HI i have coded this car few days back trying to change the longcoding back to original it just gives me odd error and freeze at long coding helper so far i have tried uninstalling the vcd restarted the computer did ignition cycle but it wont let me code any module giving me same error on all modules any possibility you can help
ERROR:00 UNKNOWN (0X0)
Saturday,02,March,2019,13:10:08:22147
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Workshop Code: 000 17485 000000
VIN: WAUZZZ8VXKA059486 License Plate:
Mileage: 107km-66mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 29 39 3C 42 44 47 4B 52 5F 6C
A5 BB BC CF D6 D7
VIN: WAUZZZ8VXKA059486 Mileage: 107km-66miles
Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AL HW: 05E 907 309
Component: R4 1.5l TFS H22 6084
Revision: 81H22000
Coding: 022500322364010820000000000000000000000000000000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM15TFS01105E906018AL 003002
ROD: EV_ECM15TFS01105E906018AL.rod
VCID: 6FBBD0BE4718644F777-803A
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 300 043 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1604
Revision: 00005008 Serial number: CU501901135242
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 38292BE272D6E3F766D-806C
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000 Serial number: 63568000001887
Coding: 12F18AA2202522758B7B0E0860C92848510444D1700614731821507492A84A0B0000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod
VCID: 79AFEEE6095C3AFFD93-802C
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001742084
Coding: 03100014000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: 76B5E5DA38425587B41-8022
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: EBD1946900PAG0MUFU03
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001901500942
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F7F2066E0FD7C25-8028
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 181101 043 0580
Serial number: 181121182025
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 27 10 2018 20000533
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY183300L4D
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000046221310
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST0028ON8T00000
Coding: 901E00
Steering Column Switch:
Subsystem 7 - Part No SW: 82A 953 521 J HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000003011920240700
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418019004
Coding: 0470155811
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CC16732164E7F57325-8018
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Coding: 3500E7C15DFFC728949C814580402600000000000000000004
VCID: 44D14F123E1EB717FA5-8010
Part No SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Component: AirbagVW21 007 0403
Serial number: 003FNR4XX1S
Coding: 98CCC0000C0000005C5400CA00C8000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 1373BC4E0BF0E0AF33F-8046
Subsystem 1 - Part No SW: ----------- HW: 480 001 501 19
Serial number: 357000000006A548163F
Subsystem 2 - Part No SW: ----------- HW: 480 001 501 19
Serial number: 35800000000559D8C73Z
Subsystem 3 - Part No SW: ----------- HW: 480 401 701 19
Component: SideSensor_Dr 004 6149
Serial number: 3510001202B805C3757T
Subsystem 4 - Part No SW: ----------- HW: 480 401 701 19
Component: SideSensor_Pr 004 6149
Serial number: 3520001202B805C4963U
Subsystem 5 - Part No SW: ----------- HW: 480 402 012 18
Component: FrontSensor_D 004 6149
Serial number: 3550001182BF79B324CD
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 901 19
Component: PedP_Sensor_D 004 6149
Serial number: 2280001182BFB753E6EO
Subsystem 7 - Part No SW: ----------- HW: 480 400 901 19
Component: PedP_Sensor_P 004 6149
Serial number: 2290001182BFB7540710
Subsystem 8 - Part No SW: ----------- HW: 480 001 201 19
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000E6BE8273J
Subsystem 9 - Part No SW: ----------- HW: 480 001 201 19
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000F6BE8273L
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 C HW: 8V0 920 790 C
Component: FBenRDW H19 0109
Coding: 248409406F8C06000180E8001000000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001032
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3C2137F246EECFD7825-8068
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4367
Revision: -------- Serial number: 0008971891
Coding: 030100043F0856005B00025A1C0B00000001010000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CDBA40126D477C1-803A
Component: 0-00-00-00-00
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20190113232123 30048
Component: J367-BDMConti H03 1051
Serial number: 75886003911901140550
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
VCID: 42DD490A240AB927C89-8016
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 H HW: 3Q0 907 566
Component: MRR1Rear H23 0630
Revision: --------
Coding: 44C002
VCID: 3D273AF65DF4C6DFB5B-8068
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RJQ18323
Coding: 005E8A205001000000001002
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B1DFD22E3E47978A5-8020
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAJ5F022YQG
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 2411EF92DE5E9717DA5-8070
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 13011911600711
Coding: 000000050900146E00102B03020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 353722D665C41E9F7DB-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RJP0172A
Coding: 005E82205C01000000001002
VCID: 43D34C0E3B10B02FC3F-8016
Part No SW: 8V1 035 035 C HW: 8V1 035 035 C
Component: MU-P-LND-EU 055 1326
Serial number: A698A0KB007815
Coding: 017303010000000011111102000A00312F0026E7017001009E
VCID: 323D19CA94AA09A7589-8066
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0FT6N
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BJ HW: 8V0 919 614 BJ
Component: ControlUnit_H H85 0855
Serial number: ALJAL112101800050446
Component: Gracenote2 --- 1017
Component: RVC Compact H15 0231
Coding: 0273100102002001400040
VCID: 392F2EE649DCFAFF993-806C
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H10 0610
Serial number: 15011915P14353
Coding: 040307030000040101022346814EA90098000E20002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D943022A06AB37DED-8014
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0187
Serial number: YE007RLL12393
Coding: 000C82204001000000001002
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 4EC56D3AE0524D475C1-801A
Component: TSG HBFS003 0187
Serial number: YE007RLL1243B
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 H HW: 3Q0 907 590
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
VCID: 3A2D31EA4CDAF1E7909-806E
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176BC85E1F08CC8F4F7-8042
Component: LED1R H09 0008
End----------(Elapsed Time: 01:58, VBatt start/end: 12.3V/12.3V)-----------
