Results 1 to 8 of 8
Thread: Lift pump not activating
    Apr 2018
    Hi
    I hope someone can help with my query.
    I've just replaced the injectors and fuel filter on my 2005 Audi A6 3.0 TDi (BMK).
    I was hoping to use the group 35 function to prime the system before starting the engine. But when I went to group 35 I got an error message - "error group 35 not available". Does that mean my car doesn't have a lift pump?
    The VCDS auto-scan is below. Some of the error messages are from when the wife tried to start the car whilst it was in pieces (next time I'll hide the keys!).
    Many thanks
    Sean
    Friday,01,March,2019,19:24:25:57775
    Data version: 20190215 DS296.0
    VIN: WAUZZZ4F96N032034   License Plate:
    Mileage: 250910km-155908mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
              56 61 62 69 72 76 77
    VIN: WAUZZZ4F96N032034   Mileage: 250910km-155908miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4F0 910 401 A    HW: 4F0 907 401 B
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H01---    Serial number:
       Coding: 0011372
       Shop #: WSC 00656 210 83209
       VCID: 1A6EDA72E091A327709-804E
    6 Faults Found:
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 001 - Implausible Signal - Intermittent
                        Fault Status: 00110001
                        Mileage: 250127 km
                        Date: 2019.01.27
                        Time: 13:09:07
                        RPM: 1953 /min
                        Torque: 0.0 Nm
                        Speed: 110.9 km/h
                        Duty Cycle: 50.1 %
                        Voltage: 13.83 V
                        Absolute Pres.: 1050.6 mbar
                        Mass Air / Rev.: 470.0 mg/str
    001592 - Throttle Body Actuator Bank 1 (J338)
                   P0638 - 002 - Implausible Signal - Intermittent
                        Torque: -195.0 Nm
                        Voltage: 11.48 V
                        Duty Cycle: 92.7 %
                        Bin. Bits:    010
                        Mass Air / Rev.: 0.0 mg/str
    004499 - Fuel Pressure Sensor (G247)
                   P1193 - 001 - Open or Short to Plus - Intermittent
                        Fault Status: 00100001
                        Torque: 265.2 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 10.72 V
                        Pressure: 0.0 bar
                        Duty Cycle: 18.5 %
    000260 - Mass Air Flow Sensor (G70)
                   P0104 - 001 - Intermittent - Intermittent
                        Torque: 265.2 Nm
                        Duty Cycle: 80.9 %
                        Voltage: 10.72 V
                        Absolute Pres.: 1009.8 mbar
    000387 - Fuel Temp. Sensor A (G81)
                   P0183 - 001 - Open or Short to Plus - Intermittent
                        Torque: 265.2 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 10.72 V
                        Pressure: 340.8 bar
                        Temperature: 8.1°C
    005445 - Throttle Valve Controller
                   P1545 - 001 - Malfunction - Intermittent
                        Fault Frequency: 14
                        Torque: 265.2 Nm
                        Voltage: 10.72 V
                        Duty Cycle: 92.7 %
                        Bin. Bits:    010
    Readiness: 0 1 0 0 0
       Part No SW: 4F1 910 156 B    HW: 09L 927 156 A
       Component: AG6 09L 3.0lTDI RdW 0030
       Revision: --H01---    Serial number:        4042590
       Shop #: WSC 02325 785 00200
       VCID: 2310E796D7DBE2EFA3F-8076
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Coding: 0004488
       VCID: 2D0401AE811F249F05B-8078
       Component: FBSAUDIC6 ELV   H30 0220
       Revision: 31050601    Serial number: 10600300187560
       Coding: 0000147
       VCID: 6390A796975BA2EFE3F-8036
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H44 0070
       Component: FBSAUDIC6 IDG   H39 0040
       Part No SW: 4F0 910 730 F    HW: 4E0 035 729
       Component: Interfacebox    H43 2120
       Revision: 00000000    Serial number: 350FR057568631
       Coding: 0001002
       Shop #: WSC 02335 785 00200
       VCID: 2412E48AD2D5E5D7DA5-8070
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H03 0010
       Subsystem 2 - Serial number: 00000000174279
       Subsystem 3 - Serial number: 0107.06.050000000100010725˙
       Subsystem 4 - Serial number: 010725˙
       Part No SW: 4F0 910 043     HW: 4F2 820 043 J
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000000148896
       Coding: 0001302
       VCID: 5BE09F76AF2B9A2FABF-800E
                        Fault Status: 00100011
                        Fault Frequency: 38
                        Reset counter: 119
                        Mileage: 248608 km
                        Date: 2018.12.08
                        Time: 07:42:13
                        Voltage: 13.50 V
                        Temperature: 10.0°C
                        (no units): 188.0
                        (no units): 218.0
                        Temperature: 9.0°C
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0002121
       VCID: 6696BE826469D7C7041-8032
       Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H11 0040
       Coding: 00022800
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7177922
