Hi all,
I'm in the process of re-building a crash damaged 2018 Audi S5 almost done but having a couple of issues, i purchased a whole front end off a rear ended S5, but it had Matrix LED headlights and my originals are Standard LED's. So im in the process of retrofitting them. I purchased a coding dongle from Kufatech but i got a fair few fault codes come up, so far ive worked out that there are a few wiring differences between the two systems.
1. there is a front & rear level sensor - Standards only have a rear
2. there is some extra wiring to the front screen camera from the J519 connector, but im a bit confused about where the wires terminate, there are two wires from the J519 to the front camera, but there appears to be a branch from each that terminates back to the J519 to pins 24 & 25 (But this doesnt make much sense to me, so still scratching my head on that)
3. all the wiring to the headlight plug seems to be the same for the standard and Matrix
4. looking at some of the errors i may be missing wiring elsewhere but once ive installed the new wiring that i know about i will re-scan and see whats what
i know ill have to get them calibrated once done (no biggy is i need a new front windscreen).
if anyone has done this mod would greatly appreciate some advice on it
I only get to work on the car over the weekends and the Autoscan i have is a little out of date (as ive fixed a fair few of the issues now, but may give some idea of what im dealing with:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 06 08 09 15 16 17 19 29 2B 36 39 42 44 46 52 5F 6C
81 A5 A9 D6 D7
VIN: WAUZZZF57JA089594 Mileage: 4998km-3105miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Self-Diagnosis Log
Sunday,24,February,2019,10:50:25:14836
Page 2
VIN: WAUZZZF57JA089594 License Plate:
Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
Part No SW: 8W0 907 559 G HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0010
Revision: B2H22000
Coding: 1A2A00322326050B34080000000000000000000000000000
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559G 001013
ROD: EV_ECM30TFS0118W0907559G.rod
VCID: 49CF5E7B493A9D0F093-801C
19228 - Bank 1: Camshaft A (Intake)
P0010 00 [167] - Position Actuator Malfunction
Mileage: 4998 km
Time: 00:00:00
Coolant temperature: 5 °C
Intake air temperature: 7 °C
Voltage terminal 30: 12.540 V
Engine status: COENG_READY
14191 - Cam Adjustment Actuator B; Cylinder 3
P11AB 00 [167] - Elec. Malf. or Open Circuit
Mileage: 4998 km
Time: 00:00:00
Voltage terminal 30: 12.580 V
Self-Diagnosis Log
Page 3
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 8W0 927 158 B HW: 0D5 927 156 H
Component: 0D5 30TSIRdW H05 1007
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 41DF465B710A554FD13-8014
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Coding: 1CAA149A30AA0A9F11A3489A00815292E4A5D238280C508812004A4927A54B
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4DC76A6BBD52812F25B-8018
13779202 - Unknown Error Code
U1241 00 [002] - -
[LWI_NET_Message_Failure:_SAS_Cumulated_Failure]
6293505 - Steering Angle Sensor
C2008 00 [002] - Signal Qualification
Self-Diagnosis Log
Page 4
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M2 959 760 A HW: 4M2 959 760 A
Component: MEM-BFS 009 0042
Serial number: 00000304780628
Coding: 00321004000CB0010003010141010000000000000000000000000000802003
Shop #: WSC 06325 790 00001
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 38292BBF22D0148766D-806C
Self-Diagnosis Log
Page 5
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 4608000D5548440D02020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14F4F6E184067FA5-8010
Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002193936
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 5590141900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: E265 Kli Fond H40 0080
263424 - Temperature Sensor for Rear Left Seat
B1113 01 [009] - Electrical Failure
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 10:40:53
Voltage terminal 30: 12.51 V
Outside air temperature: 9.00 °C
263425 - Temperature Sensor for Rear Right Seat
B1114 01 [009] - Electrical Failure
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 10:40:53
Self-Diagnosis Log
Page 6
Self-Diagnosis Log
Page 7
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501343C13900CD050D8F141BAD84F9110B3104000000000000000020001A810A450222025609
Shop #: WSC 17873 123 50804
VCID: 025D8957348C8E57889-8056
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 120118 036 0471
Serial number: 00000001801100301504
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21177835X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 22 01 2018 01268379
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE106011823810446
