Results 1 to 6 of 6
Thread: Audi A3 8P 2009 ABS Long Coding (MK60EC1)
    Oct 2016
    Good Evening All,
    I have a friend that took it upon himselft to replace his instrument cluster before I had ever ran an autoscan to save his coding. Now that he has the cluster fitted there is faults left right and centre. One of which I am struggling to sort is the long coding for the abs module is now all set at 0's. Here is his autoscan. Is there anyway of calculating a long code? His car is:
    Audi A3 8P RHD
    1.8TSI
    3 Door
    Automatic
    Tuesday,26,February,2019,18:57:55:40380
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ8P5AA034091   License Plate: GV09WGF
    Mileage: 182590km-113456mi   Repair Order:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56
    VIN: WAUZZZ8P5AA034091   Mileage: 182590km-113456miles
    17-Instruments -- Status: Sporadic communication error 1000
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 8P7 907 115 L    HW: 8P0 907 115 Q
       Component: 1.8l R4/4V TFSI     0030
       Revision: AAH06---    Serial number: AUX7Z0I6FNF0FG
       Coding: 0103000C24070160
       Shop #: WSC 00191 264 15243
       VCID: 428B1DC61D126D5A8B-8016
    000665 - Boost Pressure Regulation
                   P0299 - 000 - Control Range Not Reached - Intermittent
                        Mileage: 182471 km
                        Date: 2019.02.25
                        Time: 00:55:07
                        RPM: 5408 /min
                        Load: 78.4 %
                        Speed: 53.0 km/h
                        Temperature: 99.0C
                        Temperature: 24.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 13.589 V
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal - Intermittent
                        Mileage: 182516 km
                        Date: 2019.02.25
                        Time: 16:46:46
                        RPM: 5998 /min
                        Load: 82.3 %
                        Speed: 139.0 km/h
                        Temperature: 93.0C
                        Temperature: 21.0C
                        Voltage: 13.716 V
    001299 - Incorrect Immobilizer Key
                   P0513 - 000 -  - Intermittent
                        Mileage: 371674 km
                        Date: 2019.02.15
                        Time: 00:00:16
                        RPM: 811 /min
                        Load: 14.1 %
                        Temperature: 93.0C
                        Temperature: 66.0C
                        Voltage: 11.684 V
    049493 - No Communication with Instrument Cluster
                   U0155 - 000 -  - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 92.0C
                        Temperature: 66.0C
                        Voltage: 11.938 V
    004688 - Fuel Level too Low
                   P1250 - 000 -
                        Mileage: 182598 km
                        Date: 2019.02.26
                        Time: 18:47:45
                        RPM: 748 /min
                        Load: 13.3 %
                        Temperature: 100.0C
                        Temperature: 73.0C
                        Voltage: 13.081 V
       Part No SW: 0AM 300 048 M    HW: 0AM 927 769 D
       Component: GSG DSG AG7     403 9032
       Revision: 00040034    Serial number: TFK01010080145
       Shop #: WSC 38488 001 1048576
       VCID: 3A7B652675C2259AD3-806E
    006300 - Function Restriction due to Insufficient Pressure Build-Up
                   P189C - 000 -  - Intermittent
                        Reset counter: 6
                        Mileage: 182483 km
                        Date: 2019.02.25
                        Time: 10:10:21
    006242 - Powertrain Data Bus
                   P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                        Reset counter: 10
       Revision: 00H45001
       Shop #: WSC 19021 000 1048576
       VCID: 000FD7CE939EBF4ADD-8054
    03306 - Coding Not Valid
                000 -  -  - Intermittent
                        Reset counter: 252
                        Mileage: 182598 km
                        Date: 2019.02.26
                        Time: 18:50:39
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 4161
                        Count: 47616
                        Reset counter: 252
                        Mileage: 182598 km
                        Date: 2019.02.26
                        Time: 18:47:28
                        Count: 16391
                        Count: 12
                        Count: 8192
                        Count: 195