       VCID: 1C62DC6AEAA5DD17625-8048
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4F AIRBAG AUDI8RH29 0260
       Revision: 07H29000    Serial number: 0037LD08B5N5
       Coding: 0013382
       VCID: 290CF5BEB5F738BFE93-807C
       Subsystem 1 - Serial number: 6332CSME0A384F179
       Subsystem 2 - Serial number: 6342CSME0A2C7B76H
       Subsystem 3 - Serial number: 6352QSME0518293DI
       Subsystem 4 - Serial number: 6362QSME05033145%
       Subsystem 5 - Serial number: 63734SME02082E43Y
       Subsystem 6 - Serial number: 63834SME05192F7DB
       Part No SW: 4F0 910 549     HW: 4F0 953 549 B
       Component: Lenksäulenmodul H09 0230
       Revision: 00H09000    Serial number: 90025080100101
       Coding: 0102142
       Shop #: WSC 00656 210 88563
       Component: Lenkradmodul    H07 0080
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4PX35PL55
       Coding: 2049443
       Shop #: WSC 60457 001 1048576
       VCID: 211CED9ECDC7F0FFB13-8074
    00532 - Supply Voltage B+
                        Reset counter: 120
                        Mileage: 250887 km
                        Date: 2019.03.01
                        Time: 16:39:14
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 12008055288084
       Coding: EDFE73C41B3104
       VCID: 2708F386A3E30ECFFF7-8072
       Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 C
       Component: MNS ECE         H44 0850
       Revision: 00000000    Serial number: 305EU057594249
       VCID: 3B203FF64F6BBA2F8BF-806E
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00000000    Serial number: ‰3q
       Coding: 0003610
       Shop #: WSC 02327 785 00200
       Component: Komfortgeraet   H19 0140
       Revision: 01400019    Serial number: 01004778620000
       Coding: 0131835
       VCID: 2E0606A28C195F873C1-807A
       Part No SW: 4F0 910 223 D    HW: 4F0 035 223 D
       Component: DSP-High C6     H09 0170
       Revision: PROD_01     Serial number: 00000000788056
       Coding: 0000113
       VCID: 1F18EB66FBB3C60F877-804A
       Revision:             Serial number: 00000000101129
       Coding: 0001103
       Shop #: WSC 02323 785 00200
       VCID: 5EE69662BC398F07CC1-800A
                        Reset counter: 107
                        Mileage: 250516 km
                        Date: 2019.02.16
                        Time: 19:47:00
                        Voltage: 11.300 V
                        Temperature: 20.0°C
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00000000    Serial number: "Hq
       Coding: 0003610
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000321
       Shop #: WSC 02334 785 00200
       VCID: 5DE4916EB13F941FD5B-8008
       Part No: 8P0 907 357 C
       Coding: 0000003
       VCID: 3A2E3AF240518327909-806E
    00070 - Starting Battery Voltage
                        Reset counter: 67
                        Mileage: 250248 km
                        Date: 2019.01.31
                        Time: 20:51:46
       Part No SW: 4E0 910 541 L    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0560
       Revision: 00000000    Serial number: 394F/057555766
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 102
                        Mileage: 250415 km
                        Date: 2019.02.09
                        Time: 16:31:02
       Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
       Component: J0644 BEM       H12 0760
       Revision: 00000000    Serial number: 00000000137903
       Component: von VA0  1506010929
       Coding: 344630393135313035442056413031353036303130393239
    02272 - Quiescent Current Stage 1
                000 -  -  - Intermittent
                        Fault Frequency: 7
                        Mileage: 247149 km
                        Date: 2018.09.16
                        Time: 16:47:50
                        Mileage: 247149 km
                        Date: 2018.09.16
                        Time: 17:49:11
    02276 - Quiescent Current Stage 5
                        Mileage: 250887 km
                        Date: 2019.03.01
                        Time: 16:45:38
    02274 - Quiescent Current Stage 3
                        Mileage: 250887 km
                        Date: 2019.03.01
                        Time: 16:45:48
                        Mileage: 250887 km
                        Date: 2019.03.01
                        Time: 16:45:58
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0003074
       VCID: 698CB5BE7577F8BF293-803C
    Address 69: Trailer        Labels: 4F0-910-383.lbl
       Part No SW: 4F0 910 383     HW: 4F0 907 383
       Component: ANHAENGERELEKTR H02 0020
       Coding: 0000331
       VCID: 629EA2928841ABE7E89-8036
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0003074
       Part No SW: 4F0 910 283 C    HW: 4F0 919 283 C
       Component: Parkhilfe 8-Kan H12 0020
       Revision: 00H12000    Serial number: 11820515401776
       Coding: 0211016
       Part No SW: 4E0 910 336 F    HW: 4E0 862 335
       Component: Handyvorb2      H10 0580
       Revision: 00000000    Serial number: 00000007558494
       Coding: 0010900
       VCID: 2514F98ED9EF1CDFCDB-8070
    End----(Elapsed Time: 01:53, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  2. Likes Uwe liked this post
  3. #2
    Check if there isn't an Output Test (Selective) for Fuel Pump Relay.
