Hi
I hope someone can help with my query.
I've just replaced the injectors and fuel filter on my 2005 Audi A6 3.0 TDi (BMK).
I was hoping to use the group 35 function to prime the system before starting the engine. But when I went to group 35 I got an error message - "error group 35 not available". Does that mean my car doesn't have a lift pump?
The VCDS auto-scan is below. Some of the error messages are from when the wife tried to start the car whilst it was in pieces (next time I'll hide the keys!).
Many thanks
Sean
Many thanks
Sean
Friday,01,March,2019,19:24:25:57775
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190215 DS296.0
VIN: WAUZZZ4F96N032034 License Plate:
Mileage: 250910km-155908mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 69 72 76 77
VIN: WAUZZZ4F96N032034 Mileage: 250910km-155908miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 00656 210 83209
VCID: 1A6EDA72E091A327709-804E
000257 - Mass Air Flow Sensor (G70)
P0101 - 001 - Implausible Signal - Intermittent
Fault Status: 00110001
Mileage: 250127 km
Date: 2019.01.27
Time: 13:09:07
RPM: 1953 /min
Torque: 0.0 Nm
Speed: 110.9 km/h
Duty Cycle: 50.1 %
Voltage: 13.83 V
Absolute Pres.: 1050.6 mbar
Mass Air / Rev.: 470.0 mg/str
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 002 - Implausible Signal - Intermittent
Torque: -195.0 Nm
Voltage: 11.48 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Mass Air / Rev.: 0.0 mg/str
004499 - Fuel Pressure Sensor (G247)
P1193 - 001 - Open or Short to Plus - Intermittent
Fault Status: 00100001
Torque: 265.2 Nm
Duty Cycle: 1.0 %
Voltage: 10.72 V
Pressure: 0.0 bar
Duty Cycle: 18.5 %
000260 - Mass Air Flow Sensor (G70)
P0104 - 001 - Intermittent - Intermittent
Torque: 265.2 Nm
Duty Cycle: 80.9 %
Voltage: 10.72 V
Absolute Pres.: 1009.8 mbar
000387 - Fuel Temp. Sensor A (G81)
P0183 - 001 - Open or Short to Plus - Intermittent
Torque: 265.2 Nm
Duty Cycle: 1.0 %
Voltage: 10.72 V
Pressure: 340.8 bar
Temperature: 8.1°C
005445 - Throttle Valve Controller
P1545 - 001 - Malfunction - Intermittent
Fault Frequency: 14
Torque: 265.2 Nm
Voltage: 10.72 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Readiness: 0 1 0 0 0
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 4042590
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2310E796D7DBE2EFA3F-8076
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0004488
VCID: 2D0401AE811F249F05B-8078
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300187560
Coding: 0000147
VCID: 6390A796975BA2EFE3F-8036
Component: FBSAUDIC6 EZS H44 0070
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 730 F HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 350FR057568631
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 2412E48AD2D5E5D7DA5-8070
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H03 0010
Subsystem 2 - Serial number: 00000000174279
Subsystem 3 - Serial number: 0107.06.050000000100010725ÿ
Subsystem 4 - Serial number: 010725ÿ
Part No SW: 4F0 910 043 HW: 4F2 820 043 J
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000148896
Coding: 0001302
VCID: 5BE09F76AF2B9A2FABF-800E
Fault Status: 00100011
Fault Frequency: 38
Reset counter: 119
Mileage: 248608 km
Date: 2018.12.08
Time: 07:42:13
Voltage: 13.50 V
Temperature: 10.0°C
(no units): 188.0
(no units): 218.0
Temperature: 9.0°C
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0002121
VCID: 6696BE826469D7C7041-8032
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H11 0040
Coding: 00022800
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7177922
VCID: 1C62DC6AEAA5DD17625-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD08B5N5
Coding: 0013382
VCID: 290CF5BEB5F738BFE93-807C
Subsystem 1 - Serial number: 6332CSME0A384F179
Subsystem 2 - Serial number: 6342CSME0A2C7B76H
Subsystem 3 - Serial number: 6352QSME0518293DI
Subsystem 4 - Serial number: 6362QSME05033145%
Subsystem 5 - Serial number: 63734SME02082E43Y
Subsystem 6 - Serial number: 63834SME05192F7DB
Part No SW: 4F0 910 549 HW: 4F0 953 549 B
Component: Lenksäulenmodul H09 0230
Revision: 00H09000 Serial number: 90025080100101
Coding: 0102142
Shop #: WSC 00656 210 88563
Component: Lenkradmodul H07 0080
Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4PX35PL55
Coding: 2049443
Shop #: WSC 60457 001 1048576
VCID: 211CED9ECDC7F0FFB13-8074
00532 - Supply Voltage B+
Reset counter: 120
Mileage: 250887 km
Date: 2019.03.01
Time: 16:39:14
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 12008055288084
Coding: EDFE73C41B3104
VCID: 2708F386A3E30ECFFF7-8072
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H44 0850
Revision: 00000000 Serial number: 305EU057594249
VCID: 3B203FF64F6BBA2F8BF-806E
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: ‰3q
Coding: 0003610
Shop #: WSC 02327 785 00200
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01004778620000
Coding: 0131835
VCID: 2E0606A28C195F873C1-807A
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 D HW: 4F0 035 223 D
Component: DSP-High C6 H09 0170
Revision: PROD_01 Serial number: 00000000788056
Coding: 0000113
VCID: 1F18EB66FBB3C60F877-804A
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000101129
Coding: 0001103
Shop #: WSC 02323 785 00200
VCID: 5EE69662BC398F07CC1-800A
01316 - ABS Control Module
Reset counter: 107
Mileage: 250516 km
Date: 2019.02.16
Time: 19:47:00
Voltage: 11.300 V
Temperature: 20.0°C
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: "Hq
Coding: 0003610
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: 5DE4916EB13F941FD5B-8008
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Coding: 0000003
VCID: 3A2E3AF240518327909-806E
00070 - Starting Battery Voltage
Reset counter: 67
Mileage: 250248 km
Date: 2019.01.31
Time: 20:51:46
Part No SW: 4E0 910 541 L HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 394F/057555766
Coding: 0000001
00856 - Radio Antenna
Fault Status: 00101011
Reset counter: 102
Mileage: 250415 km
Date: 2019.02.09
Time: 16:31:02
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000137903
Component: von VA0 1506010929
Coding: 344630393135313035442056413031353036303130393239
02272 - Quiescent Current Stage 1
Fault Frequency: 7
Mileage: 247149 km
Date: 2018.09.16
Time: 16:47:50
02273 - Quiescent Current Stage 2
Mileage: 247149 km
Date: 2018.09.16
Time: 17:49:11
02276 - Quiescent Current Stage 5
Mileage: 250887 km
Date: 2019.03.01
Time: 16:45:38
02274 - Quiescent Current Stage 3
Mileage: 250887 km
Date: 2019.03.01
Time: 16:45:48
02277 - Quiescent Current Stage 6
Mileage: 250887 km
Date: 2019.03.01
Time: 16:45:58
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0003074
VCID: 698CB5BE7577F8BF293-803C
Address 69: Trailer Labels: 4F0-910-383.lbl
Part No SW: 4F0 910 383 HW: 4F0 907 383
Component: ANHAENGERELEKTR H02 0020
Coding: 0000331
VCID: 629EA2928841ABE7E89-8036
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0003074
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820515401776
Coding: 0211016
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H10 0580
Revision: 00000000 Serial number: 00000007558494
Coding: 0010900
VCID: 2514F98ED9EF1CDFCDB-8070
End----(Elapsed Time: 01:53, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
