Volkswagen Phaeton non starter
Hwash
C?ID=345501
Hi all i've got a 2006 VW Phaeton, sitting dead on my yard. Initially the car seemed to have immobilized its self. After a first scan the main system battery was found to be a bit tired. A new battery was fitted and the car was fine for a few days. Now I've now got a got a Key symbol up on the dash board and the car wont start or lock/unlock on the key fob. This is the auto scan results:
I should note, I couldn't get the auto scan to work as a Phaeton, so I scanned it as a Bentley Continental which seems to have worked
Wednesday,20,February,2019,12:34:54:39924
VCDS Version: 18.9.0.2  HEX-V2 CB: 0.4436.4
VIN: WVWZZZ3DZ78001179   License Plate:
Mileage: 182940km-113673mi   Repair Order: 20 feb
Chassis Type: 3D (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: WVWZZZ3DZ78001179   Mileage: 182940km-113673miles
   Part No SW: 3D0 907 401 A    HW: 8E0 907 401 AB
   Component: 3.0L V6TDI  G000AG  0010
   Revision: --H01---    Serial number: VWZ3Z0F1504902
   Coding: 0011773
   Shop #: WSC 66565 257 00032
   VCID: 1D67DA12D1A871AF953-5160
005685 - Powertrain Data Bus
               P1635 - 001 - Missing Message from A/C Controller - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 14
                    Mileage: 182941 km
                    RPM: 1281 /min
                    Torque: 62.4 Nm
                    Speed: 30.2 km/h
                    Duty Cycle: 6.0 %
                    Voltage: 14.59 V
                    Bin. Bits: 00001100
005785 - Powertrain Data Bus
               P1699 - 001 - Missing Message from Steering Wheel Electronics - Intermittent
                    Fault Frequency: 30
                    Mileage: 182941 km
                    RPM: 1260 /min
                    Torque: 31.2 Nm
                    Speed: 30.2 km/h
                    Duty Cycle: 5.0 %
                    Voltage: 14.67 V
                    Bin. Bits: 00001000
   Part No SW: 09L 927 760 J    HW: GS1 911 4
   Component: AG6 09L 3.0lTDI RdW 2205
   Revision: 00000001    Serial number:        4218824
   Coding: 0000001
   VCID: 3E253D9E7C6E0AB7AC9-513C
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008356
   Shop #: WSC 01065 000 00000
   VCID: 6B83C4CA5F9C4F1F5B7-51CE
18265 - Load Signal
            P1857 - 000 - Error Message from ECU
            000 -  -  - Intermittent
   Part No SW: 3D0 909 139     HW: 5WK 484 94
   Component: 0C Kessy            6700
   Revision: 67006015    Serial number: VWZ3Z0F1504902
   Coding: 0004328
   VCID: 6695B5FE447E7277049-5160
7 Faults Found:
00003 - Control Module
            014 - Defective
00288 - Steering Column Lock Actuator (N360)
00165 - Switch for Transmission Position P/N
00166 - Access/Start Authorization Switch (E415)
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1722
   Coding: 0000003
   VCID: 77ABE8BA13D4FBFFAFF-5160
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Address 07: Control Head        Labels: None
   Part No: 3D0 035 017 X
   Component:    ZAB COCKPIT      0253
   Coding: 0400535
   Shop #: WSC 00581 210 83422
   VCID: 2F3B10DAAB04F33F37F-5160
12 Faults Found:
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
00387 - Plus Output Audio Channel for Navigation Announcements
00388 - Negative Output Audio Channel for Navigation Messages
00856 - Radio Antenna
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
01312 - Powertrain Data Bus
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 J
   Component: Climatronic D1      2031
   Coding: 0000001
   VCID: 2517F2F2F9F8B96FCD3-5160
00021 - Motor for Blocking Flap; Defrost and Body Vents; Left (V200)
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 L    HW: 3D0 937 049 L
   Component: J519                6200
   Revision: -4003---    Serial number: --------------
   Coding: 600200002A2115000000000000000000
   Shop #: WSC 00660 210 82436
   VCID: 33331CAA472CD7DF537-5160
00576 - Terminal 15
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 E
   Component: 0J Airbag 8.4E+ H10 0935
   Coding: 0012362
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Component: Lenksäulenmodul     3401
   Coding: 0000232
            014 - Defective
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No: 3D0 920 982 H
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0023411
   VCID: 2D070AD2A108812F053-5160
   Part No: 3D0 815 005 AG
