Results 1 to 9 of 9
Thread: 10 A6 rear brakes lock up , ABS does not cut in , but live data reading lock up
    Mar 2017
    Ireland
    Hi , hope some one seen this before, driving along and press the brake , not even that hard , and the back wheels or sometimes just one will lock , and no matter how long its locked for the abs will not cut in nor will any lights come on the dash , no faults nor even a fault while it is happening , I have tried re coding the ecu , , its extremely dangerous , i can try and post vid of live data ,
    Thursday,28,February,2019,15:02:03:34799
    VCDS Version: 18.9.1.0
    Dealer/Shop Name: GUNT TUNING
    VIN: WAUZZZ4F5AN052225   License Plate: 10C4152
    Mileage: 198460km-123317mi   Repair Order:
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 4F 52 53 56 5F 62 72
              76
    VIN: WAUZZZ4F5AN052225   Mileage: 198460km-123317miles
    Address 01: Engine (J623-CAGB)       Labels:| 03L-906-022-CAG.clb
       Part No SW: 03L 906 019 AF    HW: 03L 906 022 FG
       Component: R4 2,0L EDC   H03 6411
       Revision: 11H03---    Serial number:
       Coding: 0105002C02072120
       Shop #: WSC 02325 785 00200
       ASAM Dataset: EV_ECM20TDI03L906019AF A01006
       ROD: EV_ECM20TDI03L906019AF.rod
       VCID: 6FE6C717B61AE33234-803A
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F5 910 157 F    HW: 01J 927 156 JG
       Component: V30 01J 2.0l CR RdW 0020
       Revision: --H06---    Serial number: 00000000000329
       VCID: 2C5C101B8F8CD82A51-8078
       Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
       Component: ESP8 front      H03 0060
       Coding: 0020856
       Shop #: WSC 80093 222 69422
       VCID: 6DDADD1F7416112206-8038
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601484644
       Coding: 0000019
       Shop #: WSC 02324 785 00200
       VCID: 254AE53FEC66E9628E-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 IDG   H01 0054
       Part No SW: 4F0 910 043     HW: 4F2 820 043 K
       Component: KLIMABETAETIGUNGH20 0170
       Revision: 00000033    Serial number: 00000030503002
       Coding: 0001044
       VCID: 5BBE83C79AA26F92E8-800E
                        Reset counter: 50
                        Mileage: 198412 km
                        Date: 2019.02.27
                        Time: 10:41:55
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Coding: 0009121
       Shop #: WSC 02335 785 00200
       VCID: 346C087B57BC80EA09-8060
       Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
       Component: Airbag AU1042 H06 0160
       Revision: --------    Serial number: 003F900241B2
       Coding: 30314236303630303033554A305234463053
       ROD: EV_Airba10AURB4.rod
       VCID: 356A357F94C699E23E-8060
       Serial number: 3574SRB40000A54C794B
       Serial number: 3584SRB40000A554C175
       Serial number: 3516HRB402V9V7KGNBU$
       Serial number: 3526HRB40279V7KH9C5M
       Serial number: 3554NRB400004B730B7$
       Serial number: 3564NRB400004B68003T
    12583424 - Powertrain Databus
              U0002 00 [008] - No Communications
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90055091270051
       Coding: 0102141
       Shop #: WSC 02323 785 00200
       VCID: 2756EF37966AFB72BC-8072
       Component: E0221           H05 0080
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
       Component: KOMBIINSTR.   H08 0147
       Revision: 00000000    Serial number: DHK02PFD9
       Coding: 2F56090502000008010800
       Shop #: WSC 02391 823 56573
       VCID: 356A357F9CC699E23E-8060
       Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0035
       Revision: LB100029    Serial number: 2900L09C15010C
       Coding: 000B03
       VCID: 3972394FB0DE7D82DA-806C
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0107
       Serial number: 00000000004149001915
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000102495333
       Coding: 011C06204041410001
       VCID: 468842B3F120027AA7-8012
    03297 - Switch in Lock Cylinder; Driver Side
                        Reset counter: 224
                        Mileage: 190558 km
                        Date: 2009.10.17
                        Time: 17:10:18
       Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Component: Komfortgeraet   H29 0250
       Revision: 02500029    Serial number: 01256106880000
       Coding: 0131569
       VCID: 356A357F5CC699E23E-8060
