Results 1 to 10 of 11
Thread: 2007 Jetta FSI, DTC p0123 Help!
    Feb 2019
    Hello there, need some help here.
    2007 Jetta 2.0T FSI.
    Getting the code p0123 only when I apply about 50% +/- throttle. Otherwise, if I drive normal the MIL never goes on.
    So far I have checked-
    1-Fuses
    2-Grounds
    3-Battery
    4-all easily accesible connections
    5- TBA
    6- new throttle body and redid TBA.
    So what's next to try?
    Monday,25,February,2019,05:53:47:51312
    VCDS Version: 18.9.1.0 (x64)
    VIN: 3VWRJ71K28M193657   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRJ71K28M193657   Mileage: 239970km-149110miles
       Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0H52480K5
       Coding: 0403010A1C070160
       VCID: 3663991C418F0DFA37-8062
    000291 - Throttle Position Sensor (G69)
                   P0123 - 001 - Signal too High
                        Fault Status: 01100001
                        Mileage: 239967 km
                        Time: 05:40:37
                        RPM: 751 /min
                        Load: 18.8 %
                        Temperature: 84.0C
                        Temperature: 21.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.843 V
    Readiness: 0100 0100
       Part No SW: 02E 300 050 J    HW: 02E 927 770 AE
       Component: GSG DSG         082 1410
       Revision: 04708020    Serial number: 00000803061349
       VCID: 193972A0D051C2823A-804C
       Revision: 00H11001
       Coding: 0021122
       VCID: 73E56008127D58D2D0-8026
                013 - Check DTC Memory
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CF74B343F2317AA81-8028
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000000913068
       Coding: 14058E234004150007140000001400000008730B5C000100000000000000
       VCID: 6FED6C787E557C3234-803A
       Component: Wischer 100608 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    00834 - Signal for Activation of Heated Rear Window
                        Fault Status: 00101001
                        Reset counter: 86
                        Mileage: 239962 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
    00059 - Terminal 30 for Interior Lighting
                        Fault Status: 00101100
                        Reset counter: 86
                        Mileage: 239962 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
       Revision: 00000000    Serial number: AUZ4Z7H0340315
       Coding: 0000100
       VCID: 3365A00852FD18D210-8066
                        Reset counter: 46
                        Mileage: 239962 km
                        Time: 15:05:05
       Revision: 05034000    Serial number: 003B6M05HS6C
       Coding: 0013889
       VCID: 6CD77B744F43872A11-8038
       Subsystem 2 - Serial number: 6332MSME3531475ED
       Subsystem 3 - Serial number: 6342MSME353417768
       Subsystem 4 - Serial number: 6351HSME156C72718
       Subsystem 5 - Serial number: 6361HSME155B19279
       Subsystem 6 - Serial number: 63727SME1458592B5
       Subsystem 7 - Serial number: 63827SME15574119.
       Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
       Coding: 0010021
       VCID: 77FD5418060534F2EC-8022
       Part No SW: 1K0 920 954 P    HW: 1K0 920 954 P
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0002000    Serial number: VWX7Z0H52480K5
       Coding: 0023203
       VCID: 397992207091E282DA-806C
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 250408F1001010
       Coding: ED807F070003021002
       VCID: 306FAF04A3EB23CA6D-8064
       Component: IMMO            3HL 1222
       Revision: 72009005    Serial number: 00000563388517
       Coding: 0001205
                        Fault Frequency: 17
                        Reset counter: 47
                        Mileage: 239962 km
                        Reset counter: 47
                        Mileage: 239962 km
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.070 H08 1901
       VCID: 35619E105C8906E23E-8060
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 040733D447D36F6AF9-8050
       Revision: 72009005    Serial number: 00000077088605
       Coding: 0001204
       VCID: 70EF6F04636B63CA2D-8024
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
                        Reset counter: 86
                        Reset counter: 86
                        Mileage: 239962 km
       Component: Radio DE2       016 0020
       Revision: 00016000    Serial number: VWZ4Z7H2208304
       Coding: 0010400
       VCID: 2959426080315202AA-807C
    00003 - Control Module
                014 - Defective
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000003168685
       Coding: 0001168
       VCID: 3E73813C69BFC5BAEF-806A
       Coding: 0100101
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000003130042
       Coding: 0001168
       VCID: 3F8DFC386EB5CCB2E4-806A
                        Reset counter: 86
                        Mileage: 239962 km
    End-------------------------(Elapsed Time: 02:01)--------------------------
    You could log the data from the throttle valve sensors in MVB group 062.