  4. Likes Dana liked this post
  5. #3
    Apr 2018
    Thanks for the suggestion. The only output test from the drop down menu seems to be Charge Pressure Control. Does that seem right?
    After some digging around I wonder if you can't do too many things with my car and VCDS?
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    For example, there's nothing under Basic Settings which is where I think group 35 would be?
  6. Likes Dana liked this post
  7. #4
    Apr 2018
    I'd appreciate any more thoughts or opinions on this issue.
    I'm new to VCDS so maybe I'm making some school boy assumptions about what I can and can't do with VCDS!
    If I can't prime the fuel system using VCDS then I need a plan B....
  8. #5
    Have you:
    Attached battery charger
    Ignition activated
    Then activate basic setting for MWB 035, even there is no text showed ?
    Do you have an Secure Access button that is not Grayed ?
    This was just for confirmation.
    In the manual, it is described, there is no bleeding for this Engine, due to construction.
    It is done while activating starter.
  9. Likes Dana, DrPeter, Rustychain liked this post
  10. #6
    16.4905° S, 151.7375° W
    This engine supports the following Basic Settings:
    [003] - Exhaust Gas Recirculation (EGR)
    [033] - Basic setting: Turbocharger
    [044] - Basic setting: Intake manifold flap 1
    [055] - Basic setting: Intake manifold flap 2
    [063] - Adapting kickdown point
    If you do any work on the fuel system of a BMK (and other) 3.0L TDI engine, the Official Audi Factory repair manual states the following:
    Bleeding fuel system
    "Vehicles with engine codes ASB, BHQ, BMK, BMZ, BNG, BPP, BSG, BLB, BNA, BRE, BRF, BVG:
    Due to the design of the engine, with a fuel system pressurisation pump located in the fuel tank, it is not necessary to bleed the fuel system.
    The fuel system bleeds itself when the starter is operated. "
    This and more information can be found at erWin Audi
    Hope this helps,
    drpeter
  11. Likes Dana, Uwe, Rustychain liked this post
  12. #7
    United States
    I absolutely agree with NEtech and DrPeter, because the repair manual does NOT indicate a diagnostic bleed is needed, but I would want to try to force the electric pump(s) to run before cranking that engine over. I just don't like the idea of a dry-start or dry-crank on a CR TDI.
    Uwe's SOT suggestion is our only shot if you don't want to hot-wire power and ground to the pump(s) or bypass a relay. We have a German file with SOT Kraftstoffpumpenrelais (J17) listed as an option but it isn't in English VCDS. If you'd like to see if that will activate the relay please drop an email to Support with a link to this thread and I'll send you a file in reply to experiment with.
    Edit. I added English SOT descriptions to the label so we have something ready to go if you want to try it.
  13. Likes Uwe, DrPeter, Eric, Rustychain liked this post
  14. #8
    Apr 2018
    Hi everyone
    Many thanks for all your helpful comments and suggestions (especially about the specifics for my particular engine - i need to get access to ERWIN).
    I'd assumed I needed to prime the engine using this guide:
    http://wiki.ross-tech.com/wiki/index...CR_TDI_Engines
    I realise now that I was looking for the output tests, as suggested by Uwe, in the wrong place - [01 Engine] [Basic settings 04]
    I should have been looking at [01 Engine] [Output tests 03] - Fuel pump relay J17 from the drop down (I clearly need to read the manual and familiarise myself with VCDS some more!)
    I'm pleased to report that the pump(s) kicked in when I followed the above procedure and the car is running.
    Thanks also to Dana for the English SOT file which worked!
  15. Likes Uwe, Dana, DrPeter, Eric liked this post
