Results 1 to 8 of 8
Thread: Port injector reading
    Jul 2018
    Australia
    Hi all,
    Please can some one help me. I have a Passat TSI R-line 2.0 EA888 gen 3
    does anyone know how I can log the measurements on the port injector?
    any help is gratefully received
    Without a scan to see exactly what ECU this car has, that could be quite difficult.
  3. Likes Eric, PetrolDave liked this post
    Jul 2018
    Australia
    https://ibb.co/Y7L8Ldw
    hi UWE, hope this works, let me know idf you require anything else, cheers
    We need you to insert a full Auto-Scan not just a screen shot - see my signature for a link which shows how-to
  6. Likes Uwe liked this post
    Jul 2018
    Australia
    Sorry guys, I’m running some logs in about an hour so will get this done
    Jul 2018
    Australia
    Saturday,23,February,2019,10:55:38:53577
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ3CZHE064587   License Plate:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
              55 5F 6C A5 BB BC CF
    VIN: WVWZZZ3CZHE064587   Mileage: 31924km-19836miles
    BC-Door Rear Pass -- Status: Malfunction 0010
    Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1D00322466050B3000
       Shop #: WSC 05311 115 00311
       ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
       ROD: EV_ECM20TFS0203G0906259B.rod
       VCID: 2B03FB49238824CF1BF-807E
    16469 - Throttle Actuator Control Circuit
              P2100 00 [032] - Open Circuit
                        Mileage: 30922 km
                        Date: 2019.02.09
                        Time: 09:31:24
                        Coolant temperature: 48 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 11.875 V
                        Unlearning counter according OBD: 11
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 97 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                        FAC_TPS_1_SAE: 16.015625 %
                        FUP_H_SAE: 12740.0 kPa
    Readiness: 0010 0001
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A TVS  H54 4999
       Revision: 06354004    Serial number: TFK01608060079
       Shop #: WSC 05311 115 12345
       ROD: EV_TCMDQ250021.rod
       VCID: 53F383A95B785C0F73F-8006
              P1734 00 [002] - -
       Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
       Component: ESC           H62 0736
       Revision: 00000000    Serial number: 62366000003171
       Coding: 0EEC938F54261B70477C070841CA6970C92AD8E2E0829675384250B8C2A902
       Shop #: WSC 00015 115 08193
       VCID: 7BA30B099368744FCBF-802E
    0156 - ASR and ESP Switch
              C109C 29 [008] - Signal Implausible
                        Reset counter: 142
                        Mileage: 31923 km
                        Date: 2019.02.22
                        Time: 17:38:58
    Address 05: Acc/Start Auth.
       Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
       Revision: 00001K10
       Coding: 1112000420010001111550000010182A
       ROD: EV_ACClimaBHBVW37X_006_VW48.rod
       VCID: 76B51A3DA84A2927B41-8022
              B10CD 00 [009] -  -
                        Reset counter: 142
                        Mileage: 30922 km
                        Date: 2019.02.09
                        Time: 10:22:10
                        Voltage terminal 30: 10.9 V
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0222
       Revision: --------    Serial number: 865806081601DO
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015F79E1F1841E9F913-8054
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    160723  043 0607
       Serial number:         160730130427
       Component: RLHS  042 0105
       Serial number: S4Y16M08D30H05M30S21
       Coding: 00A8DD
       Light switch:
       Serial number: 31 05 2016  10000617
       Serial number: 000000000ZY162041D5B
       Serial number: 00000000000066540919
    589592 - Databus
              U1201 00 [008] - No Communications
              [CAN Keine Kommunikation]
                        Reset counter: 40
                        Mileage: 31196 km
                        Date: 2019.02.12
                        Time: 20:22:22
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 97
                        Mileage: 30326 km
                        Date: 2019.02.02
                        Time: 16:17:00
    262936 - Sensor for anti-theft alarm system
              B1330 29 [008] - Signal Implausible
       Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0161
       Serial number: 000305183616238
       Coding: 0371167851
       Shop #: WSC 05311 115 00084
       ASAM Dataset: EV_EPHVA2CAU3700000 009017
       ROD: EV_EPHVA2CAU3700000_009_VW48.rod
       VCID: 0D4755D1BDDC4AFFE5B-8058
       Component: ACC BOSCH MQB H04 0194
       Coding: 320467D359FFC428949C8045
       Shop #: WSC 00015 115 00001
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3431E035FEB67B374A5-8060
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 151
                        Mileage: 30922 km
                        Date: 2019.02.09
                        Time: 09:31:24
                        Control Module temperature: 47 °C
                        Voltage terminal 15: 11.6 V
       Serial number: 14081641350236
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 3829D405E2DE9F5766D-806C
       Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003STPFUCZTY
       Coding: 98FCC0C0000000005C540000008800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F5BFF198770686FE77-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 508 16
       Serial number: 3576U00000029C757C1K
       Subsystem 2 - Part No SW: -----------    HW: 454 000 508 16
       Serial number: 3586U000000620557C14
       Subsystem 3 - Part No SW: -----------    HW: 454 800 608 16
       Serial number: 3516R716F040C0000001
       Subsystem 4 - Part No SW: -----------    HW: 454 800 608 16
