Results 1 to 6 of 6
Thread: DPF sensor adaptation not found! Help
    Pirate
    Feb 2019
    Australia
    Hi Everyone
    I have a 2011 Audi Q7 4.2TDI and have just replaced both dpf sensors after one failed (shorth to gnd confirmed). Anyway after searching this forum and youtube videos, I cant find the same situation that i am in. I cant find the adaption for the new sensors. Under Engine module 1, Coding 2 is greyed out. Under Basic Settings is resetting of dpf sensor and resetting of learned values but no adaptation first. Also checked in Adaption but that only has DFP filter initialization. Looking in Coding - 07, in the Long code at Byte 3 bit 5 has the DPF filter fitted - as unchecked! could this cause issues? Any help would be great.
    Thanks in advance
    Pirate
    Feb 2019
    Australia
    Pirate
    Feb 2019
    Australia
    Or looking back through the scan could it be an issue with :
    No ASAM data for: "EV_ECM42TID1114L0910409F" (AU56)
    Dec 2016
    Amsterdam
    Time to update the software perhaps?
    Current:
    Quote Originally Posted by MasterTommy View Post
    I think he will have to buy a legitimate interface first.
    http://www.ross-tech.com/distributors.php#au
    He can let is know if/when he gets one so and we'll adjust his forum status.
    Pirate
    Feb 2019
    Australia
    Oh cool, that explains a lot. Mental note: don't buy a second hand interface off eBay again. Will order direct from ross-tech now. Thanks guys