    This car has ~150,000 miles on it. What kind of shape are the drivetrain mounts in? I wonder of the drivetrain is moving around enough under load to tug something to the point of causing a problem?
    Feb 2019
    I did log it this morning, values don't add up.
    I will need to check the motor mounts.
    '061			'062
    Engine Speed	Battery Voltage	Throttle Valve Angle	Throttle Valve	Throttle Valve	Accel. Pedal Pos.	Accel. Pedal Pos.
    (G28)	(Terminal 30)		Sensor 1 (G187)	Sensor 2 (G188)	Sensor 1 (G79)	Sensor 2 (G185)
     /min	 V	 %	 %	 %	 %	 %
    1200	13.63	2.7	13.3	86.7	14.8	7.4
    1200	13.63	3.1	12.9	87.1	14.8	7.4
    1200	13.63	3.1	12.9	87.1	16.4	8.2
    1200	13.536	3.5	12.9	87.1	17.2	8.6
    1160	13.536	5.5	13.7	86.3	18.4	9
    1160	13.348	7.1	16	84	27	13.3
    1160	13.536	9.8	16.8	83.6	33.6	16.8
    1360	13.63	11	18.8	81.3	34	16.8
    1520	13.536	13.7	20.3	79.7	35.9	18
    1800	13.536	18	21.9	78.1	36.7	18
    1840	13.724	20.4	25.8	74.2	40.2	19.9
    2080	13.724	23.1	27.3	72.7	40.6	19.9
    2080	13.818	25.1	28.9	71.1	42.2	20.7
    2040	13.724	26.7	31.3	68.8	43.4	21.5
    1760	13.724	29.8	32	68	44.5	21.9
    1640	13.63	73.7	42.6	57	49.2	24.2
    1680	13.724	94.5	81.3	18.4	53.1	26.2
    1760	13.724	97.6	85.5	14.1	57	28.5
    1840	13.724	99.6	88.3	11.3	57.4	28.5
    1920	13.724	99.6	88.3	11.3	60.9	30.5
    2040	13.63	99.6	88.3	11.3	62.1	30.9
    2120	13.724	99.6	88.3	11.3	64.1	32
    2240	13.724	99.6	88.3	11.3	66	32.8
    2320	13.818	99.6	88.3	11.3	66.4	33.2
    2440	13.912	99.6	88.3	11.3	67.6	33.6
    2520	13.912	99.6	88.3	11.3	68.4	34.4
    2640	13.724	99.6	88.3	11.3	69.5	34.8
    2760	13.818	99.6	88.3	11.3	69.5	34.8
    2920	13.818	99.6	88.3	11.3	69.5	34.8
    3040	13.818	99.6	88.3	11.3	69.5	34.8
    3160	13.818	99.6	88.3	11.3	69.1	34.8
    3320	13.818	99.6	88.3	11.3	67.2	33.6
    3440	13.818	99.2	87.9	11.7	66	33.2
    3560	13.724	99.6	87.9	11.7	63.3	31.6
    3720	13.724	99.6	88.3	11.3	62.1	31.3
    3840	13.818	99.6	88.3	11.3	62.1	30.9
    3920	13.818	99.6	88.3	11.3	62.1	30.9
    4040	13.63	99.6	88.3	11.3	62.1	30.9
    3280	13.63	99.6	88.3	11.3	57	28.1
    3160	13.63	34.9	87.9	11.7	49.2	24.2
    3160	13.63	25.1	35.9	64.1	44.1	21.9
    3200	13.63	18.8	26.2	73.8	37.9	18.8
    3120	13.724	12.9	22.7	77.3	31.6	15.6
    2720	13.724	7.1	19.1	80.9	27.7	13.7
    2520	13.724	7.1	16.4	84	18.4	9