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00695392
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2817000306261003
Subsystem 7 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0034
Serial number: 7008174235B180512621
Coding: BF0500
Subsystem 8 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0034
Self-Diagnosis Log
Page 8
Serial number: 7008174235B180410370
Coding: B30500
66707 - Image processing control module
U1079 00 [009] - No communication
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:57:34
average_Voltage_terminals: 12.10 V
Outside air temperature sensor-Resistance: 2.56 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 4.00 °C
interior_temperature: 4.50 °C
Vehicle speed: 0.00 km/h
67735 - Databus
[MxB not available]
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:57:31
Self-Diagnosis Log
Page 9
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00D8VL2
Coding: AACCF0C00C800000585000F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CC1676F46488827325-8018
Subsystem 1 - Part No SW: ----------- HW: 442 061 102 18
Serial number: 3577Y009D2782EE414AF
Subsystem 2 - Part No SW: ----------- HW: 442 061 102 18
Serial number: 3587Y00BB28937B19189
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 901 18
Component: SideSensor_Dr 1C7 0148
Serial number: 351770099292F3F3D45Q
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 901 18
Serial number: 3527700B1292F3F60327
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 801 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B7295D2904214
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 203 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500BF21E60053388
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 403 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 23075000E2A4CE172906
Self-Diagnosis Log
Page 10
Subsystem 8 - Part No SW: ----------- HW: 442 431 903 17
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00A72066983F4DP
Subsystem 9 - Part No SW: ----------- HW: 442 431 903 17
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00A71FD7524E37V
Self-Diagnosis Log
Page 11
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E5876844A2F7B41-8022
2101504 - Supply voltage
[Spannung auf der Kl.30 zu niedrig]
Reset counter: 215
Mileage: 4998 km
Date: 2018.11.10
Time: 09:41:16
6755328 - Cruise Control Switch
B1154 12 [008] - Short to Plus
Reset counter: 215
Mileage: 4998 km
Date: 2019.02.06
Time: 08:41:49
Freeze_Frame_Lever_Cruise_Control-Operation_time_counter: 10768 min
Freeze_Frame_Lever_Cruise_Control-Voltage_12V: 12278.91 mV
Freeze_Frame_Lever_Cruise_Control-Voltage_12VS: 0.00 mV
Freeze_Frame_Lever_Cruise_Control-Voltage_5VS: 4978.13 mV
Freeze Frame Lever Cruise Control-Voltage Decelerate Accelerate Neutral uncompen
Freeze Frame Lever Cruise Control-Voltage Decelerate Accelerate uncompensated:
Freeze_Frame_Lever_Cruise_Control-Voltage_Main_Switch_uncompensated: 47 bit
Freeze Frame Lever Cruise Control-Voltage Resume Cancel Neutral uncompensated:
Freeze_Frame_Lever_Cruise_Control-Voltage_Resume_Cancel_uncompensated: 124 bit
Freeze_Frame_Lever_Cruise_Control-Voltage_Set_Distance_Speedlimiter: 218 bit
Self-Diagnosis Log
Page 12
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0373
Coding: 25AD19DA218606000123E9601000400000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 43D34C536B16475FC3F-8016
Part No SW: 8W5 907 468 F HW: 8W5 907 468 E
Component: Gateway H43 0123
Revision: 7A000002 Serial number: 0287A828918228
Coding: 0301000100008640540700000059001268180007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180221042855 20601
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3931516904
8519683 - Energy Management Active
U140B 00 [008] - -
Reset counter: 215
Mileage: 4998 km
Date: 2019.02.23
Time: 16:32:47
EM_vehicle_state: 02 1C
Static current shutdown level: Deactivation stage 2
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime:
Self-Diagnosis Log
Page 13
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
VCID: 79AFEEBB595ACD8FD93-802C
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 18000058345018
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 323D1997C4ACFED7589-8066
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 009 0042
Serial number: 00000306611638
Coding: 00621004000CB0010003010141010000000000000000000000000000802003
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Self-Diagnosis Log
Page 14
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0129
Serial number: 0000305813751
Coding: 001F4A425001000500003482
196660 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:05
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DD4957740C4E57C89-8016