                        Count: 44288
       Part No SW: 8P0 820 043 BL    HW: 8P0 820 043 BL
       Component: KlimavollautomatH09 0130
       Revision: 000656      Serial number: 8P0820043BL
       VCID: 77FDBC120650F8F2EC-8022
                        Reset counter: 36
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   104 0575
       Revision: 00104 AH
       Coding: 06000A2FB005F000207041E00100094C437E25AA306DD929E40008840040
       Shop #: WSC 00441 210 88110
       VCID: 326B4D066DB2DDDA1B-8066
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 024C2D
       Component: Innenraumuebe  H04 0020
       Subsystem 5 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    01134 - Alarm Horn (H12)
                        Reset counter: 248
                        Mileage: 182442 km
                        Date: 2019.02.24
                        Time: 23:57:55
                        Voltage: 13.50 V
                            Term 50 Off
                        Reset counter: 37
                        Mileage: 371674 km
                        Voltage: 11.80 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
       Part No SW: 8P0 919 475 G    HW: 8P0 919 475
       Component: PARKHILFE 4K  H06 0120
       Revision: 11001001    Serial number: 93640919504584
       Coding: 000103
       Shop #: WSC 06314 000 00000
       VCID: 428B1DC6DD126D5A8B-8016
                        Reset counter: 37
                        Temperature: 0.0C
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H06 0140
       Revision: --------    Serial number: 003FB00282KI
       Coding: 303142413039303030384A55305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 4FAD24F21640903214-801A
       Serial number: 34928RB400004EC86F97
       Serial number: 35028RB400004EC85FC1
       Serial number: 35128RB400004EC8FCC9
       Serial number: 35228RB400004EC85F8%
       Serial number: 35547RB400004ED99B85
       Serial number: 35647RB400004ED99C32
              U0155 00 [008] - -
                        Reset counter: 37
                        Time: 00:00:00
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0012142
       VCID: 468301D6313A517AA7-8012
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 M    HW: 8P0 920 982 M
       Component: KOMBIINSTR. VDO H02 0980
       Revision: D0H02002    Serial number: 2246I002001550
       Coding: 0000408
       VCID: 438518C20208645280-8016
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H16 0222
       Revision:   H16       Serial number: 4020K09715036C
       Coding: EDA11F06000202000101
       VCID: 66C3E15651FA717A47-8032
                        Reset counter: 36
                        Reset counter: 36
       Revision: D0H02002    Serial number: AUX7Z0I6FNF0FG
       Shop #: WSC 00441 210 97470
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 M    HW: 8P0 959 801 M
       Component: Tuer-SG         H04 0100
       Coding: 0000564
       VCID: 458106DA0C3C5A62AE-8010
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 233    2901
       Revision: 00H17000
       VCID: 2F6D4472BE80F03274-807A
                        Reset counter: 37
                        Voltage: 11.88 V
                            DD
                        Temperature: 35.0C
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 182598 km
                        Date: 2019.02.26
                        Time: 18:12:26
                        Battery Volts: 13.5 V
                            DU
                        Temperature: 39.0C
                        Count: 9
                        Steering Angle: 0.00
                            SteerAng n.Init
       Part No SW: 8P0 959 802 M    HW: 8P0 959 802 M
       Coding: 0000564
       Shop #: WSC 00441 210 91369
       Part No: 8P3 907 357
       Coding: 0000013
       VCID: 7AFBA5263542E59A93-802E
                        Reset counter: 37
       Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
       Component: R Concert2+     H02 0280
       Revision: 00H02000    Serial number: AUZ1Z3I5132594
       Coding: 0330101
                        Reset counter: 37
    End-------------------------(Elapsed Time: 02:19)--------------------------
    Many Thanks
    Gary
  2. Likes Dana, Jack@European_Parts liked this post
  3. #2
    United States
    Please verify this is the actual VIN: WAUZZZ8P5AA034091
    Also, check the Advanced ID function in addresses 01, 17 (and 25 which may not show a VIN at all) to verify the same VIN is shown diagnostically. Add the data to a log if you spot anything goofy so it can be pasted here.
