Fuel Pump Priming
merael
C?ID=359448
This is my first time using VCDS and I was trying to prime the fuel pumps. I went to the Engine Control Module -- Basic Settings -- Group Code 035. There is nothing showing this is the fuel pumps and the drop down is greyed out with "No documentation available." The four boxes after "Go!" show "0/min" "12.01V" "47.7C" "62.1C"
If I hit the On button it sounds like both fuel pumps are turned on. It't just not looking like all the youtubes I've come across.
Any tips? Thanks.
2012 Audi A3 TDI.
Sunday,24,February,2019,08:34:26:34899
VIN: WAUBJAFM6CA058955   License Plate:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 56 62 72
          77
VIN: WAUBJAFM6CA058955   Mileage: 54560km-33902miles
Address 01: Engine (CBE)       Labels: None
   Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number: AUX7Z0K8FNJ0HS
   Coding: 0050078
   Shop #: WSC 25190 002 1048576
   VCID: 2C0106753A03B257125-8078
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001109062126
   Shop #: WSC 06314 000 00000
   VCID: 176BC9999385218F4F7-8042
   Revision: 00H31001
   Coding: 1150400F49270002881402E9921E0042BF0C00
   VCID: 7BA3F52983EDE5EFCBF-802E
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0180
   Revision: 000630      Serial number: 8P0820043BN
   VCID: 79AFEF2185D1D7FFD93-802C
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0719
   Revision: 00110 AF
   Coding: 6E000A0FA01336E4287241E00000054D401A60AA104DC128E40008800040
   VCID: 42DD48CDA4875427C89-8016
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0603175
   Coding: 0000100
   VCID: 3635241DF44FF887741-8062
            000 -  -
                    Reset counter: 69
                    Mileage: 54536 km
                    Date: 2019.02.23
                    Time: 11:05:03
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003FC001J80F
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50F972857A6BB6B74ED-8004
   Subsystem 1 - Part No SW: 8P0 910 339 C    HW: 8P0 959 339 C
   Component: BF-Gewichtss.  H02 0030
   Serial number: 5810000R0000005UUN
   Serial number: 3572DRB40000DFA47260
   Serial number: 3582DRB40000DFE05A34
   Serial number: 35128RB400006527990D
   Serial number: 35228RB40000641E86ET
   Serial number: 35547RB4000065F388F/
   Serial number: 35647RB4000065F4FF75
   Component: J0527           H37 0070
   Coding: 0014042
   VCID: 46D554DD84AF6807E41-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 2248K002001503
   Coding: 0272288
   Shop #: WSC 16736 002 1048576
   VCID: 3B233529CF6D25EF8BF-806E
00003 - Control Module
                    Fault Status: 01100101
                    Mileage: 49547 km
                    Date: 2018.10.01
                    Time: 11:22:36
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 280811F1001626
   Coding: 352102
   VCID: 35372311E549F39F7DB-8060
   Revision: D0H02002    Serial number: AUX7Z0K8FNJ0HS
   Shop #: WSC 44231 000 1048576
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001205
   VCID: 49CF5FE195B1877F093-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 232    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 34311E15E233EA974A5-8060
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158124231624
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001205
   VCID: 4ACD60ED90B78C67009-801E
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
   Component: R Concert2+     H05 0293
   Revision: 00H05000    Serial number: AUZ1Z3L2599309
   Coding: 0750112
   VCID: 73B3DD09A7BDADAF93F-8026
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001168
   Shop #: WSC 06314 000 1012544
   VCID: 42DD48CDA8875427C89-8016
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001168
   VCID: 43D34DC9B79D5D2FC3F-8016
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005158243
   Coding: 0001277
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.2V)-----------
I'm reasonably confident that's right.
It seems the label file is not loading due to the newer -997- fixfail software your ECU has in it.
Ignition ON / Engine OFF.
Test Duration ca. 30 Seconds
Required after Repairs where the Fuel System was drained.
After extensive repairs such as Injector Replacement and/or Fuel System Flushing, this Process should be repeated at least 3 Times.
There must be NO open Fuel Supply Lines!
merael
C?ID=359448
Thanks. I tried it, but the pumps didn’t stop at 30 seconds. So I manually stopped it and repeated that 30 second interval 3 more times. The car started right up.
_Val
Latvia
C?ID=356659
What is chain of finding correct label file in this situation?
I now know that SW number is checked first.
03L-997-030-A
03L-997-030
03L-906-019-EJ
03L-906-019
or
03L-997-030-A
03L-906-019-EJ
03L-997-030
03L-906-019
Not written in here: http://www.ross-tech.com/vag-com/labels.html
I think TEMPLATE.LBL is also a little off from actually used label files. (login, long coding, SN)
Thank you.
Yeah, the "Template" file is pretty old. :o
Dana
Western PA, USA
I realize the OP has his fuel bleeding concern resolved but VCDS Release 18.9.1 Data Version 20190215 / DS296.0 contains a redirect for that re-flashed EDC:
https://ross-tech.de/downloads/upd
If you run that updater make sure VCDS is closed (not running) while doing so.
_Val
Latvia
C?ID=356659
Will successful redirect happen even if file extension is "wrong"? :)
I don't think so, but when developing a file, you can always use the full part number, which takes a higher precedence than the re-direct.
So in this case (Part No SW: 03L 997 030 A), one could use: 03L-997-030-A.LBL and VCDS would find and open it before it went looking for a possible redirect.
merael
C?ID=359448
I ran the update that Dana linked to, which was nice because there is a lot of Greek language in this thread. I hooked up and looked at the fuel pump again and it is now labeled "Fuel Supply Pump Activation". I don't know why I needed to update as I originally downloaded VCDS on Saturday. The fuel pump turned on and ran for about 15 seconds. I forgot to see if the drop down menu was active. Based on my picture (I hope I got it here right), it looks like it is active.
Thank you everyone for your help on this. Next up is DSG temp in a couple of weeks!
Dana
Western PA, USA
I can explain that :) Our newest dataversion (label files and redirects) wasn't entirely ready to go when the Release was updated. When that happens we offer Data Version updaters that can be sent as-needed (instead of forcing another VCDS update at all users that have their PCs set to automatically check for updates.)