    02935 - Control Circuit for Tail-Light; Right
                        Fault Status: 00101001
                        Fault Frequency: 32
                        Reset counter: 16
                        Mileage: 197617 km
                        Date: 2019.01.24
                        Time: 15:01:34
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
       Component: BOSE G3 C6    H01 0100
       Revision: AG001300    Serial number: 00000000054691
       Coding: 0B000000
       VCID: 2952E90F407ECD02AA-807C
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000678757
       Coding: 0001104
       VCID: 5EB88AD389B07ABA8F-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000102573623
       VCID: 458A45BFCC260962AE-8010
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000131
       Shop #: WSC 02145 785 00200
       VCID: 2142F12FF84E0542F2-8074
       Part No SW: 4F0 035 053 B    HW: 4F0 035 053
       Component: Radio U Basic H45 0020
       Revision: AB001007    Serial number: 341L/097690536
       Coding: 010003010000000000
       VCID: 1C3CC0DB1F2C28AA21-8048
       Part No SW: 4E0 035 666 C    HW: 4E0 035 666 C
       Component: H-BN-EU       H47 0047
       Revision: --------    Serial number: 454L0097533448
       Coding: 01010100010282ED01000315EF6300030001
       VCID: 2648E2335160E27A87-8072
       Subsystem 1 - Part No: 8R0 060 884 J
       Component: EUR 2010  1005
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356LY091160385
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F2 919 611 M
       Component: Bedienteil MM  H01 0060
       Serial number: 00000001478794
       Subsystem 4 - Part No: 8R0 906 961 A
       Component:   CD-Database  1293
       Revision:             Serial number: 0000102580604
       Coding: 010804204041220001
       VCID: 438E5BA7C212375280-8016
       Revision:             Serial number: 0000102580601
       Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
       Component: Parkhilfe 4-Kan H02 0500
       Revision: 00H02000    Serial number: 12331000900184
       Coding: 0001006
       VCID: 2952E90F807ECD02AA-807C
    End-------------------------(Elapsed Time: 03:18)--------------------------
    Most likely a mechanical problem not a coding problem.
    RTFB and test verify and fix mechanical error.
    Have you replaced the rear caliper that is in drag condition and tested for sticking or for burr?
    What happens when you crimp a rubber line for stuck zone & after stuck condition has happened, did you isolate the zone by opening the bleeder to see if this is indeed a hydro-static error or if as you speculate from ABS unit & to determine hold PSI or mechanical defect?
  3. Likes Uwe liked this post
    HQ
    Thank you for posting the Auto-Scan.
    • Are the rear brakes dragging? Getting super hot from normal driving?
    • Tires all the same size/brand?
    • Can you feel the ABS pump kicking in when this happens?
    Jef
  5. Likes Uwe liked this post
  6. #4
    Mar 2017
    Ireland
    ok
    tyres same size , calipers not binding , none changed either , the rear is locking up when braking but the ecu does not engage abs pumping , nor does it create a fault , i can leave 100ft of rubber on the road and still nothing , i incorrectly coded a abs unit ion mk5 golf and created the same sanario , live data is picking everything up and still nothing
    Jun 2014
    Newcastle, England
    Most ABS modules will drop the diagnostic session if you go over a certain speed. Are you ensuring you keep below this level?
    Go get the car SVM or install original coding.
    Verify no FOD!
    Mar 2017
    Ireland
    does this in or out of diagnostics , and code verified , and checked , the live data test was to check if the ecu was actually seeing the wheels locking up
  10. #8
    Aug 2014
    Maryland, USA
    Gunt,
    Has there been recent work done on the ABS hydraulic block unit?
    I had a similar case but on a VW Golf where somebody interchanged the brake pipes connections (wrong connections) on the abs hydraulic unit from VL/VR HL/HR...so during braking the wheels lock with no abs intervention.
    Double check these connections to ensure they are right especially if there has been recent work in that area.
  11. Likes Uwe liked this post
  12. #9
    Mar 2017
    Ireland
    , nothing changed of late , i will check , it would have a merky past
