Hi please I need a vw Golf gti ABS Code and I need to know How can I coding a ABS, I have a Vag com and odis, I change a ABS module, thanks for your help
The vin number is WVWZZZ1KZ9W143456
the ABS part number is :1K0907379BK
The auto scan is :
The auto scan is :
Monday,25,February,2019,15:48:37:30029
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ1KZ9W143456 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ9W143456 Mileage: 113690km-70643miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H93NG8WJ
Coding: 040300101C070060
VCID: 356BCED15C343BE23E-8060
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Mileage: 113263 km
Time: 13:46:50
Load: 0.0 %
Temperature: 94.0°C
Temperature: 54.0°C
Absolute Pres.: 760.0 mbar
Voltage: 12.065 V
Load: 0.0 %
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0001
Part No SW: 02E 300 051 R HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1960
Revision: 04844002 Serial number: 00000810020885
VCID: 2241058DFDBABC5AEB-8076
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Revision: 00H31001
Shop #: WSC 09003 957 00200
VCID: 7CFD1BF5FF9E2AAA81-8028
Reset counter: 72
Mileage: 113691 km
Count: 7
Count: 14
Count: 12800
Count: 195
Count: 42752
Count: 9472
Count: 256
Fault Status: 01100101
Reset counter: 72
Mileage: 113691 km
Count: 2
Count: 14
Count: 12800
Count: 279
Count: 42752
Count: 9472
Reset counter: 72
Mileage: 113691 km
Count: 2
Count: 14
Count: 12800
Count: 270
Count: 42752
Count: 9472
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6DDB26B174E4B32206-8038
Revision: 00H54000 Serial number: 00000008941855
Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
VCID: 336FF0C9524025D210-8066
Component: Wischer 061008 021 0501
Coding: 00038805
Shop #: WSC 01357
Component: RLS 141008 054 0402
Coding: 00209069
Shop #: WSC 01357
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 39 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD289LMP
Coding: 0013113
VCID: 3D7BD6F16404E3A2F6-8068
Subsystem 1 - Serial number: 6332MSME427479059
Subsystem 2 - Serial number: 6342MSME4274702A8
Subsystem 3 - Serial number: 6352QSME4D111A34E
Subsystem 4 - Serial number: 6362QSME530F0612A
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 057 0101
Coding: 0012102
VCID: 78F507E50BA6068AE5-802C
Component: E0221 002 0010
Part No SW: 1K6 920 874 X HW: 1K6 920 874 X
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0005000 Serial number: VWX7Z0H93NG8WJ
Coding: 0004103
Shop #: WSC 79360 409 452358
VCID: 4895B7253BC6B60A55-801C
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 061008F1001469
Coding: ED811F060002020000
Component: IMMO VDD 2416
Shop #: WSC 04028 873 177625
Component: Tuer-SG 006 1207
Coding: 0000052
VCID: 3875C7E54B26C68A25-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 819002085103087F2D04840570084A06F0BC00
VCID: 030F600942605552C0-8056
Subsystem 1 - Component: Sounder No Answer
01134 - Alarm Horn (H12)
Reset counter: 72
Mileage: 113691 km
Time: 15:39:28
Coding: 0000052
VCID: 3973C2E1702CDF82DA-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74ED33D517CE62EAC9-8020
Part No SW: 1K0 035 180 M HW: 1K0 035 180 M
Component: Radio PM6 125 0037
Revision: 00125000 Serial number: VWZ5Z7H2273702
Coding: 0040401
VCID: 2A51EDAD858A641AA3-807E
End-------------------------(Elapsed Time: 01:39)--------------------------