    2440	13.536	6.7	16	84	14.8	7.4
    2480	13.536	7.1	16	84	14.8	7.4
    2280	13.63	6.3	16	84	14.8	7.4
    2280	13.536	6.3	15.6	84.4	14.8	7.4
    2200	13.63	6.3	15.6	84.4	14.8	7.4
    2080	13.63	5.9	15.2	84.8	14.8	7.4
    2040	13.63	5.5	15.2	84.8	14.8	7.4
    1960	13.536	5.1	14.8	85.2	14.8	7.4
    2000	13.724	5.1	14.8	85.2	14.8	7.4
    1920	13.63	5.1	14.8	85.2	14.8	7.4
    1920	13.536	5.1	14.8	85.2	14.8	7.4
    1840	13.536	5.1	14.8	85.5	14.8	7.4
    1840	13.442	4.7	14.5	85.5	14.8	7.4
    1720	13.536	4.7	14.5	85.5	14.8	7.4
    1760	13.536	4.7	14.1	85.9	14.8	7.4
    1680	13.536	4.7	14.5	85.9	14.8	7.4
    1640	13.63	4.3	14.5	85.9	14.8	7.4
    1600	13.536	4.3	14.1	85.9	14.8	7.4
    1560	13.536	3.9	14.1	85.9	14.8	7.4
    1480	13.536	3.9	14.1	85.9	14.8	7.4
    1400	13.536	3.9	13.7	86.3	14.8	7.4
    1400	13.536	3.5	13.7	86.3	14.8	7.4
    1360	13.442	3.5	13.7	86.3	14.8	7.4
    1320	13.536	3.5	13.7	86.3	14.8	7.4
    1320	13.442	3.5	13.3	86.7	14.8	7.4
    1400	13.63	3.5	13.3	86.7	14.8	7.4
    1440	13.536	3.9	13.7	86.3	14.8	7.4
    1360	13.536	3.5	13.7	86.3	14.8	7.4
    1320	13.442	3.5	13.7	86.3	14.8	7.4
    1240	13.536	3.1	13.3	86.7	14.8	7.4
    1200	13.442	3.1	13.3	86.7	14.8	7.4
    1160	13.442	3.5	13.3	87.1	14.8	7.4
    1200	13.442	3.5	13.7	86.3	14.8	7.4
    1280	13.442	3.5	13.7	86.3	14.8	7.4
    1280	13.536	3.9	13.7	86.3	14.8	7.4
    1200	13.536	3.5	13.7	86.3	14.8	7.4
    1160	13.442	3.5	13.7	86.3	14.8	7.4
    1040	13.536	3.5	13.7	86.3	14.8	7.4
    960	13.442	3.5	13.7	86.3	14.8	7.4
    1080	13.536	3.5	13.7	86.3	14.8	7.4
    1120	13.348	2.7	12.9	87.1	14.8	7.4
    1000	13.442	3.1	12.9	87.1	14.8	7.4
    920	13.442	3.1	13.3	86.7	14.8	7.4
    840	13.442	3.1	13.3	86.7	14.8	7.4
    800	13.536	3.1	13.3	86.7	14.8	7.4
    800	13.442	3.5	13.3	86.7	14.8	7.4
    800	13.63	3.5	13.7	86.3	14.8	7.4
    760	13.442	3.1	13.3	86.7	14.8	7.4
    680	13.442	3.9	13.3	86.7	14.8	7.4
    720	13.536	4.7	14.5	85.9	14.8	7.4
    880	13.63	3.5	14.1	85.9	14.8	7.4
    920	13.63	3.5	13.3	86.7	14.8	7.4
    920	13.536	3.5	13.7	86.3	14.8	7.4
    840	13.536	3.5	13.7	86.3	14.8	7.4
    840	13.536	3.5	13.3	86.7	14.8	7.4
    840	13.442	3.5	13.3	86.7	14.8	7.4
    800	13.442	3.1	13.3	86.7	14.8	7.4
    840	13.536	3.1	13.3	86.7	14.8	7.4
    800	13.63	3.1	13.3	86.7	14.8	7.4
    800	13.63	3.5	13.3	86.7	14.8	7.4
    840	13.63	3.5	13.7	86.7	14.8	7.4
