This car came into my garage and I did a full scan
Clear the scan. Car some time start and non start.
Now start to see why the Engine ECU sometime not reach. so that was my first [point to check all fuses. Good.
and then check power to fuse with ignition off, 30, ignition on, 15 and 87. No power to fuse SA2, SA5, SA7, SA10, SA11, SA16
No 87, meaning relay issue or power failed to the relay, found a J317 relay have dirty contact, replace relay have sorted all above DTCs
Final scan
Wednesday,27,February,2019,11:36:43:62062
VCDS Version: 18.9.1.0
Workshop Code: 000 18261 018261
VIN: WAUZZZ4G5DN021621 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 30 36 3B 42 44 46 52 53 55
5F 62 6D 72
VIN: WAUZZZ4G5DN021621 Mileage: 106434km-66135miles
Address 01: Engine (J623-CLAA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 311 E HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0001
Revision: 53H37---
Coding: 1A254012042601020800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
ROD: EV_ECM30TDI0114G0907311E.rod
VCID: A54BB587A413E8620E-80F0
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Fault Frequency: 6
Mileage: 106430 km
Date: 2018.11.06
Time: 02:34:46
Coolant temperature: 31 °C
Intake air temperature: 15 °C
Voltage terminal 30: 11.900 V
Cruise Control System (CCS): switch position-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 15
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [044] - -
Fault Frequency: 10
Mileage: 106430 km
Time: 00:00:00
Coolant temperature: 17 °C
Intake air temperature: 12 °C
Voltage terminal 30: 11.120 V
Cruise Control System (CCS): status-Bits 0-7: 12
Engine control module reset status-Bits 0-7: 2
U1113 00 [044] - -
Fault Frequency: 10
Mileage: 106428 km
Time: 00:00:00
Coolant temperature: 25 °C
Intake air temperature: 9 °C
Voltage terminal 30: 11.200 V
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [032] - -
Mileage: 106428 km
Date: 2018.11.01
Time: 21:53:55
Coolant temperature: 9 °C
Voltage terminal 30: 11.720 V
Accelerator pedal: sensor voltage 1: 757.4 mV
Accelerator pedal: sensor voltage 2: 381.0 mV
Accelerator pedal: switch positions-Bits 0-7: 72
Starter control: Interlock- or P/N-signal-Bits 0-7: 177
Limitation: torque: 0.0 Nm
Control Module temperature: 46.4 °C
5619 - Engine Off Timer Performance
P150A 00 [032] - -
Mileage: 106428 km
Time: 00:00:00
Coolant temperature: 22 °C
Intake air temperature: 10 °C
Voltage terminal 30: 12.120 V
Shut-off timer: last engine shut-off time: 2 s
Shut-off timer: last ECM after-run time: 20 s
Time since ignition off: 2 s
Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7: 0
Terminal 15 status-Bits 0-7: 1
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Time: 00:00:00
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Part No SW: 4G1 927 156 J HW: 0B5 927 156 J
Component: 0B5 30 TDIRdW H01 0003
Revision: --H01--- Serial number: 0000000160
ASAM Dataset: EV_TCMDL501021 001008
ROD: EV_TCMDL501021.rod
VCID: B46D58C31FC981EA89-80E0
18147 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [044] - -
Fault Frequency: 16
Reset counter: 40
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
Engine speed: 0 /min
Transmission input speed: 0 /min
Engine torque: 0 Nm
Transmission fluid temperature: 6 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
8008 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [044] - -
Fault Frequency: 16
Reset counter: 40
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
Engine torque: 0 Nm
18051 - Shift Fork 2
P284A 00 [096] - Stuck
Reset counter: 40
Mileage: 106428 km
Date: 2018.11.01
Time: 21:53:53
Engine speed: 778 /min
Transmission input speed: 778 /min
Engine torque: 72 Nm
Transmission fluid temperature: 8 °C
18058 - Shift Fork 1 Position Sensor
P2845 00 [096] - Incorrect Neutral Position
Reset counter: 40
Mileage: 106428 km
Date: 2018.11.01
Time: 21:53:52
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 07A68703E065E1C0DB00
VCID: B66962CB09B593FAB7-80E2
9 Faults Found:
0004 - Brake Switch (F)
P0571 00 [008] - Implausible Signal
Fault Frequency: 10
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:10
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: F6
Uz: 9E
0069 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 17
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E3
Uz: B1
0071 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 17
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: F0
Uz: B1
0073 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 17
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: F5
Uz: B1
0075 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 17
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: F8
Uz: B1
0077 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 14
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:12
VzRef: 00
Bit Info 1: 80
Bit Info 2: 22
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: FD
Uz: 9D
0091 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 17
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: 0C
Uz: B1
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 13
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:27
VzRef: 00
Bit Info 1: 00
Bit Info 2: 2F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 04
Uz: 9C
0693 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:00
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 02
F-Type: 03
Uz: A0
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H32 0421
Coding: 01BA3046000000000000
VCID: F7F7AFCF463FAAF26C-80A2
Serial number: 2312000102692005
Fault Status: 00101101
Fault Frequency: 15
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:27
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 180
