Noticed that the Air Suspension light on the dash that normally comes on for a few seconds after start-up did not go out like it normally does. I checked the Air Suspension page on the MMI interface and all of the levels were disabled, except the one that it was set to "Dynamic". So when I got home, I hooked up the VCDS and found the following fault:
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 280AF2086EF2E5C7F65-807C
01397 - Venting Solenoid for Level Control (N111)
Fault Status: 00101001
Reset counter: 30
Mileage: 264432 km
Date: 2019.02.25
Time: 08:52:35
I have googled it and some people suggest that it might just be the Air Suspension pump relay that needs to be replaced. Looking for suggestions on where to look for this Relay or if there is anything that I should check or test?
Coding: 0015510
Reset counter: 30
Mileage: 264432 km
Date: 2019.02.25
Time: 08:52:35
