Long coding changes does not save
Jonaz_6@live.se
Pirate
Walking the Plank
Sweden
LP/IP
Hi.
I’m having touble saving long coding changes, done to my cars.
I’m changing the code and saves, without issues. But next time I read the code it hasn’t changed!
Been trying to adapt rear camera and air suspension on my A6 2010. On my A4 2014, I’m trying to change front light settings.
Same problems on both cars. Long coding changes will not be saved!
What am I missing??
Jonaz_6@live.se
Pirate
Walking the Plank
Sweden
LP/IP
Thanks for reply!
Please enlighten this newbie how an autoscan would be helpful in this case.
Autoscan of all systems or just the one the I try to make changes in?
Jonaz_6@live.se
Pirate
Walking the Plank
Sweden
LP/IP
Some updates. On my A6 I have MMI and access to the green hidden menu. Tried make the correct adaption settings in there, for the rear camera and air suspension....and finally that worked it out. When I check the long coding with vcds it now has changed....
Why wouldn’t it just change when I tried through vcds directly?
Problem still persists on my A4, which dont’t have the hidden menu to go in and make changes in...
Well, a scan would tell us a lot about the car you are working on, as well as the version of VCDS and the interface...
Jonaz_6@live.se
Pirate
Walking the Plank
Sweden
LP/IP
Jonaz_6@live.se
Pirate
Walking the Plank
Sweden
LP/IP
_Val
Latvia
C?ID=356659
Well, I suppose the same reason why Engine can't be reached in latest scan.
Jonaz_6@live.se
Pirate
Walking the Plank
Sweden
LP/IP
Uhmm...really don’t get this??? What’s the problem???
As far as I know I have a genuine vcds, if that’s what this is about?
_Val
Latvia
C?ID=356659
Then you should contact cable seller and get refund.
PetrolDave
Westbury, UK
C?ID=1423
If Uwe says you've got a clone copy of VCDS then that's what you have - he's the founder of Ross-Tech so he should know :thanks:
You've been sold a clone so ask the seller for a refund and if relevant report him to your local Trading Standards for selling fake goods.