Self-Diagnosis Log
Page 15
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EB HW: 8W0 907 064 DB
Component: BCM2 MLBevo 025 0387
Coding: 013300002FB000006309A0000600000233020010804306502F04000000040030201F0001000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 0059835F3A809C479ED-8054
Ignition key:
Subsystem 1 - Part No SW: 8W0 959 754 AF HW: 8W0 959 754 AF
Component: ID-Geber H40 0105
Serial number: 3618000024018003
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY18023185A
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099770333
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 215
Mileage: 4998 km
Date: 2019.02.24
Time: 09:26:58
Supply voltages-Supply voltage: Terminal 30: 12.337 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.365 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.310 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general additional freeze frame-Stall current cutoff level: Deactivation stage
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
Self-Diagnosis Log
Page 16
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general additional freeze frame-terminal control intern status: 40 04 0A 10 04
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0129
Serial number: 0000302568223
Coding: 001F4A425001000500003480
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:05
Self-Diagnosis Log
Page 17
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 B HW: 8W5 035 035
Component: MU-P-LND-EU 034 1177
Serial number: A829B0JB057647
Coding: 01945401FF0A000053111101000A00102F0012E701700100DE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 3635258728C4E2F7741-8062
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9HBK00RZS
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK123011800020588
Component: Gracenote2 --- 1016
B1064 13 [008] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung]
Reset counter: 215
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:04
Voltage terminal 30: 12.3 V
B1066 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 4: Unterbrechung]
Self-Diagnosis Log
Page 18
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 10:41:44
Voltage terminal 30: 12.5 V
Self-Diagnosis Log
Page 19
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 D HW: 4M0 907 428
Component: Areaview 2 H11 0311
Serial number: C854606JG003963
Coding: 02940301BA0FA10008404084
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: 33331C933BB6F7DF53F-8066
9617690 - Video Signal Line for Right Surroundings Camera
B127B 01 [009] - Electrical Failure
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:05
9618000 - Left Surroundings Camera
B127E 54 [009] - Missing Calibration / Basic Setting
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:01
9591856 - Voltage Supply for Camera; Right
B1864 01 [009] - Electrical Failure
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:00
Self-Diagnosis Log
Page 20
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 F HW: 4M2 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18012445745530
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 372B28832FCE1BFF6F7-8062
Self-Diagnosis Log
Page 21
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H16 0050
Coding: 0404090400000403024023A0A50000FC00F0C020E280
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: 40D9435F7A005C47DED-8014
13679104 - Databus Front Lights
U1504 00 [009] - No Communications
[AFS_CAN_no_communication]
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:58:43
Control Module temperature: 9 °C
Voltage terminal 15: 12.10 V
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 215
Mileage: 4998 km
Date: 2019.02.24
Time: 08:58:47
1123669 - Left Matrix High Beam
C1175 54 [009] - Missing Calibration / Basic Setting
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Self-Diagnosis Log
Page 22
Time: 08:58:42
1123670 - Right Matrix High Beam
C1176 54 [009] - Missing Calibration / Basic Setting
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:58:42
0660 - No Basic Setting
B2010 00 [009] - -
[Initial_calibration_missing]
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:58:42
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 J HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0009
Serial number: 180110200223
VCID: 48C95B7F5230640716D-801C
Self-Diagnosis Log
Page 23
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 1A6DD137BC1C2697709-804E
0304 - Databus
[can message MXB_Soll_Fktx missing]
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:00
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
0304 - Databus
Reset counter: 175
Mileage: 4998 km
Date: 2019.02.24
Time: 08:55:00
End----------(Elapsed Time: 01:53, VBatt start/end: 12.3V/12.2V