    As long as all of the VINs match we should be able to assist.
    Oct 2016
    Thank you for your reply, My friend has now been back to me and i have logged the following as requested. All VINs seem to match.
    Saturday,02,March,2019,15:00:54:40380
                    Address 01: Engine
    Control Module Part Number: 8P7 907 115 L
      Component and/or Version: 1.8l R4/4V TFSI     0030
               Software Coding: 0103000C24070160
                Work Shop Code: WSC 00191
    Advanced Identification
         Identification: RB8-658
         Revision: AAH06---
         Date: 29.06.09
         Test stand number: 1354
         Manufacturer number: 1623
    Flash Status
         Programming Attempts: 3
         Successful Attempts: 3
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 72587 264 00191
         Flash Date: 11.01.19
    Software
         A0101
         A5.1.6a
    Misc.
         Hardware number: 8P0 907 115 Q
         Immo Challenge: 08 26 10 6A
    Car Info
         Chassis Number: WAUZZZ8P5AA034091
         Engine code: CDA
    VCDS Info:
           Labels: 06J-907-115-CDA.clb
           Readiness: 06F-907-115-AXX.crd
    Saturday,02,March,2019,15:04:54:40380
    Control Module Part Number: 8P0 920 982 M
      Component and/or Version: KOMBIINSTR. VDO H02 0980
               Software Coding: 0000408
                Work Shop Code: WSC 12345
         Identification: VDD-024
         Revision: D0H02002
         Date: 15.07.09
         Test stand number: 7601
         Manufacturer number: 0556
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Flash Tool Code: 00000 000 00000
         Flash Date: 15.07.09
    Misc.
         Hardware number: 8P0 920 982 M
         Lot Number:
         Type Lock: VDD-
    Car Info
    VCDS Info:
    Saturday,02,March,2019,15:03:27:40380
               Software Coding:
                Work Shop Code: WSC 00441
         Revision: D0H02002
         Date: 15.07.09
    Misc.
         Lot Number:
         Type Lock: VDD-
         Immo Challenge: FB CB 45 38
    Car Info
    VCDS Info:
    Many Thanks
    Gary
  5. Likes Uwe, Dana liked this post
  6. #4
    United States
    Thanks for confirming all diagnostic VINs match! I believe the factory condition 03-ABS coding was:
    13424012092500FEC80B02ED901A0081B900
    The Basic Settings on this page apply: VW Golf (1K) Brake Electronics (MK60EC1)
    Vehicle Identification No. WAUZZZ8P5AA034091
    Model audi a3 1.8 fsi
    A3
    Date of production 23.07.2009
    Year 2010
    Sales type 8P1B6G
    Engine Code CDAA
    Transmission Code LSS
    G1C 7-speed automatic transmission
    L0R Right-hand drive
    1N3 Speed-related variable steering assist (Servotronic)
    0YE Weight range 5 installation control only, no requirement forecast
    2UC Sports version
    1AT Electronic stability control (ESC)
    1ZE Disc brakes in front (Geomet D)
    1KD Disc brakes in rear
    UG1 Hill hold control
    7K0 Without tyre pressure monitor
    7X1 Park distance control
    7L3 Without start/stop system without regenerative braking
    13424012092500FEC80B02ED901A00813900 Here is my attempt
    13424012092500FEC80B02ED901A0081B900 DANA
  8. Likes Dana, gazpot0111645 liked this post
  9. #6
    Oct 2016
    I can confirm that the coding that Dana provided worked. I performed basic settings and clear of all faults. Many thanks to you all for your time and effort helping me with this, it is much appreciated.
    Regards
    Gary
  10. Likes Uwe, Jack@European_Parts, Dana liked this post
