Please help me with coding for VW golf 2014 abs
Thank you
Thank you
Thursday,21,February,2019,08:13:45:40565
VCDS Version: 18.9.0.4
VIN: WVWZZZAUZEP585163 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP585163 Mileage: 28537km-17732miles
Address 01: Engine (J623-CRKB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 AP HW: 04L 907 309 E
Component: R4 1,6L EDC H22 6561
Revision: 86H22---
Coding: 01250012032405092000
Shop #: WSC 46211 001 1048576
ASAM Dataset: EV_ECM16TDI01104L906021AP 002010
ROD: EV_ECM16TDI01104L906021AP.rod
VCID: 73E5B1C4DA2B5DD2D6-8026
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
Coolant temperature: 10 °C
Intake air temperature: 12 °C
Voltage terminal 30: 11.740 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 2
Cruise control switch actuation-Bits 0-7: 32
Cruise control switch actuation-Bits 0-7: 1
ACC variants (coding)-Bits 0-7: 1
Acceleration: 0.000 m/s˛
4716 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
Limitation: accelerator pedal: 111.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
Part No SW: 0CW 300 047 R HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5201
Revision: 00043014 Serial number: CU501406206744
Shop #: WSC 00028 028 00066
ROD: EV_TCMDQ200021_VW31.rod
VCID: 4A9B0C20ED217C1A45-801E
21221 - No Communications with Parking Brake Control Module
U0128 00 [011] - -
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
Engine speed: 4.25 /min
Engine torque: -100 Nm
Vehicle speed: 54 km/h
Control Module temperature: -20 °C
CURRENT pressure: -9.5 bar
Clutch: primary stat: Driving
Driving position: N
Accelerator position: 0.4 %
DTC memory status: 8448
21193 - No Communication with Cruise Control Module
U0104 00 [011] - -
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
Driving position: N
DTC memory status: 8704
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61834000001190
VCID: 46833810F939987AA1-8012
9 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 103
Date: 2019.02.20
Time: 10:17:45
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 103
Date: 2019.02.20
Time: 10:17:45
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 103
Date: 2019.02.20
Time: 10:17:45
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 103
Date: 2019.02.20
Time: 10:17:45
4161 - Coding invalid
U10DA 00 [008] - -
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:25:52
8290 - Coding Not Possible
U10BC 00 [137] - -
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:50
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:50
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:49:11
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 103
Date: 2019.02.20
Time: 10:17:45
Part No SW: 5G0 907 044 AF HW: 5G0 907 044 AF
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00020104202100011005000000101000
VCID: 6BD5A9A4821B85121E-803E
459015 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
B10CD 00 [009] - -
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 14:02:44
Voltage terminal 30: 11.0 V
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 N HW: 5Q0 937 086 N
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86581003140771
Coding: 00001842C241005B4BE44000000403081000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_012.rod
VCID: 45813F1CC43F9362A8-8010
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140618 043 0551
Serial number: 140624201506
12810 - Bulb for Right Back-up Light
B12CC 15 [009] - Open or Short to Plus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 18:22:44
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 18:24:03
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 04071403210674
Coding: 001C1100FE0739
VCID: 387F46E883CDFE8A23-806C
8 Faults Found:
1071 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
Control Module temperature: 44 °C
Voltage terminal 15: 11.6 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s˛
1058 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
1059 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
1039 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
1807 - No Enable Indentifications Active
B2032 00 [009] - -
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
0261 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:43
1083 - Databus
Reset counter: 143
Mileage: 28537 km
Date: 2019.02.20
Time: 20:30:28
Control Module temperature: 10 °C
Voltage terminal 15: 13.8 V
Vehicle speed: 1.21 m/s
Acceleration: 0.50 m/s˛
1075 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 18:22:49
Control Module temperature: 24 °C
Voltage terminal 15: 13.1 V
Vehicle speed: -0.54 m/s
Acceleration: -0.32 m/s˛
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R08T4CI
Shop #: WSC 00028 028 00065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 41892B0CD017BF4294-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 107 14
Serial number: 357670000009870D001N
Subsystem 2 - Part No SW: ----------- HW: 480 000 107 14
Serial number: 358670000006C82D001S
Subsystem 3 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3516502B11697523330U
Subsystem 4 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3526502AF169752482FL
Subsystem 5 - Part No SW: ----------- HW: 480 402 306 14
Serial number: 3556502A3156E9E2915J
9682162 - Multiple collision brake
B13BC F2 [137] - No function
Mileage: 28537 km
Date: 2019.02.20
Time: 10:49:14
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 05071404400056
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BF599E4F27B15928E-802E
Part No SW: 5G0 920 861 A HW: 5G0 920 861 A
Component: KOMBI 252 2210
Coding: 07A412082F80000800886801040000
Shop #: WSC 63480 001 104857
VCID: 275D95945E736172BA-8072
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:47
16776967 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
16776970 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
16776973 - Databus
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 30061410800591
Coding: 030100040B087300EF0002581C0F00010001050000000000000000000000
ROD: EV_GatewConti_011_VW37.rod
VCID: 428B2400D511A45A8D-8016
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29140001215820054236
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 1612983703
Part No SW: 5Q4 959 593 C HW: 5Q4 959 593 B
Component: TSG FS 009 0015
Serial number: 0000108037297
Coding: 003A03208000020000001000
Shop #: WSC 00028 028 00216
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005864861
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
19204 - Databus
Reset counter: 40
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:44
Motor status: 00
Supply voltage: 11.50 V
Temperature: 22.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 21
uioUdNotFilt_xdu16: 11.72 V
uAdSensI_SwitchedKl30_xdu16: 11.72 V
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000108026938
Coding: 003A01208000020000801000
VCID: 44872218CF05AA6ABF-8010
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005952879
Coding: 090000
B122D 29 [009] - Signal Implausible
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 18:24:04
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 040 0421
Serial number: V1C02003140575
Coding: 02730200FF00000011110001000800001F0100840100010001
Shop #: WSC 00028 028 00068
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9PS2001PF
B1061 13 [009] - Open Circuit
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:48
Voltage terminal 30: 11.6 V
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Reset counter: 103
Mileage: 28537 km
Date: 2019.02.20
Time: 10:17:45
End-------------------------(Elapsed Time: 03:57)--------------------------
