Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 2017 NMS Passat with Byte 18 problem
    Feb 2019
    Iraq
    Smile 2017 NMS Passat with Byte 18 problem
    Hi everyone,
    I have a problem with park assist car picture which is appears from display when change gear to reverse , the picture will appear is jetta not passat how can I change it to passat ???
    thanks
    Bakhtiyar
    Welcome to our forum.
    Please post an Auto-Scan so people can see exactly how your car is equipped and configured.
    Feb 2019
    Iraq
    Thank you
    this is the attached txt file for auto scan,also I have a problem with front & rear lifgts which have this fault ( 02896 - Control Circuit for LED Module for DRL and Parking Light , 02898 - Control Circuit for LED Module for DRL and Parking Light; Right )
    Wednesday,13,February,2019,20:34:24:31085
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    VIN: WVWCR7A32HC013413   License Plate:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 46 47 4F 52 5F
              62 72
    VIN: WVWCR7A32HC013413   Mileage: 25580km-15894miles
    Address 01: Engine (CCC)       Labels: None
       Part No SW: 07K 906 055 EE    HW: 07K 907 309 B
       Component: 2,5L 125KW      G01 1501
       Revision: T4H07---    Serial number:
       Coding: 0000075
       Shop #: WSC 09003 957 00200
       VCID: 75A2E6731CB85BE2FE-8020
       Part No SW: 09G 927 750 NH    HW: 09G 927 750 NH
       Component: AQ 250 6F           2623
       Revision: 00H97000    Serial number:
       Coding: 0000328
       VCID: 04448BB74762726AF9-8050
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: C54BC0F5892308FDA30F03E5911C10612010F019
       VCID: 75A2E673DCB85BE2FE-8020
    02214 - Tire Pressure Warning
                        Reset counter: 208
                        Mileage: 25284 km
                        Date: 2019.02.05
                        Time: 19:05:50
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 52369
                        Count: 1024
       Part No SW: 5K0 959 434 H    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 093 1305
       Revision: 00093000    Serial number: 0408651272
       Coding: 032C0C
       VCID: 3A38354FBD26F49AD3-806E
       Part No SW: 561 907 044 BD    HW: 561 907 044 BD
       Component: Climatronic   H08 0910
       Revision: 00001K05
       Coding: 0010019002
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 5AF895CF5D66149AF3-800E
       Part No SW: 5K0 937 087 AK    HW: 5K0 937 087 AK
       Component: BCM PQ35 H++  122 0184
       Revision: BM122001
       Coding: 68200E3B882908D4008804003400816002F1000645A00DB0E4806000AC70
       VCID: 7EB0F95FE98E18BAAF-802A
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 020716 04  42  0106
       Coding: 0038DD
       Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0480
       Revision: --------    Serial number: 39331618300622
       Coding: 0071155011
       ASAM Dataset: EV_EPHVA18VW364GP00 001007
       VCID: 373E2C7B8E34E9F22C-8062
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    008 0210
       Serial number: 003RXM07M5LB
       Coding: 8CCCCC00000000005000001A020800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW41.rod
       VCID: 6386A82B6A2CD552A0-8036
       Serial number: IBH000000000005MMN2Y
       Coding: 30324D
       Subsystem 2 - Part No SW: -----------    HW: 480 001 006 16
       Serial number: 35700000000292DCEB1-
       Subsystem 3 - Part No SW: -----------    HW: 480 002 106 16
       Serial number: 35800000000915B81C1L
       Subsystem 4 - Part No SW: -----------    HW: 480 022 306 16
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001B3210BB1226FW
       Subsystem 5 - Part No SW: -----------    HW: 480 020 407 16
       Component: SideSensor_Pr  000 0148
       Serial number: 35200019D20E2701C6B2
       Subsystem 6 - Part No SW: -----------    HW: 480 020 306 16
       Component: FrontSensor_D  000 0189
       Serial number: 3550001C12149AB3178/
       Subsystem 7 - Part No SW: -----------    HW: 480 020 306 16
       Component: FrontSensor_P  000 0189
       Serial number: 3560001C12149AB3014U
       Part No SW: 1K5 953 501 AJ    HW: 5K0 953 569 AN
       Revision: FF010042    Serial number: 20160614300177
       Coding: 0102440008
       VCID: 73A6D86BDACC45D2D0-8026
       Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
       Serial number: 1741622491602419AD1B
       Coding: 280000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 881 B    HW: 561 920 881 B
       Component: KOMBI         H03 1104
       Coding: 611E010000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
       VCID: 1A78D5CF1DE6D49A33-804E
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 25071603010413
       Coding: 461010
       VCID: 7BB6F04BFA9C0D9288-802E