    800	13.348	3.5	13.3	86.7	14.8	7.4
    800	13.536	3.5	13.3	86.7	14.8	7.4
    840	13.348	3.5	13.3	86.7	14.8	7.4
    840	13.442	3.5	13.7	86.7	14.8	7.4
    800	13.254	3.5	13.3	86.7	14.8	7.4
    840	13.63	3.5	13.7	86.3	14.8	7.4
    840	13.254	3.5	13.3	86.7	14.8	7.4
    840	13.63	3.5	13.3	86.7	14.8	7.4
    840	13.254	3.1	13.3	86.7	14.8	7.4
    800	13.348	3.1	13.3	86.7	14.8	7.4
    840	13.348	3.1	13.3	86.7	14.8	7.4
    840	13.442	3.1	12.9	87.1	14.8	7.4
    800	13.348	3.1	13.3	87.1	14.8	7.4
    800	13.536	3.1	13.3	87.1	14.8	7.4
    800	13.442	3.1	13.3	87.1	14.8	7.4
    800	13.536	3.1	12.9	87.1	14.8	7.4
    840	13.442	3.1	13.3	87.1	14.8	7.4
    840	13.348	3.1	13.3	87.1	14.8	7.4
    800	13.348	3.1	12.9	87.1	14.8	7.4
    880	13.63	3.5	13.7	86.3	14.8	7.4
    880	13.63	3.9	13.7	86.3	14.8	7.4
    800	13.442	4.3	13.7	86.3	14.8	7.4
    720	13.63	5.1	14.1	85.9	14.8	7.4
    720	13.536	5.9	14.8	85.2	14.8	7.4
    920	13.536	4.3	15.2	84.8	14.8	7.4
    880	13.63	3.1	13.7	86.3	16	7.8
    960	13.63	4.3	14.1	85.9	21.5	10.5
    1000	13.63	4.7	14.1	85.9	23	11.3
    1000	13.724	4.7	14.5	85.5	23.8	11.7
    1000	13.63	4.7	14.5	85.5	23.8	11.7
    1080	13.724	5.5	14.5	85.5	25	12.1
    1160	13.724	7.1	15.6	84.4	27.7	13.7
    1280	13.724	8.6	16.8	83.2	29.7	14.8
    1160	13.724	8.6	17.6	82.4	29.7	14.8
    1360	13.724	9.8	18	82	32	16
    1400	13.724	11	19.1	80.9	32.4	16
    1400	13.724	11	19.1	80.9	32.8	16
    1520	13.724	11.8	19.5	80.5	32.8	16.4
    1600	13.63	12.5	20.3	79.7	33.6	16.8
    1760	13.63	14.9	21.5	78.5	36.7	18.4
    1920	13.63	17.3	23.8	76.2	37.9	18.8
    1880	13.724	19.2	24.6	75.4	39.1	19.1
    1600	13.724	19.2	25.8	74.2	39.5	19.5
    1600	13.63	18.8	25.4	74.6	39.8	19.5
    1680	13.63	18.8	25.4	74.6	39.8	19.5
    1800	13.63	19.2	25.4	74.6	40.2	19.9
    1920	13.724	19.6	25.8	74.2	40.2	19.9
    2040	13.724	20	26.2	73.8	40.2	19.9
    2120	13.63	20	26.2	73.8	40.2	19.9
    1960	13.63	19.6	26.6	73.4	40.2	19.9
    1800	13.63	23.5	27.3	72.7	43.4	21.5
    1720	13.63	28.2	31.3	68.8	45.7	22.3
    1720	13.63	28.2	32.8	67.2	45.7	22.3
    1800	13.63	29.4	32.8	67.2	46.1	22.7
    1880	13.724	58.8	43.4	56.6	48	23.8
    1960	13.724	67.5	62.1	37.5	48.4	23.8
    2040	13.63	58	59.4	40.2	48.4	23.8
    1920	13.63	47.5	50.4	49.2	48.4	23.8
    1680	13.63	57.6	59.8	39.8	48.4	23.8
    1680	13.442	43.1	46.5	53.1	48.4	23.8
    1720	13.63	23.9	49.2	50.8	42.2	20.7