       Serial number: 3526R732A2D0C0000006
       Subsystem 5 - Part No SW: -----------    HW: 454 803 107 16
       Serial number: 3556V42A1650B0000003
       Part No SW: 3Q0 953 521 DA    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160806501742
       Coding: 0810
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 72BD262DC4223507989-8026
       Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
       Component: KOMBI         404 2153
       Coding: 27A40018FF88000801886B0B1001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 28090445327E0FD7F6D-807C
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 163
                        Mileage: 30307 km
                        Date: 2019.02.02
                        Time: 15:44:26
       Revision: --------    Serial number: 26081610520303
       Coding: 030300347F085900FB00025A9C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013_VW48.rod
       VCID: 7CA1081596667377C25-8028
       Serial number: 29160001656180096344
       Coding: 2DFFFF
       Serial number: 75410803001608302422
       Analog clock:
       Component: Analoguhr  209 2002
    8531970 - Quiescent Current
              U1406 00 [008] - Too High
              [Ruhestrom oberer Grenzwert überschritten]
                        Reset counter: 182
                        Mileage: 31924 km
                        Date: 2019.02.23
                        Time: 00:59:22
                        Supply voltage: Terminal 30: 12.3 V
                        Terminal 15: OFF
       Serial number: HA1-00001.08.16
       Coding: 0301
       VCID: 4ACD9ECD8C321DC7009-801E
       Serial number: 16000193219014
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BF2921C1240E1F613-8024
       Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
       Component: Sitzmemory    H05 0020
       Serial number: Y0006PHP14224
       Coding: 0014000000000500818280808080000000008181000000F400
       VCID: 3A2DCE0DDCD28D47909-806E
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0310
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       Serial number: 051116EK416027
       Coding: 003F1A20D201020000000000
       VCID: 43D3B3E9AB18CC8FC3F-8016
              B122D 29 [008] - Signal Implausible
                        Fault Frequency: 10
                        Reset counter: 181
                        Mileage: 30530 km
                        Date: 2019.02.04
                        Time: 12:20:04
    65799 - Door Warning / Enrty Lighting
              B1775 01 [008] - Electrical Failure
                        Reset counter: 158
                        Mileage: 31169 km
                        Date: 2019.02.12
                        Time: 08:15:46
    65649 - Lamp for Ambient Illumination
              B1325 13 [008] - Open Circuit
                        Reset counter: 158
                        Mileage: 31169 km
                        Date: 2019.02.12
                        Time: 08:15:46
       Coding: 9307
       Shop #: WSC 00015 115 00311
       ROD: EV_SteerAssisMQB_013.rod
       Serial number: 170616EFH03214
       Coding: 003F1020DE01020200001000
       VCID: 42DDB6EDB402C587C89-8016
                        Reset counter: 159
                        Mileage: 31169 km
                        Date: 2019.02.12
                        Time: 08:49:54
                        Reset counter: 158
                        Mileage: 31169 km
                        Date: 2019.02.12
                        Time: 08:49:54
       Component: AFS-ECU       H01 0120
       Coding: 03A603000F210200
       Shop #: WSC 05311 000 08193
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3FDBBF19C7F0A86FA77-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    5538554 - LED Headlamp; Right
              C1178 F0 [008] - Over-Temp Protection Active
                        Reset counter: 182
                        Mileage: 30922 km
                        Date: 2019.02.09
                        Time: 10:21:12
       Part No SW: 3G0 035 045 C    HW: 3G0 035 045
       Component: MU-H-N-RW     H51 0687
       Serial number: A688E0G7503256
       Coding: 02840108FF00000051510001000808001F0106E601200002DF
       VCID: 1E65229D603AC1678C1-804A
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL03A0P
       Subsystem 2 - Part No SW: V03 959 801 EB    HW: -----------
       Component: ROW 2016/2017  --- 0058
       Component: Gracenote2---  --- 4009
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 0184010162002017000040
       Shop #: WSC 05311 000 00150
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 77AB1739AF40502FAF7-8022
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 29081611P12051
       Coding: 000408010000010100022346C050410084000E300000
       Serial number: 120816DH704787
       Coding: 000E10200101020000000000
       VCID: 45D7ADF1A52CF2BFEDB-8010
       Serial number: 120816DH70478A
                        Reset counter: 153
                        Mileage: 31015 km
                        Date: 2019.02.09
                        Time: 14:00:11
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
       VCID: 3537DD31F5CC623F7DB-8060
    End----(Elapsed Time: 02:32, VBatt start/end: 10.7V/10.1V. VIgn 10.2V)-----
    Having scrolled through the half a bazillion measuring values available from that ECU, I don't see anything that shows the low-pressure (port) injection vs. the high-pressure (direct) injection.
    You could have a look at:
    IDE00148 -- Median injection timing
    IDE00472 -- Mean injection quantity
    IDE07019 -- Number of ignitions direct injection
    IDE07020 -- Number of ignitions intake manifold injection
    But I'm not sure any of that is really what you're looking for.
  10. #8
    Jul 2018
    Australia
    Worked great, got the info we needed. Thanks for your help.
  11. Likes Uwe liked this post
