Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Multiple Oxygen Sensor codes P0131, P0130, P2251
    Dec 2018
    Lehigh Valley, PA
    Backyard mechanic here.
    I have replaced O2 sensor on manifold with a used one from parts bin and get the same codes. (thinking it was the sensor)
    Visual inspection show no apparent wire issues at 6 pin connector
    Is there any tests with measuring blocks? What am I looking for?
    Using a voltmeter what do I test and what outcome am I looking for?
    Tuesday,19,February,2019,08:02:54:55382
    VCDS Version: Release 18.9.1 (x64) Running on Windows 10 x64
    Address 01: Engine Labels: 06A-906-032-BGP.lbl
    Control Module Part Number: 07K 906 032 BG HW: 07K 906 032 Q
    Component and/or Version: 2,5l R5/4V G 1859
    Software Coding: 0000003
    Work Shop Code: WSC 00066 000 00000
    VCID: 6FEC55C67E455A3234-803A
    000305 - Oxygen (Lambda) Sensor B1 S1
    P0131 - 002 - Signal too Low - Intermittent - MIL ON
    Fault Status: 10100010
    Mileage: 180945 km
    Time: 17:36:22
    RPM: 2576 /min
    Load: 89.8 %
    Speed: 79.0 km/h
    Temperature: 91.0°C
    Temperature: 24.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.224 V
    008785 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
    P2251 - 004 - Open Circuit
    Mileage: 180949 km
    Time: 07:37:46
    RPM: 831 /min
    Load: 30.2 %
    Temperature: 22.0°C
    Temperature: 6.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.351 V
    000304 - Oxygen (Lambda) Sensor B1 S1
    P0130 - 001 - Malfunction in Circuit
    Fault Status: 01100001
    Mileage: 180949 km
    Time: 07:37:46
    RPM: 831 /min
    Load: 30.2 %
    Temperature: 22.0°C
    Temperature: 6.0°C
    Voltage: 14.351 V
    Readiness: 0000 1000
    Dec 2018
    Lehigh Valley, PA
    I have wire diagram but do not know what to test
    Component and/or Version: 2,5l R5/4V G 1859<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed!
    Please to meet you "backyard mechanic"...... I'm the asshole mechanic!
    Did you load light wire tracks from G39 connector to ecu T94 connector & at respective pins, if good current is able to be carried by respective tracks & with a quality new oxygen sensor, not some used one, change engine ecu?
    Isn't it advised to check and load light plus inspect all tracks of ecu harness and a visual inspection of wiper area or for harness known defects?
    JPPSG?
    https://forums.ross-tech.com/showthr...final-version)
    Post a complete auto-scan with valid vin number to pull PR data.
    If you need a controller or OXS or package deal please see us here & with included data transfer.
    https://www.ebay.com/itm/330955482482
    Did you change entire OXS or did you crimp some POS in?
    And remember the worst type of FOD is induced FOD!
    Please clear codes and report a fresh complete auto-scan after doing so and additionally with MODE 9 DATA from the OBD2 side too!
    WARNING!
    This car is an SULEV! ......... & contains 3 OXS sensors & that like to share tracks and fuck around with each other for some undocumented fun outside the scope of the RTFB!
    Hey PSSST....... did you know you are reading the wrong WD so go to ERWIN and check yourself?
    Who knows? NostraJackASS knows nothing!
    Dec 2018
    Lehigh Valley, PA
    Thank you for the quick response.
    The used OXS was from a low mileage motor complete with 6-pin connector.
    My first task is the cowl area harness inspection and expose the ecu.
    Bentley manual is due to be delivered today. I have been using Haynes and www.repairsurge.com
    Mike Wiest
    Backyardplants@gmail.com
    Lehigh Valley, PA
    610.50437413
    This is not a complete auto-scan...............
