I did notice that "Daytime Running Light (DRL) only active with Assistance Driving Light (ADL) active" option but I cannot remember if the box was ticked or unticked. I do remember thinking at the time that ticking (or unticking) it would not have the desired effect, but perhaps I was thinking about it wrong. I also don't think the original box that I ticked (or unticked) had the word 'adaptive' or 'assistance' in it.
I think that a good idea for me, is that before I tick or untick any box in the future, to take 10 seconds and just snap a quick picture with my smartphone!
I really appreciate your comment.
Bakhtiyar
Iraq
C?ID=356829
LEDs Lights Front & Rear
Hello Sirs
I have a problem with LEDs from top of front & rear which they are working properly before and you can see from below links ( not my car but same style) .
also you can see auto scan. I will appreciate you to help me for them.
now , front ( left/right)side doesn't working and Rear (right/left)side also doesn't working , how can I know which of options are right for my car from long coding Helper or any where .
https://www.google.com/search?biw=9...gws-wiz-img.9xzkjNDQV78#imgrc=nXYaF42I-qbxTM:
https://www.google.com/search?biw=9...gws-wiz-img.4uVMipSm1wU#imgrc=cMi6f2XDZZTL4M:
https://www.google.com/search?biw=9...gws-wiz-img.0NOdKt17-Z4#imgrc=CXKB-HdlG77lUM:
Monday,11,March,2019,17:21:39:31085
VCDS Version: 18.9.0.2  HEX-NET CB: 0.4437.4
VIN: WVWCR7A32HC013413   License Plate:
Mileage: 26480km-16453mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 46 47 4F 52 5F
          62 65 72
VIN: WVWCR7A32HC013413   Mileage: 26480km-16453miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CCC)       Labels: None
   Part No SW: 07K 906 055 EE    HW: 07K 907 309 B
   Component: 2,5L 125KW      G01 1501
   Revision: T4H07---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 75A2E6731CB85BE2F6-8020
049409 - No Communication with Transmission Control Module
               U0101 - 000 -  - Intermittent
                    Mileage: 26222 km
                    Date: 2019.03.03
                    Time: 05:08:58
                    RPM: 988 /min
                    Load: 22.3 %
                    Temperature: 90.0°C
                    Temperature: 69.0°C
                    Absolute Pres.: 960.0 mbar
   Part No SW: 09G 927 750 NH    HW: 09G 927 750 NH
   Component: AQ 250 6F           2623
   Revision: 00H97000    Serial number:
   Coding: 0000328
   VCID: 04448BB74762726AF1-8050
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5892308FDA30F03E5911C10612010F019
   VCID: 75A2E673DCB85BE2F6-8020
                    Reset counter: 1
                    Date: 2019.03.03
                    Time: 10:51:31
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 50176
                    Count: 256
02214 - Tire Pressure Warning
                    Reset counter: 9
                    Date: 2019.03.03
                    Time: 10:51:31
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 16401
                    Count: 50176
                    Count: 256
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0408651272
   Coding: 032C0C
   VCID: 3A38354FBD26F49ADB-806E
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
          [Weckleitung vom Steuergerät für Zugang- und Startberechtigung Unterbrechung/Kurzschluss nach Masse]
                    Reset counter: 9
                    Time: 00:00:00
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0010019002
   VCID: 5AF895CF5D66149AFB-800E
   Part No SW: 5K0 937 087 AK    HW: 5K0 937 087 AK
   Component: BCM PQ35 H++  122 0184
   Revision: BM122001
   Coding: 68200E3B882908D4808804043400816802F1000645A00DB0E4806804AC70
   VCID: 7EB0F95FE98E18BAA7-802A
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 020716 04  42  0106
   Coding: 0038DD
13 Faults Found:
00059 - Terminal 30 for Interior Lighting
                    Fault Status: 00101011
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:04:50
                        Term 15 Off
                    Voltage: 12.70 V
                    Reset counter: 9
                        Term 15 Off
                    Voltage: 12.85 V
00834 - Signal for Activation of Heated Rear Window
                    Fault Status: 00101001
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:07:23
                        Term 15 Off
                    Voltage: 12.60 V
00927 - Terminal 30 (Right)
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:19:44
                        Term 15 Off
                    Voltage: 12.70 V
                    Fault Status: 00101010
                    Fault Frequency: 18
                    Reset counter: 13
                    Mileage: 26246 km
                    Date: 2019.03.06
                    Time: 07:03:05
                        Term 15 Off
                    Voltage: 12.70 V
                    Fault Frequency: 16
                    Reset counter: 13
                    Mileage: 26290 km
                    Date: 2019.03.08
                    Time: 04:32:25
                        Term 15 Off
                    Voltage: 13.15 V
01516 - Terminal 30; Left
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:19:43
                        Term 15 Off
                    Voltage: 12.70 V
01800 - Light Switch (E1)
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 10:11:31
                        Term 15 Off
                    Voltage: 12.65 V
02391 - Terminal 30 Reference
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:07:23
                        Term 15 Off
                    Voltage: 12.60 V
03266 - Control Circuit for Signal Horn
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:07:23