Mileage: 106434 km
Date: 2018.11.15
Time: 20:25:52
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0070
Serial number: 20061200110644
Coding: 3623000821
ASAM Dataset: EV_AirCondiBasisUDS 002040
VCID: E0C5E493FBB14D4A3D-80B4
0276 - Engine Off Timer Performance
P150A 00 [008] - -
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:09:48
Voltage terminal 30: 13.91 V
0280 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:09:48
Outside air temperature: 4.5 °C
Engine speed: 847 /min
0331 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 48
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:13
Voltage terminal 30: 12.23 V
Outside air temperature: 8.5 °C
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001354016
Coding: 2600201040349FE00181008380001D0CCF9DC30A27090201000004606100
VCID: EED98AAB3965EB3ABF-80BA
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120425 H35 0080
Serial number: 120523161512
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20349303
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 18 06 2012 00000592
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: F3F80336000000000001
Fault Frequency: 10
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:00
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061216401562
Coding: 08C304
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: F7F7AFCF4E3FAAF26C-80A2
12648448 - Databus
Fault Frequency: 13
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:13
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG0090J7U
Coding: 30314530323130303133554A305234473853
Serial number: 3575HRB404V1E4S27PL1
Serial number: 3585HRB405F1E4S0613S
Serial number: 3515JRB401A4UI5COHG/
Serial number: 3525JRB40184UI5CL91D
Serial number: 3554VRB400Q4UE20GPA2
Serial number: 3564VRB400Q4UE20GH8-
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120620000647
Coding: 000034
VCID: B06554D3E3D1BDCAED-80E4
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Part No SW: 4G8 920 983 C HW: 4G8 920 983 C
Component: TDieGb H79 0515
Revision: 28460207 Serial number: 658130612596051
Coding: 33A600020B432600010100
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: B56B65C714B398E2BE-80E0
16776971 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 14
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:28
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000573273
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: F0E594D32B51FDCAAD-80A4
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790282431
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 0204120000000000016E
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Fault Frequency: 37
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:02:26
Voltage terminal 30: 14.2 V
Voltage terminal 15: 0.0 V
Control Module temperature: 5 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
6678 - Voltage Regulator Stage 1
C10AF F2 [024] - Supply Voltage Lower Limit Not Reached
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:01:51
Voltage terminal 30: 10.4 V
Voltage terminal 15: 10.4 V
Control Module temperature: 13 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: On
Datenfeld: 0
6688 - Voltage Regulator Stage 2
C10AF F6 [024] - Supply Voltage Lower Limit Not Reached
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:01:51
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [008] - -
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:02:11
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 1
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000029391
Coding: 01010101000000000001000202
VCID: E4CDE883E7A9516AD9-80B0
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000032618965
Coding: 0078130000006001000001010101102030303232203232
Fault Frequency: 18
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:29
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H02 0053
Revision: -------- Serial number: EJ1BPA72000RG3
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
VCID: B36F5BDF1AC786D290-80E6
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011F56024E21620002080402
VCID: C7971F0F765F1A72DC-8092
Fault Frequency: 67
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:14
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0006633595
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B2615EDBE5DD8FDA9B-80E6
3158274 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 148
Reset counter: 220
Mileage: 106428 km
Date: 2018.09.25
Time: 00:00:24
Write only channel
18689 - Terminal 30
U140A 00 [008] - Open Circuit
Fault Frequency: 6
Reset counter: 220
Mileage: 106428 km
Date: 2018.09.25
Time: 00:00:23
Write only channel
19714 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:44
Write only channel
Revision: 00002001 Serial number: 0178377374
Coding: 013B062220B9B80083200A040001020F0000000000000000000000000000
Subsystem 3 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0028
Serial number: WA103647000001501514
03700 - Control Module for Rear Spoiler Positioning
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:34
Fault Frequency: 15
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:27
Component: TSG BF H03 0506
VCID: C689120B7155037A27-8092
Fault Frequency: 67
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:14
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000382714
ROD: EV_ParkiBrake_VW51.rod
VCID: AB5F43BFC2F7DE12D8-80FE
333568 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
Voltage terminal 30: 13.1 V
Internal Fault ID: 49
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
334080 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
Internal Fault ID: 51