    Dec 2018
    Lehigh Valley, PA
    Wednesday,20,February,2019,15:16:34:55382
    VCDS Version: 18.9.1.0 (x64)
    VIN: 3VWRZ71K48M154951   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRZ71K48M154951   Mileage: 180980km-112455miles
    Address 01: Engine (CBU)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 BG    HW: 07K 906 032 Q
       Component: 2,5l R5/4V      G   1859
       Revision: 1NH03---    Serial number: VWX7Z0H224J02H
       Coding: 0000003
                        Mileage: 180985 km
                        Time: 00:02:47
                        RPM: 782 /min
                        Load: 21.2 %
                        Temperature: 35.0°C
                        Temperature: 15.0°C
                        Voltage: 14.224 V
                        Mileage: 180985 km
                        Time: 00:02:47
                        RPM: 782 /min
                        Load: 21.2 %
                        Temperature: 35.0°C
                        Temperature: 15.0°C
                        Voltage: 14.224 V
    Readiness: 0110 1101
       Part No SW: 09G 927 750 HE    HW: 09G 927 750 HE
       Component: AQ 250 6F           1090
       Revision: 00H69000    Serial number:
       Coding: 0000584
       VCID: 7BF471963A3D369288-802E
       Revision: 00H11001
       Coding: 0021122
       VCID: 73E459B6126D7ED2D0-8026
       Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
       Component: Climatic PQ35   141 1010
       Revision: 00141028    Serial number: 00000000000000
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000007834610
       Coding: 14058E234004150007140000001400000008730B5C000100000000000000
       Component: Wischer 190308 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    00906 - Horn (H1)
                        Fault Status: 00101001
                        Reset counter: 44
                        Mileage: 180985 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.70 V
    Address 0F: Digital Radio        Labels: None
       Part No SW: 8E0 035 593 Q    HW: 8E0 035 593 Q
       Component: SDAR SIRIUS     H08 0160
       Revision: 00000000    Serial number: AUZ4Z7L0596198
       Coding: 0000000
       VCID: 377CADA64695D2F22C-8062
                        Reset counter: 4
                        Mileage: 180985 km
                        Time: 00:02:29
       Revision: 05034000    Serial number: 003B6M04NNNT
       Coding: 0013889
       VCID: 6CD642CA4F53A12A11-8038
       Subsystem 2 - Serial number: 6332MSME33031253Y
       Subsystem 3 - Serial number: 6342MSME3555617AE
       Subsystem 4 - Serial number: 6351HSME13280B765
       Subsystem 5 - Serial number: 6361HSME131C595BF
       Subsystem 6 - Serial number: 63727SME125B5C534
       Subsystem 7 - Serial number: 63827SME126B405F5
       Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
       Component: J0527           051 0100
       Coding: 0010021
       VCID: 77FC6DA6061512F2EC-8022
       Part No SW: 1K0 920 954 Q    HW: 1K0 920 954 Q
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0002000    Serial number: VWX7Z0H224J02H
       Coding: 0023203
       Shop #: WSC 00066 067 57207
       VCID: 3A7AB4927587CF9AD3-806E
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 150208F1001180
       Coding: ED807F070003021002
       VCID: 306E96BAA3FB05CA6D-8064
       Component: IMMO            3HL 1222
       Shop #: WSC 47505 003 1048576
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000548188307
       Coding: 0001205
       VCID: 3B74B1967ABDF692C8-806E
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.070 H08 1901
       VCID: 3560A7AE5C9920E23E-8060
       Coding: 13980F880186281B0904058FB0880F0488DCA0
       VCID: 04060A6A47C3496AF9-8050
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000572688305
       Coding: 0001204
       VCID: 3C76B28A7FB3F1AAC1-8068
       Component: Radio DE2       016 0020
       Revision: 00016000    Serial number: VWZ4Z7H2190641
       Coding: 0010400
       VCID: 29587BDE80217402AA-807C
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000002832669
       Coding: 0001168
       VCID: 3E72B88269AFE3BAEF-806A
    00934 - Electric Window Motor; Rear Left (V26)
                        Fault Status: 01100101
                        Reset counter: 4
                        Mileage: 180985 km
       Coding: 0100101
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000002834165
       Coding: 0001168
       VCID: 3F8CC5866EA5EAB2E4-806A
                        Fault Status: 01111000
                        Reset counter: 4
                        Mileage: 180985 km
    00935 - Electric Window Motor; Rear Right (V27)
                        Reset counter: 4
                        Mileage: 180985 km
                        Fault Status: 01111100
                        Reset counter: 4
                        Mileage: 180985 km
    End-------------------------(Elapsed Time: 02:08)---------------
    Mike Wiest
    Lehigh Valley, PA
    610.50437413
  7. #7
    PR DATA record.
