Does anyone know if it's possible to code out front sensors and keep rear sensors working. We put aftermarket bumper on the front without sensors.
I can't see any option in coding anywhere.
Thursday,21,February,2019,13:04:31:38330
VCDS Version: 18.9.1.0 (x64)
VIN: WA1LKCFP5AA081676 License Plate:
Mileage: 141990km-88228mi Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56 5F
62 6C 6D 72
VIN: WA1LKCFP5AA081676 Mileage: 141990km-88228miles
Address 01: Engine (J623-CALB) Labels:| 06E-907-559-CAL.clb
Part No SW: 8R0 907 559 G HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H06 0004
Revision: --------
Coding: 0121000A190F0121
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
ROD: EV_ECM32FSI.rod
VCID: 44879A79CF0E656AB9-8010
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8R0 927 158 F HW: 0B6 927 156
Component: 0B6 32 FSIUSA H05 0005
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 408F9669DB16794A9D-8014
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 M HW: 8R0 907 379 M
Component: ESP8 quattro H06 0020
Coding: 041D18
VCID: 4A9BB441E52AB31A43-801E
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0327
Coding: 0D0500
VCID: 04075A79878EA56AF9-8050
Subsystem 1 - Part No SW: 8T0 959 754 G HW: 8T0 959 754 G
Component: FBSAUDIB8 IDG H40 0070
Serial number: 0510000005813001
Component: J764 ELV MLB H37 0042
Serial number: 0210000012826001
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01100220101699
Coding: 46112000
VCID: 7AFB2481F54AE39A93-802E
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000585823
Coding: 26001096463CAF010000080300001D0D0F1C470802010161000000
VCID: 3C77E299BFFE1DAAC1-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 100206 H10 0041
Serial number: 90243014100205001139
Coding: 01DD13
Component: RLS H04 0003
Serial number: 10780400
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002601101889
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941004404219
Coding: 300105
VCID: 489F8E49FB26410A55-801C
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 229
Mileage: 141655 km
Date: 2019.02.18
Time: 19:12:26
Temperature: 5.0°C
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Reset counter: 229
Mileage: 141655 km
Date: 2019.02.18
Time: 19:12:26
Temperature: 5.0°C
01549 - Supply Voltage for Parking-Aid Sensor
Fault Status: 00101001
Reset counter: 14
Mileage: 141655 km
Date: 2019.02.18
Time: 19:09:33
Temperature: 5.0°C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 D HW: 8R0 959 655 D
Component: AirbagVW-AU10 H39 0560
Serial number: 003FRD059T8N
Coding: 30373331343230303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4581877DC4345C62AE-8010
Serial number: 6334MSME5114506C7
Serial number: 6344MSME50106F28B
Serial number: 6352QSME7B4D372C-
Serial number: 6362QSME3D4C3E32W
Serial number: 63732SME064E57383
Serial number: 63832SME074E1F00+
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JBA0004G
Coding: 000017
VCID: 3D71EF9DA4E414A2F6-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 B HW: 8R0 920 930 B
Component: KOMBIINSTR. H11 0255
Revision: 00200000 Serial number: CJI450A2A
Coding: 8B0622000B000008020000
VCID: 3365C9A592A0D2D210-8066
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0105
Revision: FB900055 Serial number: 5500F1012980B4
Coding: 00C303
VCID: 000F56699396B94ADD-8054
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140954748
Part No SW: 8R0 959 760 B HW: 8R0 959 760 B
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010075398
Coding: 00581B00000044440000
VCID: 408F9669D316794A9D-8014
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 8R0 907 566 HW: 4L0 907 566 A
Component: J0769_SWA_MasterH11 0040
Revision: 00H11000 Serial number: 6PZ 009 014-04
Coding: 0000009
VCID: 7BF521853A70DA9288-802E
Subsystem 1 - Part No: 8R0 907 568
Component: J0770_SWA_Slave_H09 0040
Subsystem 2 - Serial number: 6PZ 009 014-24
Subsystem 3 - Serial number: 5F06.02.1000H090003CL10622ÿ
Subsystem 4 - Serial number: L10622ÿ
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010091067
Coding: 011D13205E00440004
VCID: 4581877DCC345C62AE-8010
Revision: 00002001 Serial number: 0126625739
Coding: 0126023A207A749504B0053200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000215862
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H01 0220
01512 - Control Module for Sliding Roof
Fault Status: 01100101
Reset counter: 245
Mileage: 141992 km
Date: 2019.02.21
Time: 12:39:46
02907 - Control Module for Roof Shade (J394)
Reset counter: 245
Mileage: 141992 km
Date: 2019.02.21
Time: 12:39:46
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010100322
VCID: 44879A79C70E656AB9-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000435420
VCID: 3467CAB997AED5EA09-8060
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Coding: 0000021
Shop #: WSC 06334 000 00000
VCID: 306FC6A9A3B6E9CA6D-8064
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH07 0004
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335BR0A7552064
Coding: 020000020100000001
VCID: 1D310F1D042474A2D6-8048
Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
Component: H-BN-NA H47 0042
Revision: -------- Serial number: 490B-0A7547076
Coding: 010200060005A1EF51000B0E000000030000
VCID: 377DFDB586D83EF22C-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356BT0A1194724
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000462198
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102890091
Coding: 010C13204000240004
VCID: 428B9C61DD1A6B5A8B-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J01A0LW
Coding: 1020010
VCID: 3467CAB957AED5EA09-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H27 0300
Revision: -------- Serial number: 8R0827851B
VCID: 3B75E185BAF01A92C8-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H27 0300
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102890094
End-------------------------(Elapsed Time: 04:00)--------------------------
