Results 1 to 7 of 7
Thread: A6 c6 optical bus diagnostic
    Pirate
    Feb 2019
    Lithuania
    Hello, I have problem with my MMI system. I found many info about common problems. But no solution for now. My MMI sometimes work very slowly, sometimes sound gone, stuck or reloading. I check all modules for water damage, everything look fine. My navigation unit was draining the battery, so I take it out and make a loop. But I think it's not a problem, becouse it just can't "sleep". Vcds don't show any errors. But main thing I can't make optical bus diagnostic. It's shows all errors (electrical and optical) , even mmi working fine. And I can connect to all modules. Can it be damaged and problem?
    Thank and sorry for my English 🙂
    Please post an Auto-Scan for context. The C6 A6 had two quite different generations of MMI.
    Pirate
    Feb 2019
    Lithuania
    I cant find right now full scan, but i will make it soon.
    Friday,22,February,2019,21:04:53:05031
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    VIN: WAUZZZ4F66N099626   License Plate:
    Control Module Part Number: 4F0 910 468 A
      Component and/or Version: Gateway         H11 0070
    Optical Bus Diagnostic : 3dB Attenuation
    Controller          	Electrical          	Optical
    19-CAN Gateway      	ERROR               	ERROR
    07-Control Head     	ERROR               	ERROR
    0E-Media Player 1   	ERROR               	ERROR
    77-Telephone        	ERROR               	ERROR
    47-Sound System     	ERROR               	ERROR
    56-Radio            	ERROR               	ERROR
    Quote Originally Posted by Pazera View Post
    Pirate
    Feb 2019
    Lithuania
    This morning my battery was empty again and i get many fault codes, becouse of that or not, i dont know.
    And what you ant to say aboaut my vcds, its too old or what?
    Please update the latest version (It free) and post an autoscan and loop bus test with the latest version please. You wont get any help unless you do this!
    Click here for downloads (Free Update)
  7. Likes Fredrick Awuor, Zenerdiode liked this post
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#lt
    Let us know if/when you gets one and we'll adjust your forum status.