RWU: not active
DSD: not active
HTR: not active
ECD: not active
721408 - Terminal 30
Reset counter: 220
Voltage terminal 30: 0.0 V
Internal Fault ID: 61
Vehicle speed: 510 km/h
Network management state: Reset
Function light in parking brake button: OFF
Red operating lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Emergency running mode
Status ParkingBrake left: Initializing
Status ParkingBrake right: Initializing
331264 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
Internal Fault ID: 99
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331520 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:26
Internal Fault ID: 100
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331776 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 14
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 23:16:10
Voltage terminal 30: 12.1 V
Internal Fault ID: 101
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 120615-0001-001
Coding: 1123A6101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: AC5D40A3C7F9D92AD1-80F8
0095 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 15
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:29
336388 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 15
Reset counter: 220
Mileage: 106428 km
Date: 2018.10.28
Time: 00:00:29
Part No SW: 4G0 035 192 G HW: 4G0 035 192 F
Component: RMC Nav Plus H52 0775
Coding: 0101040101C1DB47082B060301010000000001
VCID: A649B28BD115E37A07-80F2
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464FT0C2532901
Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Serial number: 90349LFG000DE
Component: TSG HL H03 0506
Coding: 010F14024021620002080002
VCID: C9931937604BEC02CA-809C
Part No SW: 4G8 959 107 N HW: 4G8 959 107 F
Component: HDSG-Modul H13 0039
Revision: 11013001 Serial number: 140200559
Coding: 0A3305C002
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: C08504135B712D4A1D-8094
Component: TSG HR H03 0506
End-------------------------(Elapsed Time: 04:40)--------------------------
Wednesday,27,February,2019,11:52:57:62062
5F 62 6D 72
Revision: 53H37---
U1113 00 [032] - -
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:30
Engine speed: 826.00 /min
Normed load value: 24.3 %
Coolant temperature: 41 °C
Voltage terminal 30: 11.880 V
U1113 00 [032] - -
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:30
U0100 00 [032] - -
Reset counter: 40
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
Engine torque: 0 Nm
Transmission fluid temperature: 24 °C
Voltage terminal 30: 12.500 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.916 V
U0100 00 [032] - -
Reset counter: 40
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
Engine torque: 0 Nm
8 Faults Found:
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: F6
Uz: A2
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E3
Uz: A2
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: F0
Uz: A2
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: F5
Uz: A2
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: F8
Uz: A2
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:02
VzRef: 00
Bit Info 1: 80
Bit Info 2: 2F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: FD
Uz: A1
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 01
F-Type: 0C
Uz: A2
U1113 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:01
VzRef: 00
Bit Info 1: 80
Bit Info 2: 2F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 04
Uz: A1
00955 - Key 1
Reset counter: 180
Mileage: 106434 km
Date: 2018.11.17
Time: 19:05:40
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:01
Coding: 3623000821
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:03
Voltage terminal 30: 12.59 V
Outside air temperature: 11.5 °C
Coding: 0045F7
Coding: 02006E
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
Coding: 08C304
12648448 - Databus
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:03
Coding: 000034
ROD: EV_RBD4K.rod
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:02
Coding: 00CD077D00
Voltage stabilizer:
U0100 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:10
Voltage terminal 30: 12.7 V
Control Module temperature: 20 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:03
ROD: EV_SARA2.rod
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:05
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:02
Write only channel
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:01
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:05
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
Voltage terminal 30: 12.4 V
RWU: not active
DSD: not active
HTR: active
ECD: not active
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
RWU: not active
DSD: not active
HTR: active
ECD: not active
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
RWU: not active
DSD: not active
HTR: active
ECD: not active
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
RWU: not active
DSD: not active
HTR: active
ECD: not active
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:00
RWU: not active
DSD: not active
HTR: active
ECD: not active
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:03
U1111 00 [008] - -
Reset counter: 220
Mileage: 106434 km
Date: 2018.11.17
Time: 19:11:03
Coding: 0A3305C002
End-------------------------(Elapsed Time: 04:35)--------------------------
Final scan
Wednesday,27,February,2019,23:17:42:62062
5F 62 6D 72
VIN: WAUZZZ4G5DN021621 Mileage: 106435km-66135miles
Revision: 53H37---
Coding: 3623000821
Coding: 0045F7
Coding: 02006E
Coding: 08C304
Coding: 000034
ROD: EV_RBD4K.rod
Coding: 00CD077D00
Voltage stabilizer:
ROD: EV_SARA2.rod
Coding: 0A3305C002
End-------------------------(Elapsed Time: 04:31)--------------------------