   Component: Standheizung        2426
   Shop #: WSC 00581 210 71766
   VCID: 629DA9EEA8560E57E81-5160
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
   VCID: 70B9D3A676BAACC76E5-5160
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   VCID: 270BF8FA83F4AB7FFFF-5160
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1722
   Coding: 0000004
   VCID: 6FBBD0DA6B84B33F77F-5160
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 J
   Component:    NAVIGATION       0188
   Coding: 0400000
   VCID: 3B23348A6F7C1F9F8B7-5160
00480 - Control Module in Instruments for Infotainment CAN (J285)
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 C
   Component: Dachmodul           0708
   Coding: 0000062
   VCID: 2313ECEAF7CC475FA37-5160
00221 - Connection to Interior Monitoring
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: X3 HSG              0102
   Coding: 0000040
   Shop #: WSC 00566 210 80271
   VCID: 33331CAA472CD7DF537-4B1E
   Subsystem 1 - Part No: 3D2 959 701 H
   Subsystem 2 - Part No: 3D2 959 702 H
   Subsystem 3 - Part No: 3D0 959 703 G
   Subsystem 4 - Part No: 3D0 959 704 G
   Subsystem 5 - Part No: 3D0 909 610 E
   Component: 3O HDSG             2530
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
00576 - Terminal 15
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 3D0 035 465 A
   Component: 08K-AUDIOVERST      0112
   VCID: 1F1BE01ADBA463BF87F-5160
Address 57: TV Tuner        Labels: None
   Part No SW: 3D0 919 148     HW: 3D0 919 148
   Component: TV-Tuner            0060
   Revision: R0H12000    Serial number: 91100500029201
   Coding: 0080001
   VCID: 678BB8FA43746B7F3FF-5160
8 Faults Found:
00532 - Supply Voltage B+
                    Reset counter: 40
03214 - Video Signal Y+
                    Fault Status: 00100111
                    Fault Frequency: 9
                    Reset counter: 40
                    Fault Status: 00101010
                    Reset counter: 40
03215 - Video Signal C+
                    Fault Frequency: 9
                    Reset counter: 40
                    Reset counter: 40
03228 - Video Signal Y-
                    Reset counter: 40
03229 - Video Signal C-
                    Fault Frequency: 13
                    Reset counter: 40
                    Reset counter: 40
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D2 955 120 A
   Component: Front Wiper         3000
   VCID: 2019E3E6E6DA5C47BE5-5160
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 2411EFF6F2C24067DAD-5160
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 D
   Component: 01 Einparkhilfe     0907
   VCID: 2B0304CA9F1C8F1F1B7-5160
Address 77: Telephone        Labels: 3W7-035-385.lbl
   Part No SW: 3W7 035 385 H    HW: 3W7 035 385 H
   Component: UHV Premium rSAP    0037
   Coding: 0002320
   VCID: 41DF46620D90754FD1B-5160
End----(Elapsed Time: 08:12, VBatt start/end: 14.7V/14.5V. VIgn 0.0V)------
Address 01: DTCs cleared
Address 02: DTCs cleared
Any ideas what I should be looking at, any help appreciated!
Jef
HQ
If you get lucky and the module is dry, verify the powers/grounds can carry load for the module. Voltage drop issues can screw with a module.
Hwash
C?ID=345501
Many thanks for your response, I've just checked and yes Kessy is floating in a puddle! Attempting to dry it out, hopefully it hasn't damaged the board (wishful thinking!)
darkchina811
ITALY
C?ID=333184
if the module can be disassembled, take the board out and soak it in isopropyl alcohol for ten minutes, then clean the dirt with a medium brush and rinse with DISTILLED water. let it dry under the sun, then reassemble and test.
cross your fingers.
Jef
HQ
Wiring harnesses love some capillary action. Are the terminals on the wiring harness and module still clean and shiny? If so, shouldn't be an issue.
But if the terminals are discolored or rotted, then that has means there been more time for the wiring to suck water up into the copper wiring. I've found this tends to be more of an issue on cars that sit around, not driven very often.
cross your fingers.
Like this............?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
That happens all the damn time to Phaetons. Check for any missing under-body plugs. Check all four of your sunroof drains (one in each corner). Also check that the under-hood plenum space (between the engine and the windshield) drains properly as well. Otherwise it'll just happen again.