                        Term 15 Off
                    Voltage: 12.60 V
03396 - Supply voltage terminal 30 for central locking
                    Reset counter: 9
                    Mileage: 26393 km
                    Date: 2019.03.10
                    Time: 00:03:01
                        Term 15 Off
                    Voltage: 12.60 V
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101010
                    Fault Frequency: 9
                    Reset counter: 228
                    Mileage: 26222 km
                    Date: 2019.03.03
                    Time: 10:51:35
                        Term 15 On
                    Voltage: 13.75 V
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Reset counter: 215
                    Mileage: 26222 km
                    Date: 2019.03.03
                    Time: 10:51:35
                        Term 15 On
                    Voltage: 13.75 V
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331618300622
   Coding: 0071155051
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   VCID: 373E2C7B8E34E9F224-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM07M5LB
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW41.rod
   VCID: 6386A82B6A2CD552A8-8036
   Serial number: IBH000000000005MMN2Y
   Coding: 30324D
   Subsystem 2 - Part No SW: -----------    HW: 480 001 006 16
   Serial number: 35700000000292DCEB1-
   Subsystem 3 - Part No SW: -----------    HW: 480 002 106 16
   Serial number: 35800000000915B81C1L
   Subsystem 4 - Part No SW: -----------    HW: 480 022 306 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B3210BB1226FW
   Subsystem 5 - Part No SW: -----------    HW: 480 020 407 16
   Component: SideSensor_Pr  000 0148
   Serial number: 35200019D20E2701C6B2
   Subsystem 6 - Part No SW: -----------    HW: 480 020 306 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001C12149AB3178/
   Subsystem 7 - Part No SW: -----------    HW: 480 020 306 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001C12149AB3014U
   Part No SW: 1K5 953 501 AJ    HW: 5K0 953 569 AN
   Revision: FF010042    Serial number: 20160614300177
   Coding: 0102440008
   VCID: 73A6D86BDACC45D2D8-8026
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1741622491602419AD1B
   Coding: 280000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 881 B    HW: 561 920 881 B
   Component: KOMBI         H03 1104
   Coding: 211F290000
   VCID: 1A78D5CF1DE6D49A3B-804E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 25071603010413
   Coding: 461010
   VCID: 7BB6F04BFA9C0D9280-802E
                    Fault Status: 00110100
                    Reset counter: 8
            000 -  -
                    Fault Frequency: 116
                    Mileage: 26222 km
                    Date: 2019.03.03
                    Time: 10:51:31
   Component: IMMO          H03 1104
   Coding: 000007
   VCID: 6A98C50F8D06841A6B-803E
   Revision: 00000000    Serial number: 16000110930004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 312A1263605037C26A-8064
   Serial number: 0410870478
   Coding: 02011102
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C343357B712CAAAC9-8068
   Component: HRE_Slave  H12 0071
   Serial number: 0409092296
   Coding: 020111
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010612678
   Coding: 3414BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E70D9DF01CEB8BAC7-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746160813161629
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 224
                    Mileage: 26222 km
                    Date: 2019.03.03
                    Time: 10:51:32
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0095893
   VCID: 281CFF07538A760ABD-807C
   Component: EZE_2         H56 1682
   Coding: 010B0508
   VCID: 6FAED41BBEE461323C-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011612400789
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0003
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010626440
   Coding: 3415BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F0EE4DB06C4B1B2CC-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14202747160814223112
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 11
   Part No SW: 5C0 035 680 D    HW: 5C0 035 680 D
   Component: MU-S-N-ER     H30 0356
   Serial number: VWZAZ2S5141154
   Coding: 0263010CAA00000011110003001828001F0100D400200100CF
   VCID: 2208ED2F35B69C5AE3-8076
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           122 0821
                    Fault Status: 01100101
                    Mileage: 26222 km
                    Date: 2019.03.03
                    Time: 10:49:12
                    Mileage: 26231 km
                    Date: 2019.03.04
                    Time: 08:09:00
End----------(Elapsed Time: 01:14, VBatt start/end: 12.4V/12.4V)-----------
Thanks for your helping.
Dana
Western PA, USA
Hello Bakhtiyar,
Since the OP had a VW Caddy we might want to move this to an entirely new forum thread but Uwe's link in post #4 applies to your car as well. Do check the CodingLog.CSV file in addition to the earliest (oldest) factory condition Auto-Scan you have from this car to obtain the factory coding values.
Next, the oldest scan we have on-file (with the seat belt warning question) had 09 coded to:
> Revision: BM122001
> Coding: 68200E3B882908D4008804003400816002F1000645A00DB0E4806000AC70
> VCID: 7EB0F95FE98E18BAAF-802A
> Coding: 0038DD
> No fault code found.
If the lights were OK prior to Wednesday,13,February,2019,20:34:24 you could simply enter that coding however I'd want to verify it was the factory condition by checking your log files on the PC.
