I've got my 2018 Golf Alltrack at a local shop with VCDS because they are a lot less likely to mess things up than I would be....however, we're stuck.
My Alltrack SEL came with every feature EXCEPT the Blind Spot Monitoring / Rear Cross-Traffic Alert feature. I saw the Kufatec retrofit kit:
https://www.kufatec.com/en/all-products/blind-spot-sensor-incl.-rear-traffic-alert-for-vw-golf-7-41035
Contacted Kufatec, and used the output from OBDEleven to verify that my car was compatible (ABS and CAN Gateway, specifically).
Got the parts, contacted a shop that does a lot of VW/Audi work, and things went great until bolting it back together and configuring.
There are 5 errors in VCDS - two I think can be ignored, but I don't know what's causing the others - or if the problem is elsewhere.
The five errors are:
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
The 4B and CA errors are (I think) due to the use of the older RT interface. The 3 others are in the same 'family' (Driving Assists). Looking further into it, two of them have errors that mention the interface. The third error is fairly specific.
Here are my questions:
1) What is the most likely cause of the 3C error? The mirror itself lights up with current, and the cable harnesses are all new.
2) Would the 3C error keep the other Vehicle Assist errors from clearing? (10 and 13)
3) Would the interface itself be a potential issue from preventing configuration?
...and 4) What do I do next? Error messages are below, full VDCS readout at the end.
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000308417617229
Coding: 0271167811
Shop #: WSC 01383 790 50316
VCID: 50A59A7C0BFD04CA0D-8004
13688835 - Databus
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:28:40
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 350000C141FFC728949C810520401600000000000000000000
Shop #: WSC 00066 790 00392
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E79D4C4A16982BAEF-806A
0803 - Databus
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:25:11
Control Module temperature: 36 °C
Voltage terminal 15: 13.9 V
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 A
Component: HRE_Master H11 0080
Serial number: 0366475368
Coding: 02011103
Shop #: WSC 17873 123 50804
ROD: EV_HREntryHella_VW37.rod
VCID: 3D7BD3C8AC6F99A2F6-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 A
Component: HRE_Slave H11 0080
Serial number: 0363213069
Coding: 020111
730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
C122C 15 [009] - Open or Short to Plus
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:59:38
Wednesday,27,February,2019,19:50:49:07735
VCDS Version: 18.9.1.0
VIN: 3VWH17AUXJM756232 License Plate:
Mileage: 2694km-1673mi Repair Order:
Chassis Type AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 47 4B 52
5F 75 A5 CA
VIN: 3VWH17AUXJM756232 Mileage: 2694km-1673miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00322466002F1000
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 4689BC24F9B9DA7AA7-8012
Readiness: 1010 1101
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01706151707
ROD: EV_TCMDQ250021.rod
VCID: 59B3675858074582FA-800C
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 52117000000264
Coding: 43FA6AA1342509728079030380C529C2562C9001C001943C36435050E029430000010312121212B435351919323200
VCID: 77F701E0CED373F2EC-8022
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0445235221
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C7DDECCB77590AAC1-8068
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 0202002420011800010400001211140A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: N/A
VCID: 4895B21CF3ADCC0A55-801C
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C86412081700Y6
Shop #: WSC 00066 790 00239
ROD: EV_BCMBOSCH_018.rod
VCID: 0B1F4D10A25B6712B8-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170609 043 0551
Serial number: 97022066170703050607
Component: RLHS 042 0105
Serial number: S8Y17M07D04H15M35S29
Coding: 00A8DD
Coding: 0271167811
13688835 - Databus
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:28:40
0803 - Databus
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:25:11
Serial number: 003GCR08MPXH
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4797B120FEB3C3725C-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007HA9UX
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 17
Serial number: 3570000000048CAC152Q
Subsystem 3 - Part No SW: ----------- HW: 480 002 306 17
Serial number: 35800000000816D8652M
Subsystem 4 - Part No SW: ----------- HW: 480 400 107 17
Serial number: 3510001B325F5895C278
Subsystem 5 - Part No SW: ----------- HW: 480 400 607 17
Serial number: 3520001C32620984249T
Subsystem 6 - Part No SW: ----------- HW: 480 400 207 17
Serial number: 3550002AD23C4E41C0CG
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 207 17
Serial number: 3560002AD23C4E4072BC
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 17071704221660
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 09137718A82775028A-805C
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BA4101DED88CF0502886B0B1001000080000000
VCID: 275711A05EF32372BC-8072
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 31081700840398
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
Shop #: WSC 00066 790 07030
ROD: EV_GatewNF_VW37.rod
VCID: 336FF5F09A2B5FD210-8066
Component: 5G0959442R H17 0040
Serial number: 28170002078010121439
Coding: 35FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H55 0041
Serial number: 0325472
Serial number: HA1-00024.05.17
Coding: 0001
VCID: 4A918814EDA13E1A43-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000177762003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346DF6EC9F2558EA09-8060
Coding: 02011103
Coding: 020111
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:59:38
Component: TSG FS 011 0032
Serial number: 5038723500053
Coding: 003A13200000020000000000
Serial number: 00000000000007063716
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 9302
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FA7990016C31B3214-801A
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD00EPJ.
VCID: 2E59E4847109723A7F-807A
Address 4B: Multifunc. Module
Interface not compatible.
Component: TSG BFS 011 0032
Serial number: 6038723901232
Serial number: 00000000000007014921
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0842
Coding: 027312020000000051220002001808009F0508F401200505C6
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT2281071
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
Component: OCULowMQBUS 007 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 438FA530CA8BEF5280-8016
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 21061712P20938
Coding: 000307020002020100221344C150490084000E200120
0646 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 192
Mileage: 2694 km
Date: 2019.02.26
Time: 08:23:25
Control Module temperature: 30 °C
Outside air temperature: 15.0 °C
Vehicle speed: 0.00 km/h
System run time: 535.1 s
Voltage terminal 15: 14.0 V
mid: 00 29
Status of camera: System malfunction
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Address CA: Sunroof
End-------------------------(Elapsed Time: 07:47)--------------------------
