Results 1 to 1 of 1
Thread: 2008 CRAFTER very odd , drivers tailk light flashes only when running
    Mar 2017
    Ireland
    have one odd sick problem in front of me , 2008 crafter when you put on the tail light all is good but when you start the van the drivers tail light turns on and off very slowly like a timed event , any thoughts , i switched the wires to make it do it on the passenger side and it odes
    Thursday,11,April,2019,16:56:57:34799
    VCDS Version: 18.9.1.0
    Dealer/Shop Name: GUNT TUNING
    VIN: WV1ZZZ2EZ86034754   License Plate: 08 TN 2504
    Mileage: 156659   Repair Order: 999
    Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
    Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
              B0 B1 B2 B3 B4 B5 B6 C1
    Address 91: LT3 Engine        Labels: 074-997-032.clb
       Part No SW: 074 997 032 K    HW: 074 906 032
       Component: R5 2,5L EDC 0400SG  5194
       Revision: --H07---    Serial number: VWZDZ0H1007723
       Coding: 0003032
       Shop #: WSC 00265 941 101236
       VCID: 244CF83BE75C106A99-8070
    005716 - Please check DTC Memory of Instrument Cluster
                   P1654 - 001 -
                        RPM: 756 /min
                        Torque: 43.9 Nm
                        Load: 0.0 %
                        Voltage: 14.14 V
                        Temperature: 15.3C
                        Temperature: 45.9C
                        Temperature: 18.0C
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 001 - Open Circuit
                        Torque: 209.8 Nm
                        Load: 0.0 %
                        Voltage: 12.01 V
                        Bin. Bits: 00000000
                        Temperature: 24.3C
                        Bin. Bits: 00110000
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 K    HW: 906 545 260 8
       Component: IMMO          0628  0639
       Revision: 00628000    Serial number: VWZDZ0H1007723
       Shop #: WSC 00265 941 62287
       VCID: 336E0B6752B287D210-8066
    Address 94: LT3 Airbag
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3331.rod (*)
       VCID: 55AA95FF3486B9E2DE-8000
    Address 95: LT3 ESP
       Part No SW: 9064481553    HW: 0004460053
       ASAM Dataset: 3 4099
       ROD: CRFT_ESP_3_36928.rod (*)
       VCID: 0D1ABD9FDCD6B122A6-8058
    5106 - CAN: Signal outside temperature invalid
                MIL ON - Test Complete - Active/Stored
    51A0 - CAN: Signal engine nominal speed : Implausible signal
                MIL ON - Test Complete - Stored
    7206 - CAN Engine Control Module (ECM) (J623): Engine speed invalid
    Address 96: LT3 Instruments
       Part No SW: 9064482021    HW: 9064469921
       ASAM Dataset: 32 776
       ROD: CRFT_KOMBI_32_776.rod
       VCID: 040C98BB8F9CF06AF9-8050
    Address 99: LT3 Ign. Switch
       Part No HW: 9065452608
       ASAM Dataset: 67 256
       ROD: CRFT_EZS_67_256.rod (*)
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0628  0639
       Revision: 00628000    Serial number: 12345678901234
    Address 9B: LT3 Driver Door
       Part No HW: 9068203926
       ASAM Dataset: 33 771
       ROD: CRFT_FTUHR_33_771.rod (*)
    Address A0: LT3 Radio
       Part No HW: 9068200686
       ASAM Dataset: 1 3840
       ROD: CRFT2_RAD.rod
    Address B1: LT3 Upper Console
       Part No HW: 9065454107
       ASAM Dataset: 67 3
       ROD: CRFT1_OBF_67_3.rod (*)
    9036 - Supply voltage: Limit value exceeded
    Address B4: LT3 Central Elec.
       Part No SW: 9064420600    HW: 9065450601
       ROD: CRFT_EZE_33_771.rod (*)
       VCID: 7F061757E67A93B2A4-802A
    90A4 - Outside Air Temperature Sensor (G17): Short to Plus
    90AC - Terminal 61: Implausible signal
    Address B6: LT3 Steering Wheel
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 060882B3B9A0C27AE7-8052
    End-------------------------(Elapsed Time: 03:37)--------------------------
