Results 1 to 2 of 2
Thread: A6 issues after MMI unit replaced to add DAB radio support
    May 2018
    Slovenia
    Originally the A6 had no DAB radio so I managed to get MMI unit with DAB support.
    The antenna was installed, unit was replaced and DAB radio now works.
    After the unit was replaced at at the workshop it was coded with settings from the old unit.
    But there are few issues:
    - Car menu doesn't work anymore (It shows message "Car systems not available")
    - USB ports don't recognize USB devices (sticks)
    - No parking display when parking sensors are activated
    The scan shows 10 Faults Found for the unit 5F including "Control Module Incorrectly Coded":
    Thursday,21,February,2019,17:50:59:55547
    VIN: WAUZZZ4G5JN109158   License Plate:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 36 3B 42 44 46 52 53 55 5F
              62 6D 72 8F 90 AC
    VIN: WAUZZZ4G5JN109158   Mileage: 15949km-9910miles
    Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
       Component: R4 2.0l TDI   H20 4166
       Revision: 8DH20---
       Coding: 0A254012232401080000
       ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
       ROD: EV_ECM20TDI01104L906021HA_004.rod
       VCID: 6B823046E3087FEF5BF-803E
       Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
       Component: 0CK 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000001026
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002028
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 2E04F952109ACAC73C1-807A
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041180085000604
       Coding: 06A29E41604579829B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DEB2EEB10445BFD13-8014
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01A8700E000000000000
       VCID: 7CA0031A96E6E857C25-8028
       Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
       Component: KLIMA 2 ZONEN H14 0113
       Serial number: 11041800110852
       Coding: 34010908210000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 619E526E11C425BFF13-8034
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 1502003S    Serial number: 00001960321702
       Coding: 0105C01440349FE0C1014083A0001800CF9CC3082E08020100000494E101140200400024030000
       VCID: 74B02B3ABEB6A0178A5-8020
       Component: WWS57X 180226  H38 0080
       Serial number:         180305063526
       Coding: 0045F7
       Serial number: 21305132X81A955547A0
       Coding: 02006D
       Component: E1 - LDS  H07 0044
       Serial number: 12 03 2018  00001374
       Subsystem 4 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
       Component: Humidity_Sens  H02 0007
       Serial number: 8F419B1900PAG0FSA002
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H83 0098
       Revision: --------    Serial number: 003P100G64W1
       Coding: 30333130313630323637554A304C34473053
       VCID: 3B22C006D3E82F6F8BF-806E
       Serial number: 3575HRB400A5DKL2A8MI
       Serial number: 3585HRB40165DNAKA9OT
       Serial number: 3515JRB40025DPR4EGV/
       Serial number: 3525JRB405D5EP2CDPN+
       Serial number: 3554VRB405V5G08E41GI
       Serial number: 3564VRB40635FQRSNGI0
       Revision: C0068538    Serial number: 91560RCJ0001U
       Coding: 000014
       VCID: 3B22C006D3682F6F8BF-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 03 03 2018  C0005465
       Part No SW: 4G8 920 934 R    HW: 4G8 920 934 R
       Component: TDieRdw       H17 0225
       Revision: 18001312    Serial number: 658050418592003
       Coding: 13A60D000B410008010000
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 40D8B7EABA0E4CB7DED-8014
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002932798
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 002011
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 1877437304
       Voltage stabilizer:
       Serial number: 18012400000000000061
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       VCID: 678A4C76FF605B8F3F7-8032
       Revision: AA000000    Serial number: 00000311376229
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77AA1C36AFC0CB0FAF7-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820FGF3A
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3634D132E8CAF207741-8062
       Coding: 011F16015E00628002080002
       VCID: 47CAACF69FA07B8F1F7-8012
       Component: RCevo         H55 0202
       Revision: 00000001    Serial number: 0000583390
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2CC502DCD21667909-806E
       Revision: 00002001    Serial number: 0476962835
       Coding: 011A062080B93080C320088408010E470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00046752767
       VCID: 46D4A1F298AA6287E41-8012
       Part No SW: 4H0 907 801 N    HW: 4H0 907 801 M
       Component: EPB-4         H01 0020
       Revision: --------    Serial number: 00000002482501
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3332E826FBB8E72F53F-8066
       Coding: 04FA02102A630200
       VCID: 3430EB3AFEB6E0174A5-8060
       Coding: E01E00
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 021 A    HW: 4G1 035 021
       Component: MU-H-LND-EU   036 0073
       Serial number: A276A0H7530530
       Coding: 01750101FF0A000013110201C00B00002F0006E5F1700100FF
       Shop #: WSC 20440 002 104857
       ROD: EV_MUHig4CGen2HBAS_AU57.rod
       VCID: 18683F8A821E247746D-804C
       Subsystem 1 - Part No SW: V03 959 801 ES    HW: -----------
       Component: ECE 2014/2015  --- 0086
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9JY80AADB
       Multimedia Operating Unit:
       Serial number: 90349RD500081
    10 Faults Found:
    1586 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for speed shutoff thresholds]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
                        Voltage terminal 30: 12.0 V
    1587 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for language]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
    1588 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for visible MMI system languages]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
    1589 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for power management timer]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
    1595 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for audio management HMI constants]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
    1591 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for telephone audio parameters]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
    1598 - Data Set Implausible
              B2012 00 [009] -  -
              [Control module (data record download) - implausible data record for visible MMI system languages]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
              B201A 00 [009] -  -
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
                        Status_Software_Version_Management-module_name: MKBD_FC7/KBD
              U11B8 00 [009] - No Communications
              [USB - communication error]
                        Reset counter: 203
                        Mileage: 15949 km
                        Date: 2019.02.21
                        Time: 17:37:45
                        Interface for external media: status-Status: OK
       Coding: 010F14004000628002080002
       VCID: 49CEAACE89B48DFF093-801C
       Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
       Component: HDSG-Modul    H02 0049
       Revision: 13002003    Serial number: 080802130
       Coding: 111104C000
       ASAM Dataset: EV_HDSGAu571 001022
       ROD: EV_HDSGAu571.rod
       VCID: 323CED2204A2EE27589-8066
       Component: RGS-VL        H16 0080
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313EE22E01A4D53F213-8064
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 180800336
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F3AE4561790C3CF377-807A
    End----(Elapsed Time: 01:54, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
    What does mean "Control Module Incorrectly Coded"?
    With the old unit I also had Smartphone interface option installed (purchased and got codes).
    Now those codes can't be entered with the new MMI unit.
    How can I now re-install Smartphone interface option?
    Any help appreciated.
    May 2018
    Slovenia
    For those who might have the same issue here is the explanation:
    - this head unit is 4G1 035 021 A (for model year 2014)
    - not compatible with USB ports/interface I have in the car
    - it does not support Smartphone interface (supported in newer unit 4G1 035 021 J).
    So I replaced the head unit with the right one and now everything works fine.