    1720	13.536	18.4	27.7	72.3	37.5	18.8
    1760	13.63	13.7	22.7	77.3	34.8	17.2
    1880	13.63	13.3	21.1	78.9	34.4	17.2
    1800	13.536	13.7	21.5	78.5	34.4	17.2
    1800	13.63	13.7	21.5	78.5	34.4	17.2
    1640	13.724	13.3	21.5	78.5	34.4	17.2
    1600	13.63	13.3	21.1	78.9	34.4	17.2
    1560	13.63	13.3	21.1	78.9	34.4	17.2
    1520	13.63	12.9	21.1	78.9	34.4	17.2
    1480	13.724	12.9	20.7	79.3	34.4	17.2
    1480	13.63	12.9	20.7	79.3	34.4	17.2
    1520	13.536	12.9	20.7	79.3	34.8	17.2
    1520	13.63	12.9	20.7	79.3	34.8	17.2
    1520	13.724	12.5	20.7	79.3	34.8	17.2
    1560	13.724	12.5	20.7	79.3	34.8	17.2
    1560	13.63	12.5	20.7	79.3	34.8	17.2
    1560	13.536	11.4	20.3	79.7	33.6	16.8
    1560	13.63	7.1	17.6	82.4	26.2	12.9
    1600	13.63	7.1	16	84	27.3	13.7
    1600	13.63	7.5	16.4	83.6	27.3	13.7
    1560	13.536	7.5	16.4	83.6	27.3	13.7
    1560	13.63	9	16.8	83.6	27.3	13.7
    1640	13.442	9.4	18	82	29.7	14.8
    1560	13.536	9	18	82	29.7	14.8
    1560	13.63	9	18	82	29.7	14.8
    1600	13.63	9	18	82	29.7	14.8
    1600	13.63	10.2	18.4	81.6	31.3	15.6
    1600	13.536	10.2	18.8	81.3	31.3	15.6
    1600	13.63	10.2	18.8	81.3	31.3	15.6
    1600	13.442	10.2	18.8	81.3	31.3	15.6
    1640	13.63	10.2	18.8	81.3	31.3	15.6
    1640	13.536	10.2	18.8	81.3	31.3	15.6
    1640	13.442	10.2	18.8	81.3	31.3	15.6
    1640	13.63	11	18.8	81.3	31.3	15.6
    1720	13.724	14.1	21.1	78.9	37.9	18.8
    1680	13.63	16.1	23	77.3	38.3	19.1
    1680	13.63	16.9	23.4	76.6	39.1	19.1
    1680	13.63	17.3	23.8	76.2	39.1	19.5
    1720	13.536	17.6	24.2	75.8	39.1	19.5
    1720	13.63	17.6	24.6	75.4	39.5	19.5
    1760	13.63	17.6	24.6	75.4	39.5	19.5
    1760	13.63	18	24.6	75.4	39.5	19.5
    1800	13.442	18.4	25	75	39.5	19.5
    1840	13.63	18.8	25.4	75	39.5	19.5
    1840	13.724	18.8	25.4	74.6	39.5	19.5
    1840	13.63	18.4	25.4	74.6	39.1	19.5
    1760	13.63	16.5	24.2	75.8	37.5	18.8
    1680	13.63	15.7	23.4	76.6	37.5	18.4
    1640	13.536	15.7	23	77	37.1	18.4
    1640	13.63	15.7	23	77	37.1	18.4
    1600	13.63	12.5	22.7	77.7	34.8	17.2
    1600	13.63	11	19.5	80.5	32	16
    1600	13.63	10.6	19.1	80.9	31.3	15.6
    1640	13.724	10.2	18.8	81.3	30.5	15.2
    1640	13.63	9	18.8	81.3	29.3	14.5
    1640	13.63	9	17.6	82.4	28.9	14.5
    1640	13.724	9	17.6	82.4	28.9	14.5
    1680	13.63	9	17.6	82.4	28.9	14.5
    1640	13.63	9	17.6	82.4	29.3	14.5
    1600	13.63	6.7	16	84	25.8	12.9
