2017 NMS Passat with Byte 18 problem
Bakhtiyar
Iraq
C?ID=356829
Hi everyone,
I have a problem with park assist car picture which is appears from display when change gear to reverse , the picture will appear is jetta not passat how can I change it to passat ???
thanks
Bakhtiyar
Welcome to our forum.
Please post an Auto-Scan so people can see exactly how your car is equipped and configured.
Bakhtiyar
Iraq
C?ID=356829
Thank you
this is the attached txt file for auto scan,also I have a problem with front & rear lifgts which have this fault ( 02896 - Control Circuit for LED Module for DRL and Parking Light , 02898 - Control Circuit for LED Module for DRL and Parking Light; Right )
Wednesday,13,February,2019,20:34:24:31085
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
VIN: WVWCR7A32HC013413   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 46 47 4F 52 5F
          62 72
VIN: WVWCR7A32HC013413   Mileage: 25580km-15894miles
Address 01: Engine (CCC)       Labels: None
   Part No SW: 07K 906 055 EE    HW: 07K 907 309 B
   Component: 2,5L 125KW      G01 1501
   Revision: T4H07---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 75A2E6731CB85BE2FE-8020
   Part No SW: 09G 927 750 NH    HW: 09G 927 750 NH
   Component: AQ 250 6F           2623
   Revision: 00H97000    Serial number:
   Coding: 0000328
   VCID: 04448BB74762726AF9-8050
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5892308FDA30F03E5911C10612010F019
   VCID: 75A2E673DCB85BE2FE-8020
02214 - Tire Pressure Warning
                    Reset counter: 208
                    Mileage: 25284 km
                    Date: 2019.02.05
                    Time: 19:05:50
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 52369
                    Count: 1024
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0408651272
   Coding: 032C0C
   VCID: 3A38354FBD26F49AD3-806E
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0010019002
   VCID: 5AF895CF5D66149AF3-800E
   Part No SW: 5K0 937 087 AK    HW: 5K0 937 087 AK
   Component: BCM PQ35 H++  122 0184
   Revision: BM122001
   Coding: 68200E3B882908D4008804003400816002F1000645A00DB0E4806000AC70
   VCID: 7EB0F95FE98E18BAAF-802A
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 020716 04  42  0106
   Coding: 0038DD
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331618300622
   Coding: 0071155011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   VCID: 373E2C7B8E34E9F22C-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM07M5LB
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW41.rod
   VCID: 6386A82B6A2CD552A0-8036
   Serial number: IBH000000000005MMN2Y
   Coding: 30324D
   Subsystem 2 - Part No SW: -----------    HW: 480 001 006 16
   Serial number: 35700000000292DCEB1-
   Subsystem 3 - Part No SW: -----------    HW: 480 002 106 16
   Serial number: 35800000000915B81C1L
   Subsystem 4 - Part No SW: -----------    HW: 480 022 306 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B3210BB1226FW
   Subsystem 5 - Part No SW: -----------    HW: 480 020 407 16
   Component: SideSensor_Pr  000 0148
   Serial number: 35200019D20E2701C6B2
   Subsystem 6 - Part No SW: -----------    HW: 480 020 306 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001C12149AB3178/
   Subsystem 7 - Part No SW: -----------    HW: 480 020 306 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001C12149AB3014U
   Part No SW: 1K5 953 501 AJ    HW: 5K0 953 569 AN
   Revision: FF010042    Serial number: 20160614300177
   Coding: 0102440008
   VCID: 73A6D86BDACC45D2D0-8026
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1741622491602419AD1B
   Coding: 280000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 881 B    HW: 561 920 881 B
   Component: KOMBI         H03 1104
   Coding: 611E010000
   VCID: 1A78D5CF1DE6D49A33-804E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 25071603010413
   Coding: 461010
   VCID: 7BB6F04BFA9C0D9288-802E
   Component: IMMO          H03 1104
   Coding: 000007
   VCID: 6A98C50F8D06841A63-803E
   Revision: 00000000    Serial number: 16000110930004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 312A1263605037C262-8064
   Serial number: 0410870478
   Coding: 02011102
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C343357B712CAAAC1-8068
   Component: HRE_Slave  H12 0071
   Serial number: 0409092296
   Coding: 020111
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010612678
   Coding: 3414BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E70D9DF01CEB8BACF-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746160813161629
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 198
                    Mileage: 25429 km
                    Date: 2019.02.10
                    Time: 00:22:34
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0095893
   VCID: 281CFF07538A760AB5-807C
   Component: EZE_2         H56 1682
   Coding: 01030108
   VCID: 6FAED41BBEE4613234-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011612400789
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0003
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010626440
   Coding: 3415BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F0EE4DB06C4B1B2C4-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14202747160814223112
   Part No SW: 5C0 035 680 D    HW: 5C0 035 680 D
   Component: MU-S-N-ER     H30 0356
   Serial number: VWZAZ2S5141154
   Coding: 0263010CAA00000011110003001828001F0100D400200100C7
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2208ED2F35B69C5AEB-8076
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Open module 5F and in the very first coding Byte see what car model is selected for parking display.