       Component: IMMO          H03 1104
       Coding: 000007
       VCID: 6A98C50F8D06841A63-803E
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 16000110930004
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 312A1263605037C262-8064
       Component: HRE_Master    H12 0071
       Serial number: 0410870478
       Coding: 02011102
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3C343357B712CAAAC1-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0071
       Serial number: 0409092296
       Coding: 020111
       Part No SW: 561 959 701 C    HW: 3C0 959 793 J
       Component: TUER-SG FT    002 0637
       Revision: 12100010    Serial number: 0010612678
       Coding: 3414BD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1E70D9DF01CEB8BACF-804A
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  022 1472
       Serial number: 14102746160813161629
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 198
                        Mileage: 25429 km
                        Date: 2019.02.10
                        Time: 00:22:34
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H09 6831
       Revision: --------    Serial number: EAA098C0095893
       VCID: 281CFF07538A760AB5-807C
       Component: EZE_2         H56 1682
       Coding: 01030108
       VCID: 6FAED41BBEE4613234-803A
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011612400789
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
       Component: Analoguhr  002 0003
       Part No SW: 561 959 702 C    HW: 3C0 959 792 J
       Component: TUER-SG BT    002 0637
       Revision: 14100010    Serial number: 0010626440
       Coding: 3415BC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1F0EE4DB06C4B1B2C4-804A
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  022 1472
       Serial number: 14202747160814223112
       Part No SW: 5C0 035 680 D    HW: 5C0 035 680 D
       Component: MU-S-N-ER     H30 0356
       Serial number: VWZAZ2S5141154
       Coding: 0263010CAA00000011110003001828001F0100D400200100C7
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2208ED2F35B69C5AEB-8076
    End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
    Jul 2014
    Tallinn, Estonia
    Open module 5F and in the very first coding Byte see what car model is selected for parking display.
  5. Likes Dana liked this post
    Feb 2019
    Iraq
    I did it but when I change it to Passat NMS it directly appears golf type
    Feb 2019
    Iraq
    Hello Mr.Uwe
    could helping me for rear fog light which is turned on in auto/low beam/high beam also instead of fog light when I pulled lights switch twice near steering tail lights will be on
    it means that fog light turned on instead of tail lights ,
    I selected skoda superb Limousin which is same style of my lights,,,,
    Appreciate you to help me for this issue
    thanks
    If I understood your problem and knew a solution, I would be happy to help.
  9. #8
    Feb 2019
    Iraq
    Hi Mr.Dana
    I did change the style of lights from Address 09 Cent Elect , the car is Passat NMS A3 and the auto scan attached , when I changed after that nothing remain normal ,but when I changed to Skoda limousine superb all of them are okay except rear left fog light working continuously and rear right fog light has a warning at instrument cluster display ???? another thing which I want to do on this car is to correct brake lights because now the tail lights work as brake lights.....
    Thanks for helping ....
              62 72
       Coding: 0000075
       Coding: 0000328
       Revision: 00H46001
                        Reset counter: 208
                        Mileage: 25284 km
                        Date: 2019.02.05
                        Time: 19:05:50
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 52369
                        Count: 1024
       Coding: 032C0C
       Revision: 00001K05
       Coding: 0010019002
       Revision: BM122001
       Coding: 0038DD
       Coding: 0071155011
       Coding: 30324D
       Coding: 0102440008
       Coding: 280000
       Coding: 611E010000
       Coding: 461010
       Coding: 000007
       Coding: 02011102
       Coding: 020111
       Coding: 3414BD
       Slave Driver:
                        Reset counter: 198
                        Mileage: 25429 km
                        Date: 2019.02.10
                        Time: 00:22:34
       Coding: 01030108
       Coding: 181100
       Coding: 3415BC
       Slave Passenger:
  10. #9
    Quote Originally Posted by Bakhtiyar View Post
    Hi Mr.Dana
  11. Likes Uwe liked this post
  12. #10
    Yeah, you would think her avatar would make her gender obvious, no?
    If this was Twitter or Facebook, Bakhtiyar would risk getting banned for mis-gendering her.
  13. Likes PetrolDave liked this post
