Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Old Man A6 Won't Start in Antarctica
    Meme Master Katie Ross's Avatar
    May 2015
    Somewhere
    Send help.
    Wednesday,27,February,2019,12:27:26:04895
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4502.4
    VIN:    License Plate: 02-27-2019
    Mileage: 105850km-65772mi   Repair Order:
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 67 72 77
       Mileage: 105850km-65772miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
       Component: FBSAUDIC6 ELV   H30 0210
       Revision: 27120501    Serial number: 10600300127140
       Coding: 0000015
       Shop #: WSC 03743 444 20474
       VCID: E386E90B2246275220-80B6
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H43 0070
       Component: FBSAUDIC6 KSG   H26 0080
    00288 - Steering Column Lock Actuator (N360)
                014 - Defective
                        Fault Status: 01111110
                        Reset counter: 254
                        Mileage: 105851 km
                        Date: 2019.02.25
                        Time: 08:47:12
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Reset counter: 38
       Part No SW: 4F0 910 731 T    HW: 4E0 035 729
       Component: Interfacebox    H43 3360
       Revision: 00000000    Serial number: 360BL057519740
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       VCID: B326594BD226F7D290-80E6
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000114429
       Subsystem 3 - Serial number: 0122.02.050000000100010688’
       Subsystem 4 - Serial number: 010688’
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Reset counter: 26
                        Mileage: 104421 km
                        Date: 2034.07.31
                        Time: 28:24:61
                        Reset counter: 39
                        Mileage: 105851 km
                        Date: 2019.02.27
                        Time: 11:58:24
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000026    Serial number: 00000000119115
       Coding: 0524326
       Shop #: WSC 02327 785 00200
       VCID: DBF6D1EB1A361F9268-808E
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 245
                        Mileage: 103168 km
                        Date: 2018.12.24
                        Time: 09:20:19
                        Temperature: 20.0°C
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H14 0190
       Coding: 0013123
       Shop #: WSC 03763 444 58363
       VCID: AA18442F05ECB61A23-80FE
       Subsystem 1 - Component: Fehler Lin-Slave 01
       Subsystem 2 - Component: Fehler Lin-Slave 02
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7125079
       VCID: 9C7492F75FB858AAA1-80C8
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
       Component: SDAR XM         H04 0670
       Revision: 00000000    Serial number: AUZ4Z7D2021085
       VCID: AB16412B0A16AF12D8-80FE
    Address 15: Airbags
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90025050480214
       Coding: 0002041
       Shop #: WSC 02323 785 00200
       VCID: E680F01FD174527AC7-80B2
       Component: Lenkradmodul    H06 0080
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
       Component: KOMBIINSTR. M73 H10 0670
       Revision: 00500000    Serial number: 4R853ZR25
       Coding: 0065201
       Shop #: WSC 06485 067 57207
       VCID: 9E7098FF49A44ABA4F-80CA
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
       Revision: 09          Serial number: 080080521900E6
       Coding: 6CFE73CC1B7904
       VCID: A71EBD1B16FE8B723C-80F2
       Coding: 0082954
       Shop #: WSC 02325 785 00200
       VCID: E18AE303385A354232-80B4
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H44 1100
       Revision: 00000000    Serial number: 378BU057517436
       VCID: B83C6E67CB40148AA5-80EC
    02261 - Data Medium
                        Fault Status: 00101110
                        Reset counter: 4
                        Mileage: 103295 km
                        Date: 2019.01.07
                        Time: 17:18:24
                        Hex Value: 0x5C33
                        Hex Value: 0x89E0
                        Hex Value: 0x0000
                        Hex Value: 0xFD17
    02927 - DVD Read Error
                000 -  -  - Intermittent
                        Fault Frequency: 16
                        Reset counter: 39
                        Mileage: 103210 km
                        Date: 2019.01.04
                        Time: 07:26:15
                        Hex Value: 0x5C76
                        Hex Value: 0x7517
                        Hex Value: 0x04FF
                        Hex Value: 0x0000
    Address 46: Central Conv.
       Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
       Component: DSP-High C6     H14 0310
       Revision: PROD_01     Serial number: 00000000025340
       Coding: 0000026
       VCID: A404AA1767C8606A19-80F0
       Component: ILM Beifahrer   H09 0050
       Revision:             Serial number: 00000000070724
       Coding: 0001114
       VCID: DEF0D8FF09240ABA0F-808A
    Address 52: Door Elect, Pass.
    Address 53: Parking Brake
    Address 55: Headlight Range
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394BM057520850
       VCID: AE10483F3904DA3AFF-80FA
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000024866
       VCID: A306A90B62C6675260-80F6
       Subsystem 1 - Part No: 000 915 105 DK
       Component: von VA0  020627R0Z5
       Coding: 303030393135313035444B56413030323036323752305A35
       Shop #: WSC 54332 321 22222
                        Date: 2019.01.31
                        Time: 12:52:24
    02276 - Quiescent Current Stage 5
                        Mileage: 104421 km
                        Date: 2019.01.31
                        Time: 12:54:11
    02274 - Quiescent Current Stage 3
                        Mileage: 104421 km
                        Date: 2019.01.31
                        Time: 12:54:21
                        Mileage: 104421 km
                        Date: 2019.01.31
                        Time: 12:54:31
    00532 - Supply Voltage B+
                        Reset counter: 39
                        Mileage: 105851 km
                        Date: 2019.02.27
                        Time: 12:08:49
    Address 62: Door, Rear Left
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000502160018
       Shop #: WSC 12336 024 394758
       VCID: B4245A57D728F0EA89-80E0
    Address 72: Door, Rear Right
       Part No SW: 4F0 910 336 D    HW: 4E0 862 335
       Component: Handyvorb2      H10 0700
       Revision: 00000000    Serial number: 00000007516826
       Coding: 0010900
    End----(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.3V. VIgn 0.6V)------
    https://youtu.be/mqWMEbvnXrU
    To clarify- the nav system will turn on and the time and temp will light up on the dash, but the engine doesn't even try to start. I hooked it up to the battery charger for good measure though.
    United States
    Hi Katie,
    If the DTC in 05 can be cleared you might get this car to start and run again but it may do the same thing the next time you shut it off. If so, I would shake that steering wheel left and right when it is stuck on the lock to jar the faulty N360 and see if doing so allows you to clear faults and get the car going again.
    May 2015
    Somewhere
    Update:
    Cleared fault on 05 and now it works. Old man A6 must have Alzheimer's.
    Quote Originally Posted by Katie Ross View Post
    Update:
    "VCDS -- Don't leave home without it!" (And keep it up to date).
    May 2015
    Somewhere
    SHHHHH, it was TOTALLY up to date when I hooked up my car to the battery charger....
  6. Likes Jack@European_Parts liked this post
    Can we get another scan now that it powers up properly, please?
  8. Likes Jack@European_Parts liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Lots of powertrain components are completely MIA:
    And your car is supplying an oddly weak but nonzero VIgn:
    This car supplied VIgn in the past (the fact it's not in your past scan means it was >12V at the time). Here, it's supplying 0.6V. Nowhere near VBatt, but greater than the zero expected if ignition were off, or if the car didn't supply VIgn by design.
    Send help.
    If you have a wiring diagram and a multimeter and the inclination, I think you should look for marginal components like relays and fuses in the path of powertrain/ECU powerup.
    If you don't... https://www.southpa.aaa.com/
    Silence gives consent.
  10. #8
    Coding: 0000015
    014 - Defective
    Reset counter: 254
    Mileage: 105851 km
    Date: 2019.02.25
    Time: 08:47:12
    Reset counter: 38
    Fecking-A
    Unscrew that steering lock N360 and toss in garbage Ms. Katie
    https://forums.ross-tech.com/showthr...-bag-of-tricks!
  11. Likes jyoung8607, Uwe liked this post
  12. #9
    Cincinnati, OH
    Update:
    Interesting! I thought about that (Phaetons have a thing where they won't go ignition-on when some wiring to the steering column lock chafes). Odd that your car managed to go halfway ignition-on, though.
    Ah well, whatever works.
  13. #10
    May 2015
    Somewhere
    Yes sir, coming right up ASAP.
  14. Likes Jack@European_Parts, Boki Ar liked this post