Bakhtiyar
Iraq
C?ID=356829
I did it but when I change it to Passat NMS it directly appears golf type
Bakhtiyar
Iraq
C?ID=356829
Hello Mr.Uwe
could helping me for rear fog light which is turned on in auto/low beam/high beam also instead of fog light when I pulled lights switch twice near steering tail lights will be on
it means that fog light turned on instead of tail lights ,
I selected skoda superb Limousin which is same style of my lights,,,,
Appreciate you to help me for this issue
thanks
If I understood your problem and knew a solution, I would be happy to help. ;)
Bakhtiyar
Iraq
C?ID=356829
Hi Mr.Dana
I did change the style of lights from Address 09 Cent Elect , the car is Passat NMS A3 and the auto scan attached , when I changed after that nothing remain normal ,but when I changed to Skoda limousine superb all of them are okay except rear left fog light working continuously and rear right fog light has a warning at instrument cluster display ???? another thing which I want to do on this car is to correct brake lights because now the tail lights work as brake lights.....
Thanks for helping ....
          62 72
   Coding: 0000075
   Coding: 0000328
   Revision: 00H46001
                    Reset counter: 208
                    Mileage: 25284 km
                    Date: 2019.02.05
                    Time: 19:05:50
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 52369
                    Count: 1024
   Coding: 032C0C
   Revision: 00001K05
   Coding: 0010019002
   Revision: BM122001
   Coding: 0038DD
   Coding: 0071155011
   Coding: 30324D
   Coding: 0102440008
   Coding: 280000
   Coding: 611E010000
   Coding: 461010
   Coding: 000007
   Coding: 02011102
   Coding: 020111
   Coding: 3414BD
   Slave Driver:
                    Reset counter: 198
                    Mileage: 25429 km
                    Date: 2019.02.10
                    Time: 00:22:34
   Coding: 01030108
   Coding: 181100
   Coding: 3415BC
   Slave Passenger:
Yeah, you would think her avatar would make her gender obvious, no?
If this was Twitter or Facebook, Bakhtiyar would risk getting banned for mis-gendering her.
Bakhtiyar
Iraq
C?ID=356829
I don't know what do you mean Mr.Uwe , I don't mean anything I just asked about some problems which I had as you said here is not facebook or twitter for searching genders I'm just talked about technical issues not anything more.
Do you understand the difference between calling someone "Mr." and "Ms."?
If not, click here. ;)
Bakhtiyar
Iraq
C?ID=356829
Yes I know, but in my country Dana is boy not girl so it is a mistake so those things will happen and its normal
Bakhtiyar
Iraq
C?ID=356829
Sorry Ms Dana about this mistake that I did really in my country there are more than 500 people their names are Dana so I'm Sorry for that.
Bakhtiyar
Iraq
C?ID=356829
Hello Friends
          62 72
   Coding: 0000075
   Coding: 0000328
   Revision: 00H46001
                    Reset counter: 208
                    Mileage: 25284 km
                    Date: 2019.02.05
                    Time: 19:05:50
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 52369
                    Count: 1024
   Coding: 032C0C
   Revision: 00001K05
   Coding: 0010019002
   Revision: BM122001
   Coding: 0038DD
   Coding: 0071155011
   Coding: 30324D
   Coding: 0102440008
   Coding: 280000
   Coding: 611E010000
   Coding: 461010
   Coding: 000007
   Coding: 02011102
   Coding: 020111
   Coding: 3414BD
   Slave Driver:
                    Reset counter: 198
                    Mileage: 25429 km
                    Date: 2019.02.10
                    Time: 00:22:34
   Coding: 01030108
   Coding: 181100
   Coding: 3415BC
   Slave Passenger:
Dana
Western PA, USA
After checking all of the scans you sent via email the real value of Byte 18 was hidden under a pair of 00's. If you haven't done so already, make sure to check the oldest/original (factory condition) Auto-Scan on that PC and paste the 09 data here for review.
Next, we have several known NMS Passat Byte 18 values in the coding helper but they aren't LED headlight package specific. It may be difficult to fix this if VW masked the real value in all of those LED headlight cars ... but I would try changing it to HEX A0 to see if the tail light functions are restored.
Bakhtiyar
Iraq
C?ID=356829