    Thank you OP for posting an auto-scan
    Vehicle Identification No. 3VWRZ71K48M154951
    Model Jetta
    JEM
    Date of production 03.04.2008
    Year 2008
    Sales type 1K27S3
    Engine Code CBUA
    Transmission Code KBV
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HM Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 0GT Emission standard SULEV
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KE Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZP Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ1 Chrome package
    General operating permit, alterations C12 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G46 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0ER Installation differentiation for transmission AQ250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MA Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K4 Separate daytime running lights NAR
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YG Weight range 7 installation control only, no requirement forecast
    Weight category front axle L13 Suspension range 13 installation control only, no requirement forecast
    Base engine T8K 5-cylinder SI engine 2.5 l unit 07K.1
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U0 Without luggage compartment cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1A 6-speed automatic transmission
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M0 Without rear window wiper and washer system
    Rear seats 3NQ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8B Notchback
    Cassette and CD storage unit 4W0 without cassette / CD tray
    coolbox 1W2 Glove compartment cooling system
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank treatment 2LF Fuel tank with special material treatment (coextrusion) with changed protective layer
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 1A1 Fuel system for fuel-injected SI engine, injection system without fuel return
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H2 Backrest release for right front seat
    Air duct, front area VK1 Air duct, type 1
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 1MH Leather-wrapped steering wheel
    Speaker installation 8RW 10 speakers (passive)
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q0 Without multi-function display/ trip computer
    Engine cooling 8Z6 Hot country
    Engine specifications D77 5-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WA Without fog lights
    Upgrading measures GP0 Vehicles w/o special upgrade measures
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CJ8 Alloy wheels 6.5J x 16
    Radios 8US Radio "Premium" (double-size standard radio)
    Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
    Tire pressure monitoring system 7K4 Tire pressure monitoring system 315 MHz High
    tire H4B All-season tires 205/55 R16 H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G4 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PMC California emission concept
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Nameplates for sales name QD3 Lettering for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N0C Seat trim covers in leatherette
    Seat adjustment 3PD Manual height adjustment for front seats, electric backrest adjustment for left front seat
    seat heater 4A3 seat heating for front seats separat controlable
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) SL9 Control (in-plant)
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B0 with no protective side strip
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JC Comfort bumpers
    Rear stabilizer 0BG Rear stabilizer
    Front stabilizer bar 0AG Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 0NV Nameplate set "2.5"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B38 Legal requirements California
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV8 Satellite radio reception NAR
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  8. #8
    Dec 2018
    Lehigh Valley, PA
    This is the correct WD for the oxs for this car. EWD-57 # 38/14 with 121 pin.
    My T6 connector is wired differently than on this WD.
    T6w5 is black T6w2 is green/white (similar to the previous WD I posted earlier 94 pin)
    The car is new to me and this is the first I'm working on it. I don't understand the schematics of the G39 on the WD. Would this effect the OXS?
    Mike Wiest
    Lehigh Valley, PA
    610.50437413
  9. #9
    Dec 2018
    Lehigh Valley, PA
    How my T6 is pinned
    Mike Wiest
    Lehigh Valley, PA
    610.50437413
  10. #10
    Wire and check tracks pin location to pin location and omit color or WD racism.
    He doubts me?
