Group 5 load status
   #21
Block explanation is indeed in RTFB to ref for testing.
Go read it and un-modify car first in order to check the numbers to be accurate.
Vehicle Identification No.WUAPV64B63N904881
ModelAudi RS6 qu.
RS6
Date of production10.07.2003
Year2004
Sales type4B45EZ
Engine CodeBCY
Transmission CodeGAG
Axle drive5A
EquipmentQH
https://i.postimg.cc/51d8Wt5B/Diaper-5.png?dl=1
Your Pie sir........Thank you for posting the auto-scan finally.........
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components0DSVehicle class differentiation -4B0-
Emission standard0GLEmission standard TLEV
Trailer hitch1D0without trailer towing
airbag4UBAirbag for NAR
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Label for central electric0W2Label for central electric system English-speaking countries
ApplicationsGS0Without applications
Exterior mirror setting6XLExterior mirrors with memory feature, auto-dimming, power-folding/adjustable/ heated
Left exterior mirror5SGLeft exterior mirror, flat
Right exterior mirror5RWRight exterior mirror, convex (US) large viewing field
Drive type1X1Four-wheel drive
Equipment levelsA8UExecutive US equipment
Brake type in rear1KYDisc brakes in rear
batteriesJ0ZBattery 520 A (110 Ah)
Brake type, front1LPSilver caliper
Components with special surface6FLExterior mirror housings in matte aluminum
Component part sets with country-specific design requirementsB0Abuild parts set without county specific documentatio
Owner's manuals0VMInformation kit in American English
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
General operating permit, alterationsC00Operating permit, initial registration
Shock absorption/suspension, chassis2MCSports running gear with variable damping
Roof rails/roof load rack3S0Without roof rails/roof load rack
Double DIN/dual-view display2T1Double-sized standard (DIN)
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Load-through hatch/ski bag3X1Load-through hatch with ski bag
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts7TADecorative poplar inserts "Agate"
Scuff plates7M7Scuff plates in door apertures
Park distance control7X1Park distance control
Tachograph/logbook9NXWithout electronic logbook
Headlight activation8K0Without special driving light switching
Antifreeze1C2Antifreeze up to -35 degree celsius tolerance up to -40 degree C
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Danger alarm systemVY0Without danger alarm system
Alternators8GTCompact alternator 90 - 150A
Transmission types/gearshift mechanisms0G7tiptronic
Transmission shafts, rear axle1YDTransmission shafts for rear axle, diameter 108
Transmission shafts1WGTransmission shafts 88 mm in diameter
Weight category rear axle0YRWeight range 16 installation control only, no requirement forecast
Weight category front axle0JMWeight category front axle weight range 12
Base engineT098-cyl. petrol engine 4.2 l assembly 077.A (ALU)
Tie down straps/net/pocket6M1Tie down straps
cruise control system8T1Cruise control system (CCS)
Exterior noise suppression measures2B2additional noise dampener
Garage door openerVC1Garage door opener
Luggage compartment trim5A5Luggage compartment trim, with storage compartments
Transmission specificationsG0Q5-speed automatic transmission for four-wheel drive
handle for hand brake lever6PChandbrake lever grip (leather)
Rear trim panel6V2Rear trim panel
Rear spoiler5J1Rear spoiler
Rear axle0N1Standard rear axle
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8EHBi-functional headlamps with gas discharge lamp, for driving on the right (US design)
Customized installationFC0Without individual installation
Instrument clustersU1DInstrument insert w/ mph speedo, clock, tachometer, trip odometer and additional instruments (voltage, oil temperature)
Instrument panel4N0Standard dashboard (Leather trimmed minor gauges + Ipod drawer)
Breakaway interior rearview mirror4L7Breakaway interior rearview mirror, auto-dimming, with compass
Body styleK8SNotchback with long vehicle front end
Luggage compartment floor covering6SSLuggage compartment floor covering
Cassette and CD storage unit4W0without cassette / CD tray
Child seatsQA0without child seat
headrest for seat, rear3Q6Three rear head restraints
Fuel quantity for initial filling1Z6Increase in initial standard fuel filling
Fuel systems0F2Fuel system for SI engine
Body measures5C6Additional measures for the body
Kindersitzbank3V0without child bench seat
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K5Transportation protective film (instead of paint preservation)
Steering system arrangementL0LLeft-hand drive
steering1N1Power steering
Lumbar support7P1Power adjustable lumbar support in front seats
steering wheels1XYLeather steering wheel with shift paddles and RS badge
Speaker installation8RYloudspeaker with BOSE-sound
Steering column systems2C7Safety steering column with electric axial and tilt adjustment
