Hi Folks,
I replaced both of my fuel pumps and filter a month ago and bought VCDS and was able to prime both pumps and get the car going. I filled the tank twice and smelled gas both times. In an effort to fix the issue, i wanted to clean the o-ring and lube it with silicone, but it went wrong. I had too much gas in the tank and it leaked, I then just tightened the lid and cleaned up the mess ... I did not prime the pumps.
I drove to work the next day - 10 miles - all was well ... On the way home, I had a misfire.
Well, I can find where to prime to fuel pump in the tank in the rear, but I can't find the option to prime the high pressure fuel pump up front. Where is it!?! Where is this in the menus?
Also, I replaced the door lock with a new one from China and the alarm stopped working. I have a used OEM replacement, and that will fix that error. I also replaced a broken rear window and the glass break sensor is not connected.
Thanks ...
Thanks ...
Wednesday,20,February,2019,17:08:05:57978
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Mileage: 160620km-99804mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
72
Mileage: 160620km-99804miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0001
Revision: E1H15---
Coding: 010C010A190F0160
Shop #: WSC 26110 444 11239
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79AFEF640957756FD93-802C
4063 - Cylinder 4
P0304 00 [237] - Misfire Detected
Mileage: 160607 km
Date: 2019.02.19
Time: 16:54:50
Engine speed: 4147.50 /min
Normed load value: 90.6 %
Vehicle speed: 61 km/h
Coolant temperature: 77 °C
Intake air temperature: 18 °C
Voltage terminal 30: 14.135 V
4057 - Cylinder 2
P0302 00 [096] - Misfire Detected
7960 - Cylinder Disabling
P130A 00 [044] - -
Mileage: 160619 km
Date: 2019.02.19
Time: 19:12:57
Engine speed: 795.00 /min
Normed load value: 14.9 %
Coolant temperature: 60 °C
Intake air temperature: 42 °C
Voltage terminal 30: 13.216 V
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [109] - -
Mileage: 160607 km
Date: 2019.02.19
Time: 16:54:50
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 J HW: 0B6 927 156
Component: 0B6 20TFSIUSA H05 0008
Revision: --H05---
Coding: 001012
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3D273B745DFF894FB5B-8068
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Coding: 150D18
VCID: 7AADF0680CD17E77D09-802E
02214 - Tire Pressure Warning
Fault Frequency: 11
Reset counter: 245
Mileage: 159906 km
Date: 2019.01.26
Time: 13:45:32
Hex Value: 0x5500
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1CB6
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0324
Coding: 090200
VCID: 78A9EA6032DD6C67A6D-802C
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000048206006
Component: J764 ELV MLB H37 0042
Serial number: 0209000057643010
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01230920090312
Coding: 64102000
VCID: 005982806A0D24A79ED-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000469849
Coding: 26001091063CAF010000080300003D0D0F1C460800010161000000
VCID: 3C21367046658047825-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 190909 H06 0070
Serial number: SWF09090195930
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10603543
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000001109090958
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940927202021
Coding: 200103
VCID: 3E253C7850799257AC1-806A
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Serial number: 003EGD02DCK7
Coding: 303836354230303030304A55304C384B3053
VCID: 42DD48882401F6B7C89-8016
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900004F53
Serial number: 6334MSME4B14563DK
Serial number: 6344MSME4B743519I
Serial number: 6352QSME633B5136F
Serial number: 6362QSME3E3C062EW
Serial number: 63732SME753C3F0EF
Serial number: 63832SME753C1100T
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319III000DA
Coding: 000017
VCID: 3D273B745D7F894FB5B-8068
Component: E221 - MFL H02 0003
00886 - Turn Signal Switch (E2)
Fault Status: 00101110
Fault Frequency: 55
Reset counter: 26
Mileage: 158034 km
Date: 2018.11.20
Time: 20:11:25
Part No SW: 8K0 920 980 M HW: 8K0 920 980 M
Component: KOMBIINSTR. H19 0253
Revision: 00300000 Serial number: BXM21NY79
Coding: 8B1611000300D705020000
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E099118355
Coding: 00C303
VCID: 52FD78C8F4E16637789-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1908EC98040909
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009309652
Coding: 011C03204000410001
VCID: 45D7539435AFC18FEDB-8010
Reset counter: 56
Mileage: 145889 km
Date: 2018.01.25
Time: 12:02:32
Revision: 00002001 Serial number: 0121668965
Coding: 0126023A207A441400B0020000000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000168357
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J394 PS228 H06 0041
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Fault Frequency: 42
Reset counter: 17
Mileage: 145889 km
Date: 2018.01.25
Time: 12:02:32
02616 - Fuel Tank Cap; Unlock
Reset counter: 21
Mileage: 145889 km
Date: 2018.01.25
Time: 14:49:18
01403 - Glass-Break Sensors; Rear
Reset counter: 201
Mileage: 159922 km
Date: 2009.04.28
Time: 00:00:00
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009323099
VCID: 44D14E903E95F887FA5-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000325279
VCID: 34311E506E3548074A5-8060
Part No: 8K5 907 357
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 77ABE95C33C3631FAF7-8022
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335I/097529517
Coding: 020000020100000001
VCID: 1D67DBF4FDBFE94F95B-8048
02984 - Connection between Impedance Converter 2 and Window Antenna
Reset counter: 56
Mileage: 145888 km
Date: 2018.01.25
Time: 10:20:24
Voltage: 14.50 V
02788 - Internal Communications Error
Reset counter: 188
Mileage: 159671 km
Date: 2019.01.15
Time: 20:15:05
Bin. Bits: 00000001
Part No SW: 8T1 035 664 F HW: 8T1 035 664 A
Component: H-BN-NA H41 0189
Revision: -------- Serial number: 490I 097516760
Coding: 010200010006A1EF01000B0E000000030000
VCID: 3B23356C436B877F8BF-806E
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356I$091072688
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000364660
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Reset counter: 242
Mileage: 160488 km
Date: 2019.02.16
Time: 12:43:12
Voltage: 14.80 V
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101933898
Coding: 010C03204000210001
VCID: 42DD48882481F6B7C89-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9890WE
Coding: 1000007
Shop #: WSC 06325 000 00000
VCID: 38292A607E5DAC6766D-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101933891
End----------(Elapsed Time: 01:49, VBatt start/end: 12.2V/12.2V)-----------