    1600	13.536	6.7	16	84	25.8	12.9
    1600	13.536	6.7	16	84	26.2	12.9
    1640	13.536	6.7	16	84	26.2	12.9
    1640	13.536	6.7	16.4	83.6	28.5	14.1
    1640	13.536	8.6	17.6	82.4	28.9	14.5
    1680	13.63	8.6	17.6	82.4	28.9	14.5
    1640	13.536	8.6	17.6	82.4	28.5	14.1
    1640	13.536	9	19.1	80.9	32.4	16
    1720	13.536	11	19.9	80.1	34	16.8
    1760	13.63	12.5	20.7	79.3	34.4	17.2
    1720	13.63	12.5	21.1	78.9	34.8	17.2
    1760	13.63	12.9	21.1	78.9	34.8	17.2
    1800	13.536	13.3	21.1	78.9	35.2	17.6
    1840	13.442	14.1	21.9	78.1	35.9	18
    1960	13.536	14.5	22.3	77.7	36.3	18
    1920	13.724	15.7	23	77	38.3	18.8
    1960	13.63	18	26.6	73.4	42.2	20.7
    1800	13.63	23.5	30.5	69.5	44.5	21.9
    1800	13.536	27.5	33.2	66.8	47.3	23.4
    1640	13.63	38.4	64.1	35.5	50.4	24.6
    1560	13.442	85.9	80.9	18.8	50.4	24.6
    1680	13.63	92.9	84.8	14.8	51.6	25.4
    1680	13.63	96.9	85.9	13.7	57.8	28.5
    1720	13.63	97.3	87.9	11.7	59	29.3
    1800	13.536	99.6	88.3	11.3	59	29.3
    1880	13.63	99.6	88.3	11.3	59	29.3
    1920	13.536	99.6	88.3	11.3	59	29.3
    1960	13.724	99.6	88.3	11.3	59	29.3
    2040	13.63	99.6	88.3	11.3	57.8	28.5
    2080	13.63	99.6	88.3	11.3	57	28.1
    2120	13.63	99.6	88.3	11.3	54.3	26.6
    2200	13.63	99.6	88.3	11.3	52.7	26.2
    2240	13.63	99.6	88.3	11.3	52.7	25.8
    2320	13.63	99.6	88.3	11.3	52.7	25.8
    2360	13.63	99.6	88.3	11.3	52.7	25.8
    2440	13.63	99.6	88.3	11.3	57.4	28.5
    2480	13.63	99.6	88.3	11.3	61.7	30.9
    2560	13.536	99.6	88.3	11.3	63.3	31.6
    2600	13.63	99.6	88.3	11.3	66.8	33.6
    2680	13.63	99.6	88.3	11.3	69.9	35.2
    2720	13.724	99.6	99.2	11.7	69.1	34.4
    2800	13.63	99.6	99.2	11.3	57.8	28.5
    2880	13.724	27.5	99.2	67.6	42.2	20.7
    2920	13.536	20	99.2	77.7	28.5	14.1
    2920	13.442	12.5	99.2	80.5	21.9	10.5
    2960	13.536	8.2	99.2	83.6	14.8	7.4
    2600	13.536	6.7	99.2	84	14.8	7.4
    2280	13.442	5.5	99.2	84.8	14.8	7.4
    2280	13.536	5.5	99.2	84.8	14.8	7.4
    2240	13.536	5.5	99.2	84.8	14.8	7.4
    2200	13.536	5.5	99.2	84.8	14.8	7.4
    Vehicle Identification No. 3VWRJ71K28M193657
    Model Jetta
    JEM
    Date of production 17.06.2008
    Year 2008
    Sales type 1K27V3
    Engine Code BPY
    Transmission Code KNC
    ULEV2
    Doesn't the warranty range from 120 to 150K depending on AECD component for free repairs and or reimbursement for these known defects?
