- Joined
- Mar 1, 2019
- Messages
- 3
- Reaction score
- 0
- Location
- South Africa
- VCDS Serial number
- HC800002 (Clone!)
Hi, I recently bought an A8, been standing for two years without a turbo. Bought a tested 2nd hand one and car has many errors. Had a similar problem on the park brakes with many grounds and low volt errors but after fixing the switch, all errors were gone. I can almost not believe that all these components are faulty. All valves are loose. Only error o the screen is the glow plug light. Not sure if that can cause limp mode.
Mode 07: Pending emission related fault codes
Address 7E8: 8 Faults Found:
P2426 - Exhaust Gas Recirculation Cooling Valve Control Circuit: Short to Ground
P2011 - Intake Manifold Flap; Bank 2: Electrical Malfunction
P2008 - Intake Manifold Flap; Bank 1: Electrical Malfunction
P2100 - Throttle Actuator Control Circuit: Open Circuit
P0489 - EGR Valve Position Control Circuit: Short to GND
P0243 - Solenoid Valve for Boost Pressure Control (N75): Malfunction
I'm suspecting something small affecting all these areas, coding perhaps...?
Would appreciate some advice
Tertius
Tertius
