OK so we ordered the driver's side fuel pump (N402). We didnt get an original part, but a Hitachi. It comes with a 1 YR warranty, and for $260 from a reputable place. If it works for 1 YR I will be satisfied lol.
ANyways, so I was able to use a dremel tool to grind a slot into each of the last two safety screws on the clamp over the ecu & ecu connectors locking them together. I got the connector off, and found a diagram that shows which pin is what on the ecu. The wire that is brown with a black stripe leading off the two-pin connector on the N402 does in fact lead to pin 35 on the T60 connector. Here is the diagram I used. Keep in mind the diagram is showing which pin is what ON THE ECU. So you need to mirror it to find the correct pin ON THE CONNECTOR. Just a note for those who may read this and not know.
I used my multimeter to test the continuity and got a nice (beep) to confirm the is at least some continuity.
Then, I tested the resistance, and got numbers varying from 0.1-1.0 Ohm..I have to go to work right now, so after work I will have torun the test again to verify those numbers are correct. I used a resistance calculator and it said even with 15 feet of 15 gauge wire the resistance should only be about 0.06 Ohm. Is that right? Isnt 0.1-1.0 Ohm too much?
If the numbers are the same I will just have to de-pin pin 35 on t60, and the matching pin on the N402 chassis side connector, and run an overlay. I need to get this thing on the road.
I ordered a 21 piece set of tools used for de-pinning connectors. Hopefully what I need is in there.
I still need to test the other wires that relate to sensors/codes thrown after I figured out that fuse S13 was blown. There could be a chaffed wire or cut wire or something. I will start with the G62 engine coolant temperature sensor that was throwing a code indicating a short to positive. I suppose that would explain some things.
Anyways, just wanted to update that