Here's hoping your KESSY dries out in a usable state. :thumbs:
But if the terminals are discolored or rotted, then that has means there been more time for the wiring to suck water up into the copper wiring. I've found this tends to be more of an issue on cars that sit around, not driven very often.​
Jef
Yeah like a candle or a kerosene heater sock........
Post pic's OP .........
I'm far away but could aid in data transfer through mail & to persevere key data & a bigger mess from happening if you get involved with wrong, let's say "unqualified personnel" something to consider?
Agreed, it should be a campaign or class action for BAD "Engineering Judgement" used in preventing FOD, right?
Zenerdiode
Newcastle, England
C?ID=24330
"WARNING: Keep brush out of reach of children. Do not touch bristles..."
Oh yeah? :rolleyes: I found out the hard way. I think one of you wrote 'sometimes you've gotta touch the stove to know that it's hot' For those unsure, Jack's picture is a glassfibre brush or we call them a glassfibre pencil. What looks like a nice fluffy brush on the end are hundreds of tiny glass fibres that break off and penetrate your skin very easily. I've only ever rubbed my thumb over the bristles once; I couldn't pick anything up for a week and a half afterwards haha! :eek:
They are really good for cleaning contacts though.
Hwash
C?ID=345501
I've given the board a good clean and dry out, and left it over night in a warm room. (no sun in the UK to dry it out!) Wiring harness and terminals look fine. The board however has definitely suffered from water damage with various corroded sections.
No sun roof on this car so I'm guess the water is getting in from the scuttle panel area. The under bonnet is dripping with water though like some one has attacked it with a pressure washer!
I refitted the board this morning and the car unlocked and started fine, but another scan reveals the same faults. So i'm guessing this fault is going to reoccur!
Fix water leak and do a transfer while you can or you will be sorry .....echo echo echo echo..............
Hwash
C?ID=345501
Just to update this, I left this Phaeton to dry out and sent the Kessy away to be repaired. The board was damaged in various places. In the end another Kessy was sourced and the data was transferred.
First scan with the replacement Kessy
Thursday,04,April,2019,15:36:13:39924
Chassis Type: 3D - VW Phaeton (2002 > 2006)
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
   Revision: 6700I515    Serial number: XXXXXXXXXXXXXX
   Coding: 0000000
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 1940
   VCID: 55F78232EC08E9EF9D3-5160
   Note: Excessive Comm Errors
   Coding: 0080001
End----(Elapsed Time: 10:22, VBatt start/end: 12.2V/12.5V. VIgn 0.0V)------
Last time it scanned I get:
Wednesday,10,April,2019,16:25:20:39924
Excessive comms errors, every where. I'm guessing the water has gone to town on the wiring (it is still very damp in the car!)
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Sure you had ignition on for that? You had to go to and through the instrument cluster to access the other devices in the car, but it's not in the scan...
Hwash
C?ID=345501
Well no not really, key was in the ignition. But I'm not getting a response from the ignition key other than the steering lock working.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Yeah I was kind of feeling that.
No faults other than the coding fault, unless you've cleared stuff we're not seeing... and if your ESCL pops in response to the key, your Immo identity transfer went okay.
   Coding: 0000000
   Component: ELV                 1940
Maybe go ahead and take care of that missing coding and see what you get? Needs to be done anyway. Just transfer your original coding from your first scan, which was 0004328.
Hwash
C?ID=345501
Thanks for your assistance,
So a new scan with the ignition on :o
I attempted to add the missing coding and I get 'Coding rejected out of range Error 31'
Thursday,11,April,2019,09:49:21:39924
   Coding: 0000000
   Component: ELV                 1940
01176 - Key
   Coding: 0000003
   Coding: 0000001
   Coding: 0000232
   Coding: 0000004
   Coding: 0000062
   Coding: 0000040
   VCID: 33331CAA472CD7DF537-4B00
13 Faults Found:
00576 - Terminal 15
01134 - Alarm Horn (H12)
00318 - Supply Voltage for Rear Lid Control Module
00896 - Trunk Lock Unit (F256)
   Coding: 0080001
   Coding: 0002320
End----(Elapsed Time: 09:37, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
Address 05,3D0 909 139 ,recoded (Short coding),from,0000000,to,0004328,(01065/000/00000),
Still quite a few things not talking, including 01-Engine...
