Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: 2007 4.2L FSI w/ rough idle P0102 P010C Low MAF
  1. #31
    Quote Originally Posted by stone4779 View Post
    The two pins on N402 itself, came to 0.5 Ohms. Out of spec.
    That's for all intents and purposes a dead short; 0.5 ohms would pull 24A from 12V, and my guess is the actual resistance is lower than that 'cause you're probably not taking the resistance of the meter leads into account.
    What size is the S13 fuse?
  2. Likes stone4779 liked this post
  3. #32
    Why no auto-scan yet and why not verified?
    Hmmm let me see I would know for sure, as would the collective, what fuse is what if we had an auto-scan?
  4. Likes stone4779 liked this post
  5. #33
    See post #8 and post #11.
  6. Likes stone4779 liked this post
  7. #34
    Verified VCDS User stone4779's Avatar
    Mar 2019
    That is correct. 0.5 ohms is plenty of resistance to blow s13 at anywhere near 12 volts. Especially since there are other things running off that fuse simultaneously presumably.
    S13 is listed as a 15A fuse.
    Thanks again for the reply Uwe. 👍
  8. #35
    Mar 2019
    Woops! My mistake Jack, I should have posted the amperage rating of the fuse s13 already...its 15A.
    And believe me, there is nothing more in this world that I desire than to obtain and post a full auto scan using vcds. Finances preclude me from getting it right now, but hopefully next week!
    I do thank you for your time kind sir
  9. #36
    Well I hope you get better financially and become a collective member in the registered area soon.
    Give the Borg ship a VIN number please, that surely doesn't preclude you financially & so data can be observed to try to help you.
    Resistance is .......
  10. Likes stone4779 liked this post
  11. #37
    Mar 2019
    Thank you, as do I I will be a verified member within 1-2 weeks most assuredly.
    Oh and I'm sorry, I should have posted the VIN. I had a link up to a PDF containing a scan which had the VIN in it in the original post, but the link went dead for some reason. my mistake. I hadnt even checked if the links worked until just now. woops. long week!
    The VIN for the vehicle in question is:
    WA1AV74L17D026123
    Input appreciated!
  12. #38
    Mar 2019
    On a side note but still related...I have an itching to get one of THESE as well:
    "Kzyee KM10 Power Circuit Probe Kit, Automotive Circuit Tester with Auto Electrical System Testing Functions (Digital Voltage Tester/Multimeter/Short Finder/Battery Test/Power or Ground Supply)"
    and maybe one of these:
    "Adjustable Current Voltage Analog Simulator Signal 0~20mA Generator DC 0~10V"
    I figure they might be handy to quickly check things.
    Also today I am getting a couple test probe lights to load test the circuit!
    There is a three pack that has one probe test light for 6/12v, one for 18/24/36v, and a 3rd test probe which just checks for continuity they have at a local supply store for $7, it is on the way home from work so I am going to stop by this afternoon for it.
    I figure I can hack one to run a 55w light bulb or something though the circuit to see if lights up, and if so, is it as bright as just connecting same 55w light bulb directly to the positive and negative of the battery? Does it flicker if I wiggle the wiring?
    I look forward to finding out!
  13. #39
    Vehicle Identification No. WA1AV74L17D026123
    Model audi q7 qu. 4.2
    AQ7
    Date of production 23.06.2006
    Year 2007
    Sales type 4LB5EL
    Engine Code BAR
    Transmission Code HPH
    If you would be so kind & take a picture of the engine controller you have please and post it?
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 1CN Vehicle class differentiation -4L0-
    Emission standard 7GA Emission standard LEV 2
    Trailer hitch 1D6 Trailer hitch
    airbag 4UB Airbag for NAR
    Label for central electric 0W2 Label for central electric system English-speaking countries
    Tray areas package QE1 Storage compartment package 1
    Exterior mirror setting 6XL Exterior mirrors with memory feature, auto-dimming, power-folding/adjustable/ heated
    Left exterior mirror 5SG Left exterior mirror, flat
    Right exterior mirror 5RW Right exterior mirror, convex (US) large viewing field
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8U Executive US equipment
    Brake type in rear 1KF Disc brakes in rear
    batteries J0Z Battery 520 A (110 Ah)
    Brake type, front 1LF Silver caliper
    Receiver (car phone) QF0 Without receiver (car phone)
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    vehicle tools and jack 1S1 vehicle tools and jack
    Owner's manuals 0VM Information kit in American English
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A2 CD changer
    General operating permit, alterations C00 Operating permit, initial registration
    Shock absorption/suspension, chassis 1BW Comfort suspension 2
    Roof rails/roof load rack 3S1 Bright roof rails
    Roof insert/convertible top 3FU Big roof system
    Differential lock 1Y0 without differential lock
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G4 Insert for the filling up of unleaded fuel
    Theft protection system 7AJ Electronic immobilizer, with anti-theft alarm system and backup horn
    Inserts 5TA Tamo wood trim
    Scuff plates 7M0 Plastic scuff plates in door apertures
    Park distance control 7X7 Park distance control in rear plus rear view camera system
    fire extinguisher 6A0 without fire extinguisher
    Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
    Interior noise suppression measures 3W4 Acoustics package "Standard"
    Alternators 8GH Alternator 190 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
    Weight category front axle 0JB Weight category front axle weight range 2
    Base engine T8T 8-cyl. petrol engine 4.2 l assembly 079.A (ALU)
