Results 1 to 7 of 7
Thread: ABS Coding Question
    Pirate
    Mar 2019
    ABS Coding Question
    Здравствуйте.Подскажите пожалуйста как сделать длинное кодирование блока ABS после замены.Старый блок на связь не выходит).На данный момент есть ошибка "неправильно введен номер шасси".
    Пятница,01,Март,2019,09:53:30:00006
    VCDS -- Основанный на Windows VAG/VAS Эмулятор Работа Windows 7 x86
    VCDS Версия: RUS 17.8.1.0
    Данные версии: 20171211 DS276.6
    VIN: WAUZZZ8K89A045828   Номерной знак: 558
    Пробег: 236000km   Заказ ремонта:
    Remainder Removed.  Data from a clone/pirate copy of VCDS is not welcome here.
    Since the language of this forum is English, you'll need to download the up-to-date English version from the Ross-Tech website and repost your Auto-Scan using that - oh and describe exactly what you want help with...
  3. Likes Uwe liked this post
    Pirate
    Mar 2019
    After replacing the ABS unit, error 01794 appeared. How to register the VIN?
    Thank you for posting Autoscan (and Uwe has work to do again )
    All though it has much to do with ABS on VW Polo.
    Look here at Wiki (and here).
  6. Likes Uwe liked this post
    Pirate
    Mar 2019
    I was on these links, but unfortunately this did not solve the problem.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#ru
    Let us know if/when you gets one and we'll adjust your forum status.
    Pirate
    Mar 2019
    Thanks for the help(
