- Apr 12, 2018
- 40
- 4
- South Africa
- C?ID=260881
GOLF 6 16TDI 2011
MANUAL 5 SPEED
NO TIRE MONITORING
original fault was P0601 00 (096)- Memory check sum error
Intermittent- not confirmed
i did a software update and never solved it ,tested the battery had measured low Ah like 20ah instead of 68ah.
Stop start only works if the car stalls on pull away ,the decrease the clutch it starts
no other function works besides that.
i did find readiness fault
readiness
oxygen sensor failed or incomplete(red)
MANUAL 5 SPEED
NO TIRE MONITORING
Monday,25,February,2019,10:38:58:16946
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: AUDI VW AUTO CLINIC
Workshop Code: 996 02232 000010
VIN: WVWZZZ1KZBW100085 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZBW100085 Mileage: 100050km-62168miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 HM HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9970
Revision: --H23--- Serial number: 00000000000000
Coding: 00114014032501080000
ASAM Dataset: EV_ECM16TDI02103L906023HM 003011
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 78BC0D43C391798AE5-802C
Readiness: 0100 0000
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 133B200D092200FAC80B04EC901E0091310000
VCID: 76A0037BC1850FFAF7-8022
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001003
ROD: EV_ClimaBasis_VW36.rod
VCID: 6D922C17BCD3CC2206-8038
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 0615
Revision: 00103 AD
Coding: 48180A3A8025F1C040080080100000E441010088424D8160648087200041
VCID: 2F2EF61F7E5F7E3274-807A
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15091 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
Subsystem 3 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRACUL7G
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B36D24FB2279292C8-806E
Serial number: 3572MSME20426354ZZZJ
Serial number: 3582MSME630C6458ZZZ
Serial number: 3512QSME36256D6CZZZ1
Serial number: 3522QSME38176F22ZZZ-
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JI9000BS
Coding: 1082140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72A83F6BA5ED13DADB-8026
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000069851
Coding: E20000
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H03 0406
Coding: 170B00
VCID: 2C14E1134749052A51-8078
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 160910F1001357
Coding: E9807F0600020204000003
VCID: 2E10EB1BB955773A7F-807A
Component: IMMO H03 0406
VCID: 6A98270B8D3DDB1A63-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0000692
VCID: 312AF067A86B68C262-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0131764
VCID: 3228FF6BAD6D53DA1B-8066
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 00000000 Serial number: VWZ1Z2K8296925
Coding: 0500040004
VCID: 658254376C23F4624E-8030
Component: Batt.regelung H25 5603
Coding: 030B185A
VCID: 71AA3067A8EB28C222-8024
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790369576
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
VCID: 3522C4775C0344E23E-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131216
VCID: 3620C37B41054FFA37-8062
End----------(Elapsed Time: 01:03, VBatt start/end: 12.9V/12.9V)-----------
readiness