    Isn't there a TSB or recall of record on the TV wiring harness for stretch and sporadic connectivity issue?
    Component: 2.0l R4/4V TFSI 0020 <<<<<<<<<<<<<<<<<<<<<<<<<<<< Update firmware required!
    Hey Hector read this link and tell me what you think and do it fast, you only have 900 miles till possible expiration?
    https://forums.ross-tech.com/showthr...l=1#post156577
    Feb 2019
    Jack, that was a good read. It's definitely worth a try.
    But in the mean time, any other suggestions on what I could try?
    My next step is checking the harness at the plug and at the ecm.
    Also verifying the motor mounts for excessive movement.
    I want to try to replicate the issue while not having to drive it.
    Any thoughts?
  7. #7
    I think that checking the harness is a grand idea but FYI that firmware update I aforementioned is also for this described condition you have too & if you read the TSB on the update and the harness issue, its under warranty but be advised the scan data you posted is proof of that time and mileage stamp to prove your reimbursement request later?
    May the data record and the fact you are using a genuine RT device set your freedom and bring you the benefits of a secure method to authenticate your possible needed paper trail of documentation?
    This is why pirate tools lose! & yours could win.
  8. #8
    Feb 2019
    Jack, do you have a minute to show me where that TSB is located?
  9. #9
    TSB/TPI # 2020922
    SVM 317D
    Transmission and engine controller get updated.............
  10. #10
    Feb 2019
    This is todays scan, different DTC came up. P0122
    Leaving work cold engine. About 20% throttle.
    VIN: 3VWRJ71K28M193657   Mileage: 240030km-149147miles
    000290 - Throttle Position Sensor (G69)
                   P0122 - 002 - Signal too Low
                        Fault Status: 01100010
                        Mileage: 240037 km
                        Time: 15:31:40
                        Temperature: 93.0C
                        Temperature: 45.0C
                        Voltage: 12.319 V
    Readiness: 0110 0101
       Revision: 00H11001
       Coding: 0021122
       Coding: 00038805
       Shop #: WSC 00066
       Coding: 0000100
                        Reset counter: 48
                        Mileage: 239987 km
                        Time: 18:07:06
       Coding: 0013889
       Coding: 0010021
       Coding: 0023203
       Coding: 0001205
                        Fault Frequency: 63
                        Reset counter: 92
                        Mileage: 239987 km
                        Fault Frequency: 12
                        Reset counter: 92
                        Mileage: 239987 km
       Coding: 0001204
                        Fault Frequency: 13
                        Reset counter: 52
                        Mileage: 239987 km
                        Fault Frequency: 10
                        Reset counter: 52
                        Mileage: 239987 km
       Coding: 0010400
                014 - Defective
       Coding: 0001168
       Coding: 0100101
       Coding: 0001168
                        Reset counter: 92
                        Mileage: 239999 km
                        Reset counter: 91
                        Mileage: 240012 km
    End-------------------------(Elapsed Time: 02:04)--------------------------