Leather parts3HKAlcantara scope without leather
Headlight range control8Q3Dynamic headlight range control (self-adjusting while driving)
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q2Multi-function display/trip computer with check control
Engine cooling8Z9Very hot country
Engine specificationsD0V8-cylinder SI engine 4.2 l/331 kW (40V) V8, biturbo base engine is T09
Navigation device7Q0without navigation system
rear fog lamp8TERear fog light for USA
Audi Sport/ Quattro GmbHFQ1Wheels of Audi Sport/ Quattro GmbH
WheelsCL5Alloy wheels 8.5J x 18
Radios8YNRadio "symphony" for USA
Tire pressure monitoring system7K0Without tyre pressure monitor
tireHE8Tires 255/40 R18 Y
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit3F1Collapsible spare tire
Sill top/sill cover5E0Large sill top with door cover
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Self-collection / special controlA00No self-collection
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E4Trunk lid/tailgate operation from inside
Bumper systemsVJ4bumper reinforced
Seat belt check9P1Seat belt reminder, electric contact in buckle
Center rear seat belts3C73-point seat belt for center rear seat
Gearshift boot/cover6R0Gearshift boot for automatic transmission
seat coversN7SSeat trim covers in leather
Seat adjustment3PNPower seat adjustment for both front seats with memory feature
seat heater4A4Seat heater for front and rear seats separately controlled
Safety certificate0LBWith special labels safety certificates for USA
Control number (no PR family)S3TCurrent MY, previous year vehicle identification number
Voice enhancerVX0Without voice enhancer
Audio-response system/voice controlQH0without voice control
Side and rear windows4KCSide and rear windows in heat-insulating glass
Sunroof roller blind for rear/side windows3Y0without roller blind
Handling production and pre-productionFA0Control of standard production
Headlamp washer system8X1Headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Door and lid locking system4K2Central locking system with radio remote control, two-stage unlocking
Telepass-Gerät / Mautsystem9B0Without telepay device
Type approval countries/countries with special requirementsB34Legal requirements USA
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Transit coatingNT1Transit coating (type 2)
TV reception/digital radio receptionQV4Satellite radio reception USA
Assembly parts for engine (drive bearing)1VJAssembly part for 8-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EPSpecial identification label (USA)
Type sign2Z1Type sign at rear and "Quattro" nameplates respectively
Delivery equipment2A4Delivery equipment for shipment (transit coating) with thick seat cover
First aid kit / warning triangle1T3First aid kit with warning triangle
Front seatsQ1DSports front seats
Telephone / telematics9ZSEmergency call system (NAR) (telematics 1 – fixed installation)
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GPWindshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
Additional tires (snow tires)2WAwithout spare tyre
Decorative trims4ZLMatte aluminum decorative trims
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Additional dust seals6U0Without additional seals outside
Auxiliary heating system9M0Without auxiliary heater/parking heater
cullenvb
C?ID=307906
"well here, let me restate the obvious, cut and paste what was already cited, insist on an absolutely valueless auto-scan, and lastly toss in "go google it on the interweb" for a solution."
i'll type more slowly this time. can anyone with knowledge please point out what DEFINES "wot", "enrichment", and "overrun" within group 5, field 4 of the engine module of VCDS? If there's an actual link that elaborates on this that also would be great.
in the meantime i'll be shipping my ecu to germany to get the chip de-soldered, have a stock chip put in and then returned to me. because that'll solve this thread. or perhaps i'll address my intercooler leak in hopes that the parameters for load status outputs were stamped on it all along. just as good a suggestion, really.
well this has been a real hoot. apologies all around, i didn't think i was asking such a difficult question.
   #23
I believe "Overrun" is when the throttle is closed but there's sufficient energy being back-fed from the drivetrain to keep the engine at higher than idle speed, and thus the ECU cuts off fuel entirely.
As for the exact difference between "Enrich" and "WOT", or when the ECU uses one or the other, I don't know.
WOT = wide open throttle plate.
Enrich = increasing loads advanced fuel administrated or the figurative accelerator pump point for the atmospheric change over map, like what was used historically in comparison to how carburetors used to operate.
Let me guess?
MTM = More Trouble-code Madness! :rolleyes:
You could of observed the TV position visually & by watching 0x01-08-060 >063 and logging it in VCDS.