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T1 Cruise control system (CCS)
    Garage door opener VC1 Garage door opener
    Transmission specifications G0R 6-speed automatic transmission for four-wheel drive
    Rear trim panel 6V2 Rear trim panel
    Molded headliner 6NJ Standard molded headlining
    Rear seats 5KL Five rear seats (with armrest)
    Heating and air-conditioning system 9AD Climatronic, free of cfc
    Headlamps 8EH Bi-functional headlamps with gas discharge lamp, for driving on the right (US design)
    Customized installation FC0 Without individual installation
    Instrument clusters U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer
    Breakaway interior rearview mirror 4L7 Breakaway interior rearview mirror, auto-dimming, with compass
    Body style K4H Closed body
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Cassette and CD storage unit 4W0 without cassette / CD tray
    child safety 4H5 Electrically operated child lock
    Climatic zones 0Y2 Tropical zones
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    Fuel quantity for initial filling 1Z6 Increase in initial standard fuel filling
    Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K4 with no paint conversation
    Rear cargo area 3GD Plane rear cargo area
    Light package (lighting) QQ1 With additional lights (interior lighting)
    Steering system arrangement L0L Left-hand drive
    steering QZ0 Speed-sensitive power steering (Servotronic) w/ limited steering lift mechanism)
    Lumbar support 7P1 Power adjustable lumbar support in front seats
    steering wheels 2ZM Leather-wrapped multi-function steering wheel
    Speaker installation 8RY loudspeaker with BOSE-sound
    Steering column systems 2C7 Safety steering column with electric axial and tilt adjustment
    Air cleaner (engine) 1L2 Air cleaner for dusty regions with saturation indicator
    Leather scope 7HA Without leather trim
    Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
    Center armrest 6E6 Center armrest in front
    Multi-function display/trip computer 9Q4 Multi-function display/trip computer with check control
    Engine cooling 8Z6 Hot country
    Engine specifications MN5 8-cylinder SI engine 4.2 l/257 kW (32V) FSI base engine is T8T
    Navigation device 7Q2 navigation system with colour screen
    Audi Sport/ Quattro GmbH FQ0 Series wheels
    Quality class AQ0 Standard-production quality
    Wheels CJ3 Alloy wheels 9J x 19 -- painted, style:- 5 thin spokes
    Radios 8DY Radio "HIGH" America
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K7 Tire pressure monitoring system 433 MHz Basic
    tire HL7 All-season tires 265/50 R19 110H xl (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G1 Space-saving spare wheel
    Wheelbases 0E2 Long wheelbase
    PAW cold-weather package
    PND navigation system plus incl. MMI for export
    PRY cast aluminium alloy wheels, 8.5Jx19, 7-arm "Structure" design, with 265/50 R 19 tyres
    PTA technical package for USA
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 7F9 Gearshift knob/handle in plastic/leather
    Self-collection / special control A00 No self-collection
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SJ Tail light cluster, normal design (NAR)
    Locking mechanism for boot lid/cover rear 4E9 Trunk lid power closing with operating lever inside
    Bumper systems VJ4 bumper reinforced
    Seat belt check 9P5 Visual and acoustic seat belt reminder, electric contact
    seat covers N1F Seat trim covers in leather, G-grain pattern/leatherette, B-grain pattern
    Seat adjustment 3L4 Electric seat adjustment for both front seats, driver's seat with memory system
    seat heater 4A4 Seat heater for front and rear seats separately controlled
    Safety certificate 0LM With special labels safety certificates for California
    sun visors 5XH Sun visors, with vanity mirror illuminated on driver's and front passenger side
    Audio-response system/voice control QH2 voice control
    Lane change assist/lane keeping system 7Y1 Lane change assist
    Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar
    Sunroof roller blind for rear/side windows 3Y3 Roll-up sunhade for rear window and rear door windows
    Rear stabilizer 0BB Rear stabilizer
    Front stabilizer bar 0AB Front stabilizer bar
    Handling production and pre-production FA0 Control of standard production
    Headlamp washer system 8X0 Without headlamp washer system
    Door and lid locking system 4K7 Central locking system "Keyless Entry" "two-stage unlocking"
    Type approval countries/countries with special requirements B34 Legal requirements USA
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Transit coating NT2 Transit coating (type 3)
    TV reception/digital radio reception QV4 Satellite radio reception USA
    Assembly parts for engine (drive bearing) 1VJ Assembly part for 8-cyl. engine
    Identification plates 1EP Special identification label (USA)
    Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit / warning triangle 1T1 First aid kit
    Front seats Q1A Standard seats in front
    Storage compartment -- veneered key storage box 4Y0 Without storage compartment/safe box
    Telephone / telematics 9ZG preperation for mobile phone with hands free teleph.
    Windshield Glass 4GP Windshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
    Central display and control unit QW1 Central control unit in front
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional body panels, side 6EQ Additional stone guard body covers (type 2)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  14. Likes stone4779 liked this post
  15. #40
    Mar 2019
    AQ7
    Year 2007
    Sales type 4LB5EL
    Engine Code BAR
    And a close up of the information on the label:
    As always, thank you for your time, Jack. 🙏
  16. Likes Jack@European_Parts liked this post
